Mon plugin Mail Listener refuse de démarrer, il doit relever une boite Gmail, cf Santé & Log d’install
Début de l’installation
Installation spécifique plugin
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated mimelib@0.3.1: This project is unmaintained
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated mailparser@0.4.9: Mailparser versions older than v2.3.0 are deprecated
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 90 packages, and audited 91 packages in 10s
13 packages are looking for funding
run `npm fund` for details
5 moderate severity vulnerabilities
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
Fin de l'installation
node:internal/validators:226
throw new ERR_SOCKET_BAD_PORT(name, port, allowZero);
RangeError [ERR_SOCKET_BAD_PORT]: Port should be >= 0 and < 65536. Received false.
at new NodeError (node:internal/errors:387:5)
at validatePort (node:internal/validators:226:11)
at lookupAndConnect (node:net:1094:5)
at Socket.connect (node:net:1070:5)
at Connection.connect (/var/www/html/plugins/maillistener/resources/node_modules/imap/lib/Connection.js:286:10)
at MailListener.start (/var/www/html/plugins/maillistener/resources/node_modules/mail-listener3/index.js:45:15)
at Object.<anonymous> (/var/www/html/plugins/maillistener/resources/maillistener.js:62:14)
at Module._compile (node:internal/modules/cjs/loader:1126:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
at Module.load (node:internal/modules/cjs/loader:1004:32) {
code: 'ERR_SOCKET_BAD_PORT'
