Hi,
I suggest to build a plugin for the solar inverter from Huawei.
The comunication can be made through Modbus TCP.
Of course that I’m going to collaborate in any way I can, including making a donation.
Thank you,
Iñaki
Hi,
Thank you,
Iñaki
Hi dear,
I found anything about this solar inverter, do you have a link do discover what the is ?
I believe there is a topic on the forum about modbus plugin.
Don’t know where it’s at since I don’t use it.
Yes, there’s a plugin about modbus, but currently is not compatible.
This family of inverters are the best sellers, and having a dedicated plugin would be great.
@cdrikd modify a plugin and have the data from Huawei inverter, coud you explain your modif on plugin?
Par où commencer ?
Une idée de la faisabilité de la chose ?
Je cherche aussi un plugin ou une solution pour capturer les données d’un onduleur Huawei SUN2000 via TCPIP, j’ai essayé tout les plugins ModBus pour l’instant mais aucune ne fonctionne et ne donne les valeurs que je recois bien via le logiciel ModBus Doctor. merci
