Merci pour ton aide.
Histoire d’etre le plus propre possible, je viens de réinstaller les plugins + mise à jour des dépendances de PlayTTS.
Début de l'installation
Installation mplayer
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (11.1.0+rpi1).
mpg123 is already the newest version (1.26.4-1).
mplayer is already the newest version (2:1.4+ds1-1).
software-properties-common is already the newest version (0.96.20.2-2.1).
The following packages were automatically installed and are no longer required:
docutils-common mypy pylint python3-astroid python3-asttokens
python3-docutils python3-isort python3-jedi python3-lazy-object-proxy
python3-logilab-common python3-mccabe python3-mypy python3-mypy-extensions
python3-parso python3-pygments python3-roman python3-send2trash python3-toml
python3-typed-ast python3-typing-extensions python3-wrapt sgml-base xml-core
xsel
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 68 not upgraded.
Installation PicoTTS
libsox-fmt-mp3 is already the newest version (14.4.2+git20190427-2).
sox is already the newest version (14.4.2+git20190427-2).
xsel
(Reading database ... 116728 files and directories currently installed.)
Preparing to unpack libttspico-data_1.0+git20130326-3_all.deb ...
Unpacking libttspico-data (1.0+git20130326-3) over (1.0+git20130326-3) ...
Setting up libttspico-data (1.0+git20130326-3) ...
dpkg: warning: downgrading libttspico0:armhf from 1.0+git20130326-9 to 1.0+git20130326-3
dpkg: regarding libttspico0_1.0+git20130326-3_armhf.deb containing libttspico0:armhf, pre-dependency problem:
libttspico0:armhf pre-depends on multiarch-support
multiarch-support is not installed.
dpkg: error processing archive libttspico0_1.0+git20130326-3_armhf.deb (--install):
pre-dependency problem - not installing libttspico0:armhf
Errors were encountered while processing:
dpkg: warning: downgrading libttspico-utils from 1.0+git20130326-9 to 1.0+git20130326-3
Preparing to unpack libttspico-utils_1.0+git20130326-3_armhf.deb ...
Unpacking libttspico-utils (1.0+git20130326-3) over (1.0+git20130326-9) ...
Setting up libttspico-utils (1.0+git20130326-3) ...
Processing triggers for man-db (2.9.4-2) ...
Ajout de www-data dans le groupe audio
Fin de l'installation
Une erreur sur les logs d’installation de PlayTTS. J’installe donc les paquets sans multiarch-support.
raspberrypi:/home/pi# sudo dpkg --ignore-depends=multiarch-support -i ./libttspico0_1.0+git20130326-9_armhf.deb
(Lecture de la base de données... 116728 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../libttspico0_1.0+git20130326-9_armhf.deb ...
Dépaquetage de libttspico0:armhf (1.0+git20130326-9) sur (1.0+git20130326-9) ...
Paramétrage de libttspico0:armhf (1.0+git20130326-9) ...
Traitement des actions différées (« triggers ») pour libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
raspberrypi:/home/pi# sudo dpkg --ignore-depends=multiarch-support -i ./libttspico-data_1.0+git20130326-12_all.deb
Préparation du dépaquetage de .../libttspico-data_1.0+git20130326-12_all.deb ...
Dépaquetage de libttspico-data (1.0+git20130326-12) sur (1.0+git20130326-3) ...
Paramétrage de libttspico-data (1.0+git20130326-12) ...
raspberrypi:/home/pi# sudo dpkg --ignore-depends=multiarch-support -i ./libttspico-utils_1.0+git20130326-9_armhf.deb
(Lecture de la base de données... 116729 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../libttspico-utils_1.0+git20130326-9_armhf.deb ...
Dépaquetage de libttspico-utils (1.0+git20130326-9) sur (1.0+git20130326-3) ...
Paramétrage de libttspico-utils (1.0+git20130326-9) ...
Traitement des actions différées (« triggers ») pour man-db (2.9.4-2) ...
Log de démarrage de PlayTTS (mode debug)
[2022-02-02 18:47:23][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=playtts function=remove callInstallFunction=1
[2022-02-02 18:47:26][INFO] : Début d'activation du plugin
[2022-02-02 18:47:27][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-02 18:47:27][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=playtts function=install callInstallFunction=1
Play TTS était installé comme mon rasp avait une enceinte connecté. La google Home a eu pour but de d’externaliser cette sortie sonore.
Mais cela n’a surement rien à voir avec le probleme.
Ok. je vais voir le supprimer alors.
j’ai pas de log TTS. Ou le trouver? (rien dans Analyse/Logs)
Juste le log gcast :
[2022-02-02 19:11:03][INFO] : Début d'activation du plugin
[2022-02-02 19:11:04][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-02 19:11:04][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=gcast function=install callInstallFunction=1
Déjà fait également
Question : j’ai fait une sauvegarde avant le passage en 4.2 et donc la maj de Gcast, est ce qu’un rollback pourrait permettre de rollback également le plugin?
