j’ai installé le plugin cloudsyncpro mais impossible d’installer les dependances.
je suis en v3.3.59.
j’essaye de comprendre les logs mais je ne suis pas trop doué
si quelqu’un peut m’aider…
voici ce que me met les logs:
* Installation des dépendances *
* Pre-Installation cleaning *
Kernel name: Linux
Machine Hardware name: armv7l
* Download the rclone pre-build installer *
converted 'https://downloads.rclone.org/v1.41/rclone-v1.41-linux-arm.zip' (ANSI_X3.4-1968) -> 'https://downloads.rclone.org/v1.41/rclone-v1.41-linux-arm.zip' (UTF-8)
--2022-01-17 10:27:42-- https://downloads.rclone.org/v1.41/rclone-v1.41-linux-arm.zip
Resolving downloads.rclone.org (downloads.rclone.org)... 5.153.250.7, 2a02:24e0:8:61f9::1
Connecting to downloads.rclone.org (downloads.rclone.org)|5.153.250.7|:443... connected.
ERROR: The certificate of 'downloads.rclone.org' is not trusted.
ERROR: The certificate of 'downloads.rclone.org' has expired.
* Extract the rclone pre-build installer *
Archive: /var/www/html/plugins/cloudsyncpro/resources/../3rparty/rclone-v1.41-linux-arm.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of /var/www/html/plugins/cloudsyncpro/resources/../3rparty/rclone-v1.41-linux-arm.zip or
/var/www/html/plugins/cloudsyncpro/resources/../3rparty/rclone-v1.41-linux-arm.zip.zip, and cannot find /var/www/html/plugins/cloudsyncpro/resources/../3rparty/rclone-v1.41-linux-arm.zip.ZIP, period.
* Download the Google Api Framework *
converted 'https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip' (ANSI_X3.4-1968) -> 'https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip' (UTF-8)
--2022-01-17 10:27:42-- https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip [following]
converted 'https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip' (ANSI_X3.4-1968) -> 'https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip' (UTF-8)
--2022-01-17 10:27:43-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A/20220117/us-east-1/s3/aws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment;%20filename=google-api-php-client-2.2.1.zip&response-content-type=application/octet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.109.133, 185.199.110.133, 185.199.111.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.109.133|:443... connected.
HTTP request sent, awaiting response... 401 Unauthorized
Username/Password Authentication Failed.
--2022-01-17 10:27:43-- https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
Reusing existing connection to github.com:443.
HTTP request sent, awaiting response... 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20220117%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment%3B%20filename%3Dgoogle-api-php-client-2.2.1.zip&response-content-type=application%2Foctet-stream [following]
converted 'https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20220117%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment%3B%20filename%3Dgoogle-api-php-client-2.2.1.zip&response-content-type=application%2Foctet-stream' (ANSI_X3.4-1968) -> 'https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A/20220117/us-east-1/s3/aws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment; filename=google-api-php-client-2.2.1.zip&response-content-type=application/octet-stream' (UTF-8)
--2022-01-17 10:27:44-- https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
--2022-01-17 10:27:44-- https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
--2022-01-17 10:27:44-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A/20220117/us-east-1/s3/aws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment;%20filename=google-api-php-client-2.2.1.zip&response-content-type=application/octet-stream
--2022-01-17 10:27:45-- https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
--2022-01-17 10:27:45-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A/20220117/us-east-1/s3/aws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment;%20filename=google-api-php-client-2.2.1.zip&response-content-type=application/octet-stream
--2022-01-17 10:27:45-- https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
--2022-01-17 10:27:46-- https://github.com/googleapis/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
--2022-01-17 10:27:46-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/12166778/a87e39f0-e3cd-11e7-828b-181ac585e76f?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A/20220117/us-east-1/s3/aws4_request&X-Amz-Date=20220117T102743Z&X-Amz-Expires=300&X-Amz-Signature=d4841be0f969d18c7b277ff4f93d12755a917419536603ac92be151031d1767f&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=12166778&response-content-disposition=attachment;%20filename=google-api-php-client-2.2.1.zip&response-content-type=application/octet-stream
--2022-01-17 10:27:46-- https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
--2022-01-17 10:27:47-- https://github.com/google/google-api-php-client/releases/download/v2.2.1/google-api-php-client-2.2.1.zip
20 redirections exceeded.
* Extract the Google Api Framework *
Archive: /var/www/html/plugins/cloudsyncpro/resources/../3rparty/google-api-php-client-2.2.1.zip
unzip: cannot find zipfile directory in one of /var/www/html/plugins/cloudsyncpro/resources/../3rparty/google-api-php-client-2.2.1.zip or
/var/www/html/plugins/cloudsyncpro/resources/../3rparty/google-api-php-client-2.2.1.zip.zip, and cannot find /var/www/html/plugins/cloudsyncpro/resources/../3rparty/google-api-php-client-2.2.1.zip.ZIP, period.
* Post-Installation cleaning *
chown: cannot access '/var/www/html/plugins/cloudsyncpro/resources/../3rparty/rclone-v1.41-linux-arm': No such file or directory
* Installation terminée *
