Suite à la mise à jour GSH ne fonctionne plus
Le démon ne se relançait pas … constaté dans les logs, j’ai donc réinstallé le plugin + reboot.
Actuellement :
- mes lampes s’éteignent bien par l’interface graphique >> EIBD ok
- lorsque je demande d’étéindre les lumières du salon :
=> je voie dans les logs
* « Ok, j’allume les lumières du salon »
[2020-07-17 12:19:00][DEBUG] : XX.XX.XX.XX => {"action":"exec","apikey":"...........................","data":{"callback":null,"auth":null,"requestId":"1912146884338858593","commands":[{"devices":[{"customData":{"cmd_get_brightness":"102","cmd_get_state":"102","cmd_set_slider":"101","local_execution::apikey":"........................................"},"id":"23"},{"customData":{"cmd_get_brightness":"130","cmd_get_state":"130","cmd_set_slider":"129","local_execution::apikey":"........................................"},"id":"28"},{"customData":{"cmd_get_brightness":"126","cmd_get_state":"126","cmd_set_slider":"125","local_execution::apikey":"........................................"},"id":"27"},{"customData":{"cmd_get_brightness":"86","cmd_get_state":"86","cmd_set_off":"89","cmd_set_on":"88","local_execution::apikey":"........................................"},"id":"21"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":true}}]}]}}
[2020-07-17 12:19:00][DEBUG] : Request : {"action":"exec","apikey":"........................................","data":{"callback":null,"auth":null,"requestId":"1912146884338858593","commands":[{"devices":[{"customData":{"cmd_get_brightness":"102","cmd_get_state":"102","cmd_set_slider":"101","local_execution::apikey":"........................................"},"id":"23"},{"customData":{"cmd_get_brightness":"130","cmd_get_state":"130","cmd_set_slider":"129","local_execution::apikey":"........................................"},"id":"28"},{"customData":{"cmd_get_brightness":"126","cmd_get_state":"126","cmd_set_slider":"125","local_execution::apikey":"........................................"},"id":"27"},{"customData":{"cmd_get_brightness":"86","cmd_get_state":"86","cmd_set_off":"89","cmd_set_on":"88","local_execution::apikey":"........................................"},"id":"21"}],"execution":[{"command":"action.devices.commands.OnOff","params":{"on":true}}]}]}}
[2020-07-17 12:19:00][DEBUG] : Exec result : {"commands":[{"ids":["23"]},{"ids":["28"]},{"ids":["27"]},{"ids":["21"]}]}
[2020-07-17 12:19:01][DEBUG] : XX.XX.XX.XX => {"callback":null,"auth":null,"requestId":"11321865802284439539","devices":[{"customData":{"cmd_get_brightness":"130","cmd_get_state":"130","cmd_set_slider":"129","local_execution::apikey":"........................................"},"id":"28"},{"customData":{"cmd_get_brightness":"102","cmd_get_state":"102","cmd_set_slider":"101","local_execution::apikey":"........................................"},"id":"23"},{"customData":{"cmd_get_brightness":"126","cmd_get_state":"126","cmd_set_slider":"125","local_execution::apikey":"........................................"},"id":"27"},{"customData":{"cmd_get_brightness":"130","cmd_get_state":"130","cmd_set_slider":"129","local_execution::apikey":"........................................"},"id":"28"},{"customData":{"cmd_get_brightness":"102","cmd_get_state":"102","cmd_set_slider":"101","local_execution::apikey":"........................................"},"id":"23"},{"customData":{"cmd_get_brightness":"126","cmd_get_state":"126","cmd_set_slider":"125","local_execution::apikey":"........................................"},"id":"27"},{"customData":{"cmd_get_brightness":"86","cmd_get_state":"86","cmd_set_off":"89","cmd_set_on":"88","local_execution::apikey":"........................................"},"id":"21"}],"action":"query","apikey":"........................................"}
[2020-07-17 12:19:01][DEBUG] : Request : {"callback":null,"auth":null,"requestId":"11321865802284439539","devices":[{"customData":{"cmd_get_brightness":"130","cmd_get_state":"130","cmd_set_slider":"129","local_execution::apikey":"........................................"},"id":"28"},{"customData":{"cmd_get_brightness":"102","cmd_get_state":"102","cmd_set_slider":"101","local_execution::apikey":"........................................"},"id":"23"},{"customData":{"cmd_get_brightness":"126","cmd_get_state":"126","cmd_set_slider":"125","local_execution::apikey":"........................................"},"id":"27"},{"customData":{"cmd_get_brightness":"130","cmd_get_state":"130","cmd_set_slider":"129","local_execution::apikey":"........................................"},"id":"28"},{"customData":{"cmd_get_brightness":"102","cmd_get_state":"102","cmd_set_slider":"101","local_execution::apikey":"........................................"},"id":"23"},{"customData":{"cmd_get_brightness":"126","cmd_get_state":"126","cmd_set_slider":"125","local_execution::apikey":"........................................"},"id":"27"},{"customData":{"cmd_get_brightness":"86","cmd_get_state":"86","cmd_set_off":"89","cmd_set_on":"88","local_execution::apikey":"........................................"},"id":"21"}],"action":"query","apikey":"........................................"}
[2020-07-17 12:19:01][DEBUG] : Query result : {"devices":{"28":[],"23":[],"27":[],"21":[]}}
Une idée de l’origine du problème ?
