Google cast sur docker
bonjour,
j’ai installé un jeedom sous docker sur un systeme debian et je n’arrive pas a detecter mon google home avec le scan. J’ai un autre jeedom sans docker qui n’a pas de probleme.
Est ce un probleme de reseau ?
L’adresse de jeedom est de type 172.17.x.x alors que celle de mon reseau local est de type 192.168.68.x.
Comment peut on resoudre ce probleme ?
lorsque je lance le deamon en mode debug j’ai le log suivant dans google_cast local :
[2022-02-14 07:28:38]DEBUG : SOCKETHANDLER------Client connected to [127.0.0.1:50896]
[2022-02-14 07:28:38]DEBUG : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "learnout"}
[2022-02-14 07:28:38]DEBUG : SOCKETHANDLER------Client disconnected from [127.0.0.1:50896]
[2022-02-14 07:28:39]DEBUG : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-14 07:28:39]DEBUG : SOCKET-READ------Received command from jeedom : learnout
[2022-02-14 07:28:39]INFO : SOCKET-READ------Leave learn mode
[2022-02-14 07:28:39]DEBUG : SENDER------Send to jeedom :  {'learn_mode': 0, 'source': 'local'}
[2022-02-14 07:28:43]DEBUG : SOCKETHANDLER------Client connected to [127.0.0.1:50900]
[2022-02-14 07:28:43]DEBUG : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "learnout"}
[2022-02-14 07:28:43]DEBUG : SOCKETHANDLER------Client disconnected from [127.0.0.1:50900]
[2022-02-14 07:28:43]DEBUG : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-14 07:28:43]DEBUG : SOCKET-READ------Received command from jeedom : learnout
[2022-02-14 07:28:43]INFO : SOCKET-READ------Leave learn mode
[2022-02-14 07:28:43]DEBUG : SENDER------Send to jeedom :  {'learn_mode': 0, 'source': 'local'}
[2022-02-14 07:29:12]DEBUG : SCANNER------ Start scanning... (schedule)
[2022-02-14 07:29:12]DEBUG :  MEMORY---- Total CPU time used : 1.308s (0.33%)  |  Last 62 sec : 0.146s (0.23%)  | Memory : 36 Mo
lorsque je lance un scan ca ajoute au log :
[2022-02-14 07:32:56]DEBUG : SOCKETHANDLER------Client connected to [127.0.0.1:50932]
[2022-02-14 07:32:56]DEBUG : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "learnout"}
[2022-02-14 07:32:56]DEBUG : SOCKETHANDLER------Client disconnected from [127.0.0.1:50932]
[2022-02-14 07:32:56]DEBUG : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-14 07:32:56]DEBUG : SOCKET-READ------Received command from jeedom : learnout
[2022-02-14 07:32:56]INFO : SOCKET-READ------Leave learn mode
[2022-02-14 07:32:56]DEBUG : SENDER------Send to jeedom :  {'learn_mode': 0, 'source': 'local'}
[2022-02-14 07:33:44]DEBUG : SOCKETHANDLER------Client connected to [127.0.0.1:50936]
[2022-02-14 07:33:44]DEBUG : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "learnin"}
[2022-02-14 07:33:44]DEBUG : SOCKETHANDLER------Client disconnected from [127.0.0.1:50936]
[2022-02-14 07:33:44]DEBUG : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-14 07:33:44]DEBUG : SOCKET-READ------Received command from jeedom : learnin
[2022-02-14 07:33:44]INFO : SOCKET-READ------Enter in learn mode
[2022-02-14 07:33:44]DEBUG : SENDER------Send to jeedom :  {'learn_mode': 1, 'source': 'local'}
[2022-02-14 07:33:46]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:46]DEBUG :  MEMORY---- Total CPU time used : 0.795s (0.46%)  |  Last 50 sec : 0.124s (0.25%)  | Memory : 36 Mo
[2022-02-14 07:33:46]DEBUG : ZEROCONF------ Stopping zeroconf monitoring thread...
[2022-02-14 07:33:46]DEBUG : ZEROCONF------ Start zeroconf monitoring thread...
[2022-02-14 07:33:46]DEBUG : Using selector: EpollSelector
[2022-02-14 07:33:48]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:48]DEBUG :  MEMORY---- Total CPU time used : 0.813s (0.47%)  |  Last 2 sec : 0.018s (0.91%)  | Memory : 36 Mo
[2022-02-14 07:33:50]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:50]DEBUG :  MEMORY---- Total CPU time used : 0.820s (0.47%)  |  Last 2 sec : 0.007s (0.34%)  | Memory : 36 Mo
[2022-02-14 07:33:52]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:52]DEBUG :  MEMORY---- Total CPU time used : 0.825s (0.46%)  |  Last 2 sec : 0.005s (0.24%)  | Memory : 36 Mo
[2022-02-14 07:33:54]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:54]DEBUG :  MEMORY---- Total CPU time used : 0.831s (0.46%)  |  Last 2 sec : 0.006s (0.32%)  | Memory : 36 Mo
[2022-02-14 07:33:56]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:56]DEBUG :  MEMORY---- Total CPU time used : 0.836s (0.46%)  |  Last 2 sec : 0.005s (0.26%)  | Memory : 36 Mo
[2022-02-14 07:33:58]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:33:58]DEBUG :  MEMORY---- Total CPU time used : 0.842s (0.46%)  |  Last 2 sec : 0.006s (0.28%)  | Memory : 36 Mo
[2022-02-14 07:34:00]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:00]DEBUG :  MEMORY---- Total CPU time used : 0.847s (0.46%)  |  Last 2 sec : 0.005s (0.25%)  | Memory : 36 Mo
[2022-02-14 07:34:02]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:02]DEBUG :  MEMORY---- Total CPU time used : 0.852s (0.45%)  |  Last 2 sec : 0.006s (0.28%)  | Memory : 36 Mo
[2022-02-14 07:34:04]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:04]DEBUG :  MEMORY---- Total CPU time used : 0.857s (0.45%)  |  Last 2 sec : 0.005s (0.25%)  | Memory : 36 Mo
[2022-02-14 07:34:06]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:06]DEBUG :  MEMORY---- Total CPU time used : 0.863s (0.45%)  |  Last 2 sec : 0.005s (0.26%)  | Memory : 36 Mo
[2022-02-14 07:34:08]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:08]DEBUG :  MEMORY---- Total CPU time used : 0.868s (0.45%)  |  Last 2 sec : 0.005s (0.26%)  | Memory : 36 Mo
[2022-02-14 07:34:10]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:10]DEBUG :  MEMORY---- Total CPU time used : 0.873s (0.45%)  |  Last 2 sec : 0.005s (0.25%)  | Memory : 36 Mo
[2022-02-14 07:34:12]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:12]DEBUG :  MEMORY---- Total CPU time used : 0.878s (0.44%)  |  Last 2 sec : 0.005s (0.26%)  | Memory : 36 Mo
[2022-02-14 07:34:14]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:14]DEBUG :  MEMORY---- Total CPU time used : 0.883s (0.44%)  |  Last 2 sec : 0.005s (0.25%)  | Memory : 36 Mo
[2022-02-14 07:34:16]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:16]DEBUG :  MEMORY---- Total CPU time used : 0.889s (0.44%)  |  Last 2 sec : 0.006s (0.28%)  | Memory : 36 Mo
[2022-02-14 07:34:18]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:18]DEBUG :  MEMORY---- Total CPU time used : 0.895s (0.44%)  |  Last 2 sec : 0.007s (0.33%)  | Memory : 36 Mo
[2022-02-14 07:34:20]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:20]DEBUG :  MEMORY---- Total CPU time used : 0.900s (0.44%)  |  Last 2 sec : 0.005s (0.26%)  | Memory : 36 Mo
[2022-02-14 07:34:22]DEBUG : SOCKETHANDLER------Client connected to [127.0.0.1:50942]
[2022-02-14 07:34:22]DEBUG : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "learnout"}
[2022-02-14 07:34:22]DEBUG : SOCKETHANDLER------Client disconnected from [127.0.0.1:50942]
[2022-02-14 07:34:22]DEBUG : SCANNER------ Start scanning... (learnmode)
[2022-02-14 07:34:22]DEBUG :  MEMORY---- Total CPU time used : 0.907s (0.44%)  |  Last 2 sec : 0.007s (0.33%)  | Memory : 36 Mo
[2022-02-14 07:34:22]DEBUG : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2022-02-14 07:34:22]DEBUG : SOCKET-READ------Received command from jeedom : learnout
[2022-02-14 07:34:22]INFO : SOCKET-READ------Leave learn mode
[2022-02-14 07:34:22]DEBUG : SENDER------Send to jeedom :  {'learn_mode': 0, 'source': 'local'}
Le plug-in ne va scanner que le réseau local entre le container et son hôte, docker, et il ne va rien trouver puisqu’il n’y a rien à trouver évidemment.
Vous devez probablement configurer votre container autrement (network en mode hôte ou macvlan devrait fonctionner mais c’est hors sujet du plug-in)
Ou peut-être en configurant un équipement manuellement, j’ignore si cela fonctionne.
Hello
Pour t’aider au cas echéant
merci je vais tester ca ce soir et si c’est trop complique je vais basculer mon jeedom hors docker …
