Dans ma longue quête du Google Home qui cause, j’essaye à présent avec le plugin GoogleCast. Cependant, impossible de finir l’installation des dépendances…
Log de l’exécution:
E: Failed to fetch http://ftp.debian.org/debian/pool/main/libt/libtool/libltdl7_2.4.2-1.11_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/o/opencore-amr/libopencore-amrnb0_0.1.3-2.1_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/o/opencore-amr/libopencore-amrwb0_0.1.3-2.1_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/s/sox/libsox2_14.4.1-5_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/libv/libvorbis/libvorbisenc2_1.3.4-2+deb8u1_arm64.deb 404 Not Found [IP: 151.101.64.204 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/libv/libvorbis/libvorbis0a_1.3.4-2+deb8u1_arm64.deb 404 Not Found [IP: 151.101.64.204 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/libv/libvorbis/libvorbisfile3_1.3.4-2+deb8u1_arm64.deb 404 Not Found [IP: 151.101.64.204 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/w/wavpack/libwavpack1_4.70.0-1_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/s/sox/libsox-fmt-alsa_14.4.1-5_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/s/sox/libsox-fmt-base_14.4.1-5_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
E: Failed to fetch http://ftp.debian.org/debian/pool/main/s/sox/sox_14.4.1-5_arm64.deb 404 Not Found [IP: 130.89.148.12 80]
python3-chardet python3-colorama python3-distlib python3-html5lib
python3-pip python3-pkg-resources python3-requests python3-setuptools
python3-six python3-urllib3
0 upgraded, 10 newly installed, 0 to remove and 192 not upgraded.
Need to get 514 kB/916 kB of archives.
After this operation, 4,313 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
python3-pkg-resources python3-six python3-urllib3 python3-requests
python3-setuptools
E: There are problems and -y was used without --force-yes
Error: Cound not found pip3 program to install python dependencies ! Check doc FAQ for possible resolution.
Un problème avec l’adresse des repositories utilisées ?
Merci d’avance !
