[2020-01-03 16:27:22][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:27:22][INFO] : Process stopped !
[2020-01-03 16:27:25][INFO] : Lancement démon googlecast : /usr/bin/python3 /var/www/html/plugins/googlecast/resources/googlecast.py --loglevel debug --socketport 55012 --sockethost 127.0.0.1 --callback http://127.0.0.1:80/plugins/googlecast/core/php/googlecast.api.php --apikey cxxxxxxxxxxxxxxxxxxxxxxxxxx --ttsweb http://192.xxxxx --ttslang fr-FR --ttsengine picotts --ttsspeed 1.2 --ttscache 1 --ttsgapikey none --daemonname local --cyclefactor 1 --defaultstatus ' '
[2020-01-03 16:27:28][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:27:28][INFO] : Process started. Sending known devices now...
[2020-01-03 16:27:41][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:28:42][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:34:58][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:42:30][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:50:01][DEBUG] : This is a message from googlecast program local
[2020-01-03 16:57:33][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:05:04][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:12:36][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:20:07][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:27:39][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:35:10][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:42:42][DEBUG] : This is a message from googlecast program local
[2020-01-03 17:50:15][DEBUG] : This is a message from googlecast program local
2020-01-03 22:00:00][DEBUG] : SCANNER------ No need to scan network, all devices are present
[2020-01-03 22:01:02][DEBUG] : SCANNER------ Start scanning...
[2020-01-03 22:01:02][DEBUG] : MEMORY---- Total CPU time used : 69.221s (0.35%) | Last 62 sec : 0.204s (0.33%) | Memory : 25 Mo
[2020-01-03 22:01:02][DEBUG] : SCANNER------ No need to scan network, all devices are present
[2020-01-03 22:02:04][DEBUG] : SCANNER------ Start scanning...
[2020-01-03 22:02:04][DEBUG] : MEMORY---- Total CPU time used : 69.426s (0.35%) | Last 62 sec : 0.205s (0.33%) | Memory : 25 Mo
[2020-01-03 22:02:04][DEBUG] : SCANNER------ No need to scan network, all devices are present
[2020-01-03 22:02:27][DEBUG] : GLOBAL------Signal 15 caught, exiting...
[2020-01-03 22:02:27][DEBUG] : GLOBAL------Shutdown
[2020-01-03 22:02:27][DEBUG] : GLOBAL------Removing PID file /tmp/googlecast.pid
[2020-01-03 22:02:27][DEBUG] : SENDER------Send to jeedom : {'source': 'local', 'stopped': 1}
[2020-01-03 22:02:27][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-01-03 22:02:27][DEBUG] : http://127.0.0.1:80 "POST /plugins/googlecast/core/php/googlecast.api.php?apikey=Xxxxxxx
Est ce que cette solution est valable pour mon log
sudo pip3 install zeroconf==0.24.3
J’ai croisé d’autres posts avec le même soucis (problème de scan) et apparemment il y aurait un soucis de compatibilité avec une version de zeroconf
ici
et ici
la solution a été de faire pip3 install zeroconf==0.24.3
Ah dis donc, il m’a fallu attendre un peu après l’installation.
tout est apparu c’est bon !
Je vais pouvoir m’amuser Youhouuuuuuu !
Merci pour votre aide.
