Bonjour, je suis sous jeedom 4.0.52 avec une jeedom pro, il m’est impossible d’installer les dépendances avec homebridge.
Dans les logs jai cette erreure:
== KO == Erreur d’Installation
== Erreur à l’étape : Installation de npm car non présent
== Ligne 155
== La commande `sudo DEBIAN_FRONTEND=noninteractive apt-get install -y npm’ pose problème
== Le code de retour est 100
== Le message d’erreur :
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
npm : Depends: nodejs (>= 6.11~) but 4.8.2~dfsg-1 is to be installed
Depends: node-abbrev (>= 1.1.1~) but 1.0.9-1 is to be installed
Depends: node-ansi-regex (>= 3.0~) but 2.0.0-1 is to be installed
Depends: node-cacache (>= 10.0.4~) but it is not going to be installed
Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed
Depends: node-glob (>= 7.1.2~) but 7.1.1-1 is to be installed
Depends: node-hosted-git-info (>= 2.6~) but 2.1.5-1 is to be installed
Depends: node-ini (>= 1.3.5~) but 1.1.0-1 is to be installed
Depends: node-npm-package-arg but it is not going to be installed
Depends: node-jsonstream (>= 1.3.2~) but 1.0.3-4 is to be installed
Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed
Depends: node-lockfile (>= 1.0.3~) but 0.4.1-1 is to be installed
Depends: node-lru-cache (>= 4.1.1~) but 4.0.2-1 is to be installed
Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed
Depends: node-normalize-package-data (>= 2.4~) but 2.3.5-2 is to be installed
Depends: node-gyp (>= 3.6.2~) but it is not going to be installed
Depends: node-resolve-from (>= 4.0~) but 2.0.0-1 is to be installed
Depends: node-npmlog (>= 4.1.2~) but 0.0.4-1 is to be installed
Depends: node-osenv (>= 0.1.5~) but 0.1.0-1 is to be installed
Depends: node-read-package-json (>= 2.0.13~) but 1.2.4-1 is to be installed
Depends: node-request (>= 2.83~) but 2.26.1-1 is to be installed
Depends: node-retry (>= 0.10.1~) but 0.6.0-1 is to be installed
Depends: node-rimraf (>= 2.6.2~) but 2.5.4-2 is to be installed
Depends: node-semver (>= 5.5~) but 5.3.0-1 is to be installed
Depends: node-sha (>= 2.0.1~) but 1.2.3-1 is to be installed
Depends: node-slide (>= 1.1.6~) but 1.1.4-1 is to be installed
Depends: node-strip-ansi (>= 4.0~) but 3.0.1-1 is to be installed
Depends: node-tar (>= 4.4~) but 2.2.1-1 is to be installed
Depends: node-boxen (>= 1.2.1~) but it is not going to be installed
Depends: node-latest-version (>= 3.0~) but it is not going to be installed
Depends: node-which (>= 1.3~) but 1.2.11-1 is to be installed
E: Unable to correct problems, you have held broken packages.
== Ligne 156
== La commande `sudo npm install -g npm’ pose problème
sudo: npm: command not found
== Erreur à l’étape : Installation de Homebridge master, veuillez patienter svp
== Ligne 193
== La commande `sudo npm install --no-fund --no-package-lock --no-audit’ pose problème
Si vous avez une solution je suis preneur
