ce matin j’ai effectué la dernière mise à jour du plugin Modbus,
après avoir cliqué sur recharger le message HTTP ERROR 500 apparait et du coup impossible de se reconnecter au jeedom.
Se connecter avec &rescue=1 à la fin de l’URL.
Puis donner le contenu du log http.error.
0119|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0120|[Fri Sep 01 17:02:26.241643 2023] [php7:error] [pid 11961] [client 127.0.0.1:39824] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0121|Stack trace:
0122|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0123|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0124|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0125|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0126|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0127|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0128|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0129|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0130|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0131|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0132|[Fri Sep 01 17:02:26.242316 2023] [php7:error] [pid 11958] [client 127.0.0.1:39822] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0133|Stack trace:
0134|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0135|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0136|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0137|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0138|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0139|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0140|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0141|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0142|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0143|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0144|[Fri Sep 01 17:02:26.454274 2023] [php7:error] [pid 11962] [client 127.0.0.1:39828] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0145|Stack trace:
0146|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0147|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0148|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0149|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0150|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0151|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0152|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0153|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0154|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0155|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0156|[Fri Sep 01 17:02:26.600765 2023] [php7:error] [pid 1311] [client 127.0.0.1:39832] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0157|Stack trace:
0158|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0159|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0160|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0161|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0162|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0163|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0164|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0165|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0166|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0167|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0168|[Fri Sep 01 17:02:26.746613 2023] [php7:error] [pid 3290] [client 127.0.0.1:39834] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0169|Stack trace:
0170|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0171|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0172|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0173|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0174|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0175|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0176|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0177|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0178|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0179|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0180|[Fri Sep 01 17:02:26.941038 2023] [php7:error] [pid 8872] [client 127.0.0.1:39836] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0181|Stack trace:
0182|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0183|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0184|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0185|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0186|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0187|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0188|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0189|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0190|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0191|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0192|[Fri Sep 01 17:02:27.054333 2023] [php7:error] [pid 26317] [client 127.0.0.1:39838] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0193|Stack trace:
0194|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0195|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0196|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0197|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0198|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0199|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0200|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0201|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0202|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0203|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0204|[Fri Sep 01 17:02:27.182693 2023] [php7:error] [pid 8289] [client 127.0.0.1:39840] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0205|Stack trace:
0206|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0207|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0208|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0209|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0210|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0211|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0212|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0213|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0214|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0215|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0216|[Fri Sep 01 17:02:27.376206 2023] [php7:error] [pid 8834] [client 127.0.0.1:39842] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0217|Stack trace:
0218|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0219|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0220|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0221|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0222|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0223|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0224|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0225|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0226|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0227|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0228|[Fri Sep 01 17:02:47.491607 2023] [php7:error] [pid 11959] [client 127.0.0.1:39848] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0229|Stack trace:
0230|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0231|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0232|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0233|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0234|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0235|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0236|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0237|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0238|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0239|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0240|[Fri Sep 01 17:02:47.838038 2023] [php7:error] [pid 11961] [client 127.0.0.1:39850] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0241|Stack trace:
0242|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0243|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0244|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0245|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0246|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0247|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0248|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0249|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0250|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0251|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0252|[Fri Sep 01 17:02:48.360042 2023] [php7:error] [pid 11958] [client 127.0.0.1:39852] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0253|Stack trace:
0254|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0255|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0256|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0257|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0258|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0259|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0260|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0261|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0262|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0263|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0264|[Fri Sep 01 17:02:48.544208 2023] [php7:error] [pid 11962] [client 127.0.0.1:39854] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0265|Stack trace:
0266|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0267|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0268|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0269|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0270|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0271|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0272|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0273|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0274|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0275|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0276|[Fri Sep 01 17:02:48.680618 2023] [php7:error] [pid 1311] [client 127.0.0.1:39856] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0277|Stack trace:
0278|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0279|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0280|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0281|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0282|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0283|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0284|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0285|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0286|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0287|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0288|[Tue Sep 05 04:21:56.723011 2023] [php7:error] [pid 31818] [client 127.0.0.1:49734] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0289|Stack trace:
0290|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0291|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0292|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0293|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0294|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0295|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0296|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0297|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0298|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0299|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0300|[Tue Sep 05 04:21:56.747384 2023] [php7:error] [pid 19800] [client 127.0.0.1:49736] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0301|Stack trace:
0302|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0303|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0304|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0305|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0306|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0307|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0308|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0309|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0310|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0311|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0312|[Tue Sep 05 04:21:56.767312 2023] [php7:error] [pid 20011] [client 127.0.0.1:49738] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0313|Stack trace:
0314|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0315|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0316|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0317|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0318|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0319|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0320|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0321|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0322|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0323|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0324|[Tue Sep 05 04:42:02.787576 2023] [php7:error] [pid 19801] [client 127.0.0.1:49772] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0325|Stack trace:
0326|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0327|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0328|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0329|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0330|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0331|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0332|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0333|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0334|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0335|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0336|[Tue Sep 05 04:42:02.812778 2023] [php7:error] [pid 31818] [client 127.0.0.1:49774] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0337|Stack trace:
0338|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0339|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0340|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0341|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0342|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0343|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0344|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0345|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0346|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0347|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0348|[Tue Sep 05 04:42:02.836563 2023] [php7:error] [pid 19800] [client 127.0.0.1:49776] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
0349|Stack trace:
0350|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b9f2febdc651f3e', Array)
0351|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0352|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0353|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0354|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0355|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0356|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0357|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0358|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0359|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/va in /var/www/html/core/class/DB.class.php on line 40
0360|[Wed Jan 17 08:59:07.303322 2024] [access_compat:error] [pid 13223] [client 92.171.144.236:0] AH01797: client denied by server configuration: /var/www/html/&rescue=1
[http.error_2.txt|attachment](upload://1YMzk8XrCuLA3do4TMsGKZIxOIm.txt) (34,5 Ko)
sur un jeedom raspberry PI3
http.error_2.txt (34,5 Ko)
sur un jeedom ATLASPRO
http.error_1.txt (4,7 Mo)
@Madcow a bien écrit « à la fin de l’url », pas « remplacer l’url » donc ajouter juste ca à la fin sans rien supprimer
j’ai bien mis &rescue=1 à la fin de mon url
et je fourni le log de http.error
https://MONJEEDOM.eu.jeedom.link/index.php?v=d&p=log&rescue=1
ou
http://MONIP/index.php?v=d&p=log&rescue=1
c’est bizarre, c’est pas ce que dit le log
et du coup vous arrivez sur l’interface rescue ou pas?
Pour qu’on y voit plus clair:
- effacer le log http.error
- dans un autre onglet retourner sur l’interface jeedom « normal », vous aurez l’erreur 500 et la page blanche
- donnez-nous le nouveau log
ainsi on n’aura que les lignes liées à ce problème
dans le log enocean j’ai ceci
[2024-01-17 01:25:04.208][ERROR] : Error on send request to jeedom HTTPConnectionPool(host=‹ 127.0.0.1 ›, port=80): Read timed out. (read timeout=120) retry : 1/3
le log http.error reste vide
voici celui du modbus => c’est lié a ce problème mais du coup je ne l’avais pas vu avant et ce matin j’ai fait la derniere mise à jour du coup c’est ce qui a fait planté.
modbus1.txt (35,3 Ko)
DEBUG:pymodbus.payload:[7064]
DEBUG:pymodbus.transaction:Current transaction state - TRANSACTION_COMPLETE
DEBUG:pymodbus.transaction:Running transaction 2
DEBUG:pymodbus.transaction:SEND: 0x0 0x2 0x0 0x0 0x0 0x6 0x2 0x3 0x3 0x9 0x0 0x1
DEBUG:pymodbus.client.sync:New Transaction state 'SENDING'
DEBUG:pymodbus.transaction:Changing transaction state from 'SENDING' to 'WAITING FOR REPLY'
DEBUG:pymodbus.transaction:Changing transaction state from 'WAITING FOR REPLY' to 'PROCESSING REPLY'
DEBUG:pymodbus.transaction:RECV: 0x0 0x2 0x0 0x0 0x0 0x5 0x2 0x3 0x2 0x0 0x1
DEBUG:pymodbus.framer.socket_framer:Processing: 0x0 0x2 0x0 0x0 0x0 0x5 0x2 0x3 0x2 0x0 0x1
DEBUG:pymodbus.factory:Factory Response[ReadHoldingRegistersResponse: 3]
DEBUG:pymodbus.transaction:Adding transaction 2
DEBUG:pymodbus.transaction:Getting transaction 2
DEBUG:pymodbus.transaction:Changing transaction state from 'PROCESSING REPLY' to 'TRANSACTION_COMPLETE'
DEBUG:pymodbus.payload:[1]
DEBUG:pymodbus.transaction:Running transaction 3
DEBUG:pymodbus.transaction:SEND: 0x0 0x3 0x0 0x0 0x0 0x6 0x2 0x3 0x3 0x15 0x0 0x1
DEBUG:pymodbus.transaction:RECV: 0x0 0x3 0x0 0x0 0x0 0x5 0x2 0x3 0x2 0x0 0x2e
DEBUG:pymodbus.framer.socket_framer:Processing: 0x0 0x3 0x0 0x0 0x0 0x5 0x2 0x3 0x2 0x0 0x2e
DEBUG:pymodbus.transaction:Adding transaction 3
DEBUG:pymodbus.transaction:Getting transaction 3
DEBUG:pymodbus.payload:[46]
[2024-01-16 09:03:06][ERROR] : Attention : l'installation des dépendances a dépassé le temps maximum autorisé : 0min
[2024-01-17 03:05:14][ERROR] : Attention : l'installation des dépendances a dépassé le temps maximum autorisé : 0min
étrange s’il y a erreur 500 il devrait y avoir un log, sans log on ne sait rien faire.
concernant modbus, faudrait le coller dans un Texte préformaté svp.
C’est lié a ce problème (mise à jour plugin modbus) mais du coup je ne l’avais pas vu avant et ce matin j’ai fait la derniere mise à jour du coup c’est ce qui a fait planté.
Les log http.error sont bien vide
est ce que ca peut etre lié au fichier .htaccess ?
non cette mise à jour ne peut pas faire planter complétement jeedom, ce n’est pas ca
cette mise à jour fait que le plugin ne peut plus démarrer sur buster (apparemment) mais c’est tout
mais si vous n’avez plus d’espace disque par exemple, alors la mise à jour a pu corrompre l’ensemble, mais c’est différent, ce n’est pas la mise à jour en soi
c’est bizar que sur 2 jeedoms différents , il y ait le même problème qd même en ayant effectué la même mise à jour.
2 jeedoms différents pas sur le même réseau et pas la même configuration (1 sur Raspberry PI3 et l’autre sur une Atlas PRO) => plugin MOdbus actif.
sur un troisième j’ai fait la mise à jour mais comme le plugin Modbus est desactivé j’ai pas ce soucis.
D’ailleurs je vais l’activer pour voir ce que ca fait
BINGO, j’ai activé le plugin MODBUS me voilà avec une page blanche
rescue log
http.error
warning: commands will be executed using /bin/sh
job 13 at Wed Jan 17 11:42:00 2024
log Modbus_Package
+ touch /tmp/jeedom_install_in_progress_modbus
+ echo 1
+ echo 2
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ sudo pip3 cache purge
Files removed: 96
+ echo 4
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (22.1.2)
Collecting pip
Downloading pip-23.3.2-py3-none-any.whl (2.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 20.3 MB/s eta 0:00:00
Installing collected packages: pip
Attempting uninstall: pip
Found existing installation: pip 22.1.2
Uninstalling pip-22.1.2:
Successfully uninstalled pip-22.1.2
Successfully installed pip-23.3.2
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 5
+ sudo pip3 install --force-reinstall --upgrade pyudev
Collecting pyudev
Downloading pyudev-0.24.1-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.9/62.9 kB 2.8 MB/s eta 0:00:00
Installing collected packages: pyudev
Attempting uninstall: pyudev
Found existing installation: pyudev 0.21.0
Uninstalling pyudev-0.21.0:
Successfully uninstalled pyudev-0.21.0
Successfully installed pyudev-0.24.1
+ echo 6
+ sudo pip3 install --force-reinstall --upgrade requests
Collecting requests
Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
Collecting charset-normalizer<4,>=2 (from requests)
Downloading charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (33 kB)
Collecting idna<4,>=2.5 (from requests)
Downloading idna-3.6-py3-none-any.whl.metadata (9.9 kB)
Collecting urllib3<3,>=1.21.1 (from requests)
Downloading urllib3-2.0.7-py3-none-any.whl.metadata (6.6 kB)
Collecting certifi>=2017.4.17 (from requests)
Downloading certifi-2023.11.17-py3-none-any.whl.metadata (2.2 kB)
Downloading requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 6.2 MB/s eta 0:00:00
Downloading certifi-2023.11.17-py3-none-any.whl (162 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 162.5/162.5 kB 12.8 MB/s eta 0:00:00
Downloading charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (133 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 133.7/133.7 kB 7.3 MB/s eta 0:00:00
Downloading idna-3.6-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.6/61.6 kB 6.1 MB/s eta 0:00:00
Downloading urllib3-2.0.7-py3-none-any.whl (124 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 124.2/124.2 kB 11.7 MB/s eta 0:00:00
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 1.24.1
Uninstalling urllib3-1.24.1:
Successfully uninstalled urllib3-1.24.1
Attempting uninstall: idna
Found existing installation: idna 2.6
Uninstalling idna-2.6:
Successfully uninstalled idna-2.6
Attempting uninstall: certifi
Found existing installation: certifi 2018.8.24
Uninstalling certifi-2018.8.24:
Successfully uninstalled certifi-2018.8.24
Attempting uninstall: requests
Found existing installation: requests 2.21.0
Uninstalling requests-2.21.0:
Successfully uninstalled requests-2.21.0
Successfully installed certifi-2023.11.17 charset-normalizer-3.3.2 idna-3.6 requests-2.31.0 urllib3-2.0.7
+ echo 7
+ sudo pip3 install --force-reinstall --upgrade setuptools
Collecting setuptools
Downloading setuptools-68.0.0-py3-none-any.whl.metadata (6.4 kB)
Downloading setuptools-68.0.0-py3-none-any.whl (804 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 804.0/804.0 kB 13.9 MB/s eta 0:00:00
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 40.8.0
Uninstalling setuptools-40.8.0:
Successfully uninstalled setuptools-40.8.0
Successfully installed setuptools-68.0.0
+ echo 8
+ sudo pip3 install --force-reinstall --upgrade wheel
Collecting wheel
Downloading wheel-0.42.0-py3-none-any.whl.metadata (2.2 kB)
Downloading wheel-0.42.0-py3-none-any.whl (65 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 65.4/65.4 kB 4.2 MB/s eta 0:00:00
Installing collected packages: wheel
Attempting uninstall: wheel
Found existing installation: wheel 0.37.1
Uninstalling wheel-0.37.1:
Successfully uninstalled wheel-0.37.1
Successfully installed wheel-0.42.0
+ echo 9
+ sudo pip3 install --force-reinstall --upgrade pyserial
Collecting pyserial
Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 90.6/90.6 kB 4.6 MB/s eta 0:00:00
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.4
Uninstalling pyserial-3.4:
Successfully uninstalled pyserial-3.4
Successfully installed pyserial-3.5
+ echo 10
+ sudo pip3 install --force-reinstall --upgrade pymodbus==3.2.2
ERROR: Ignored the following versions that require a different python version: 3.0.0 Requires-Python >=3.8.0; 3.0.0.dev4 Requires-Python >=3.8.0; 3.0.0.dev5 Requires-Python >=3.8.0; 3.0.0rc1 Requires-Python >=3.8.0; 3.0.1 Requires-Python >=3.8.0; 3.0.2 Requires-Python >=3.8.0; 3.1.0 Requires-Python >=3.8.0; 3.1.1 Requires-Python >=3.8.0; 3.1.2 Requires-Python >=3.8.0; 3.1.3 Requires-Python >=3.8.0; 3.2.0 Requires-Python >=3.8.0; 3.2.1 Requires-Python >=3.8.0; 3.2.2 Requires-Python >=3.8.0; 3.3.0 Requires-Python >=3.8.0; 3.3.1 Requires-Python >=3.8.0; 3.3.2 Requires-Python >=3.8.0; 3.4.0 Requires-Python >=3.8.0; 3.4.1 Requires-Python >=3.8.0; 3.5.0 Requires-Python >=3.8.0; 3.5.1 Requires-Python >=3.8.0; 3.5.2 Requires-Python >=3.8.0; 3.5.3 Requires-Python >=3.8.0; 3.5.4 Requires-Python >=3.8.0; 3.6.1 Requires-Python >=3.8.0; 3.6.2 Requires-Python >=3.8.0; 3.6.3 Requires-Python >=3.8.0
ERROR: Could not find a version that satisfies the requirement pymodbus==3.2.2 (from versions: 0.9.0, 1.0.0, 1.1.0, 1.2.0, 1.3.0rc1, 1.3.0rc2, 1.3.1, 1.3.2, 1.4.0rc3, 1.4.0, 1.5.0, 1.5.1, 1.5.2, 2.0.0, 2.0.1, 2.1.0, 2.2.0rc1, 2.2.0rc2, 2.2.0rc3, 2.2.0rc4, 2.2.0, 2.3.0rc1, 2.3.0, 2.4.0rc1, 2.4.0, 2.5.0rc1, 2.5.0rc2, 2.5.0, 2.5.1rc1, 2.5.1, 2.5.2, 2.5.3rc1, 2.5.3, 3.0.0.dev2, 3.0.0.dev3)
ERROR: No matching distribution found for pymodbus==3.2.2
+ echo 11
+ sudo pip3 install --force-reinstall --upgrade bitstring
Collecting bitstring
Downloading bitstring-4.1.4-py3-none-any.whl.metadata (5.8 kB)
Collecting bitarray<3.0.0,>=2.8.0 (from bitstring)
Downloading bitarray-2.9.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (34 kB)
Downloading bitstring-4.1.4-py3-none-any.whl (60 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.0/61.0 kB 5.6 MB/s eta 0:00:00
Downloading bitarray-2.9.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (279 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 279.9/279.9 kB 15.7 MB/s eta 0:00:00
Installing collected packages: bitarray, bitstring
Successfully installed bitarray-2.9.2 bitstring-4.1.4
+ echo 12
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end modbus
+ rm /tmp/jeedom_install_in_progress_modbus
ok faites un ticket au support là, ils ont cassé quelque chose sur la version stable au lieu de le faire en beta, je ne comprend pas ce qui a été fait.
pour vous débloquer, en mode rescue, supprimez le dossier du plugin
je vais faire une restauration
J’ai fait une demande support ce matin.
