Bonjour.
J’utilise depuis un bon moment le plugin Airzone d’origine sur jeedom. J’ai deux systemID car deux caissons gainables et tout fonctionne(ait) correctement.
Lorsque je veux ajouter un équipement j’ai bien systemID 1 et 2 et tous les équipement cf photo
Sur le nouveau plugin officiel si je ne me trompe pas je fais le get all zones/equipement et lorsque je veux creer l’equipement je n’ai qu’un systeme ID sur deux il manque tout le RDC sur le gainable du bas :
Pas de systemID 1
[2021-12-01 21:15:48][INFO] : DATA_ALL_SYSTEMS_ZONES: [{"data":[{"systemID":2,"zoneID":1,"name":"Appart","on":1,"maxTemp":30,"minTemp":15,"setpoint":18,"roomTemp":18.299999,"mode":3,"coldStages":1,"coldStage":1,"heatStages":1,"heatStage":1,"humidity":60,"units":0,"errors":[],"air_demand":0,"floor_demand":0},{"systemID":2,"zoneID":2,"name":"Chb Appart","on":1,"maxTemp":30,"minTemp":15,"setpoint":18,"roomTemp":18.299999,"mode":3,"coldStages":1,"coldStage":1,"heatStages":1,"heatStage":1,"humidity":47,"units":0,"errors":[],"air_demand":0,"floor_demand":0},{"systemID":2,"zoneID":3,"name":"Elona","on":1,"maxTemp":30,"minTemp":15,"setpoint":19,"roomTemp":20.700001,"mode":3,"coldStages":1,"coldStage":1,"heatStages":1,"heatStage":1,"humidity":44,"units":0,"errors":[],"air_demand":0,"floor_demand":0},{"systemID":2,"zoneID":4,"name":"Palier","on":1,"maxTemp":30,"minTemp":15,"setpoint":20,"roomTemp":20.5,"modes":[1,4,2,3,5],"mode":3,"coldStages":1,"coldStage":1,"heatStages":1,"heatStage":1,"humidity":41,"units":0,"errors":[],"air_demand":0,"floor_demand":0},{"systemID":2,"zoneID":5,"name":"Aedan","on":1,"maxTemp":30,"minTemp":15,"setpoint":19,"roomTemp":19.9,"mode":3,"coldStages":1,"coldStage":1,"heatStages":1,"heatStage":1,"humidity":54,"units":0,"errors":[],"air_demand":0,"floor_demand":0},{"systemID":2,"zoneID":6,"name":"ZONA 06","on":1,"maxTemp":30,"minTemp":15,"setpoint":20,"roomTemp":0,"mode":3,"coldStages":1,"coldStage":1,"heatStages":1,"heatStage":1,"humidity":0,"units":0,"errors":[],"air_demand":0,"floor_demand":0}]}]
Autre souci que j’ai avec l’un ou l’autre peu importe, au bout d’un certain temps, cela peut etre 24h ou quelques heures l’api coté webserver airzone cesse de répondre, tout du moins réponds cela :
Ancien plugin Airzone :
[2021-12-01 20:43:02][WARNING] : ERROR HTTP : 192.168.1.46, PORT : 3000, URL (http://192.168.1.46:3000/api/v1/hvac), POST, ERROR (500)
[2021-12-01 20:43:02][DEBUG] : BEGIN executeCommand / tipo: info; sistema :1; zona :5; parametro :roomTemp; valor :
[2021-12-01 20:43:02][DEBUG] : CONNECTED, SENDING COMMAND (IP : 192.168.1.46, PORT : 3000), URL (http://192.168.1.46:3000/api/v1/hvac), POST
[2021-12-01 20:43:02][DEBUG] : Return reponse (500)
[2021-12-01 20:43:02][DEBUG] : CLOSING CONNECTION
Nouveau :
errors":[{"error":"Method not provided or not supported
Le seul moyen de revenir fonctionnel est de faire un hard reboot du webserver Airzone.
Je suis en version 3.36 niveau firmware Airzone et lorsque j’ai cette erreur l’appli web Airzone continue de bien fonctionner de son côté.
Merci d’avance si vous avez des solutions de vote côté ou les mêmes soucis.
Florian.
