Hi everyone,
I’m trying to integrate my Nuki Smart Lock Pro 4 (no Bridge) with Jeedom using the Nuki plugin, but I’m running into issues with the Local HTTP API setup.
Here’s what I’ve done so far:
- I installed the official Nuki plugin in Jeedom.
- Since I have a Smart Lock Pro 4, I don’t use a Nuki Bridge (the lock has built-in Wi-Fi).
- I configured the IP address of the lock in the plugin settings.
- For the token, I initially tried using the Web API token from web.nuki.io, but the plugin cannot connect (which makes sense now that I realize it uses the local API).
My problem is:
I can’t find the setting to enable the Local HTTP API in the Nuki app.
In the Nuki app (latest version), I go to:
Settings→Features & Configuration
But there’s no option to enable Local API or HTTP API anywhere. No « Integrations », no « Local API » menu.
I’ve confirmed that:
- I’m the owner/admin of the lock.
- The firmware is updated.
- The lock is connected via Wi-Fi and in the same network as Jeedom.
- I’m using the latest version of the app.
I’ve read that the Local API should be available for the Smart Lock Pro 4 (4th gen), but it seems to be missing or hidden in my case.
My questions:
- Has anyone managed to make Jeedom work with the Smart Lock Pro 4 without a Bridge, using Local HTTP API?
- Where exactly do you enable the Local HTTP API in the app?
- Is this feature being rolled out gradually, or are there limitations by region/user?
- If not possible via Local API, does the plugin support Nuki Web API as a fallback?
Thanks a lot in advance for any help or hints!
Información Jeedom Luna
Core : 4.4.19 (master)
DNS Jeedom Luna : Sí
Plugin : Nuki
Versión : 2025-02-19 01:22:08 (stable)
