J’ai une Smart 4.3.23
Dans le log http.error, je vois régulièrement des lignes:
[Mon Apr 15 17:38:06.593711 2024] [access_compat:error] [pid 701] [client 192.168.1.49:36127] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard
[Mon Apr 15 17:53:19.114661 2024] [access_compat:error] [pid 585] [client 192.168.1.49:36218] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard&object_id=1
[Mon Apr 15 17:56:29.318911 2024] [access_compat:error] [pid 588] [client 192.168.1.49:37303] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard&object_id=1
[Mon Apr 15 17:59:22.072710 2024] [access_compat:error] [pid 1971] [client 192.168.1.49:37322] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard&object_id=1
[Mon Apr 15 17:59:48.857603 2024] [access_compat:error] [pid 2121] [client 192.168.1.49:37324] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard&object_id=1
[Tue Apr 16 07:05:58.075832 2024] [access_compat:error] [pid 7873] [client 192.168.1.49:37744] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard
[Tue Apr 16 09:51:04.698767 2024] [access_compat:error] [pid 8548] [client 192.168.1.49:39775] AH01797: client denied by server configuration: /var/www/html/plugins/widget, referer: http://192.168.1.40/index.php?v=d&p=dashboard
Je pense que lors de l’intégration du plugin Widget dans le core, ça s’est pas bien passé sur ma configuration , ou bien lors de suppressions de plugins plus utilisés??
Le plugin widgets ne doit plus être présents sur les Jeedom en version 4.3 et supérieur.
Le fonctionnement de ce plugin est directement intégré au Core de Jeedom.
Merci de la réponse rapide, mais je n’ai plus ce plugin dans ma liste de la gestion des plugins, suite à l’intégration dans le Core, et donc il doit y avoir encore des références je ne sais où? comment nettoyer?
Alors c’est que vous avez encore une ou plusieurs commandes d’équipement qui sont toujours configurées pour utiliser un widget qui était géré par le plugin widget.
La suppression de celui-ci n’a pas corrigé/modifié les configs.
Afficher le dashboard piece par piece et ensuire jouez avec la visibilité des équipements pour trouver la ou les commande(s)
J’ai trouvé un virtuel On/off/Etat qui m’indiquait le Jour ou la Nuit avec une image sur le desktop qui avait la CC Etat avec un widget « Customtemp/WJourNuit ». D’ailleurs quand j’ouvre cette combo liste Widget/Dashboard: il y a encore plusieurs widgets Customtemp : Presence_femme_2,Presence_homme_2, Bell, Choc, Feu, Incendie, Inondation, Porte_garage .
C’est un virtuel piloté par un scenario utilisant le plugin Weather pour détecter le lever du jour et le coucher du soleil.
J’ai désactivé ce virtuel pour voir : pour le moment, je n’ai pas plus cette erreur dans le log http.error,
mais j’ai des lignes « Python 2.7.16 » ?
les widgets « customtemp » ne sont pas un problème en soit, ce sont des widgets code mais géré via le core
Allez dans l’outil widget, bouton code
là vous verrez une série de fichier html, probablement des widgets qui ont été copié depuis le plugin widget;
le problème c’est que ces fichiers html, bien qu’étant dans le dossier du core, utilisent des images qui se trouvaient dans le dossier du plugin widget
Il faut donc les modifier pour pointer sur une image dans le dossier data/img
ceci dit pour des widgets binaire tel que ceux cités, c’est plus simple d’utiliser un widget core (bouton ajouter) de type info/binaire
Effectivement c’est bien ça le problème!
Dans l’outil Widget/code/dashboard, j’ouvre ‹ cmd.info.binay.wJourNuit.html ›
Ce code html pointe sur
‹ plugins/widget/core/template/dashboard/cmd.info.binary.wJourNuit/Jour.png ›
et
‹ plugins/widget/core/template/dashboard/cmd.info.binary.wJourNuit/Nuit.png ›
qui n’existent plus!
Du coup j’ai mis un autre widget Info/Binaire, pour cette cde info du virtuel.
