tout d’abord, merci pour votre travail sur ce plugin.
j’ai récemment tenté d’ajouter mon robot à Jeedom à l’aide de votre plugin. il semble que la découverte du roomba se déroule correctement mais ensuite, celui ci n’apparaît pas.
J’ai quitté l’application irobot sur mon téléphone, sans succés. J’ai regardé les différents topics sans trouver de solution. pouvez vous m’aider ?
Ci dessous les différents éléments demandés (capture, log, …)
Santé du jeedom :
Config du plugin :
fichier de log du daemon:
[2026-01-11 09:45:37] ERROR : Attempting retry Connection# 672
[2026-01-11 09:45:37] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:46:37] ERROR : Attempting retry Connection# 673
[2026-01-11 09:46:37] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:47:37] ERROR : Attempting retry Connection# 674
[2026-01-11 09:47:37] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:48:37] ERROR : Attempting retry Connection# 675
[2026-01-11 09:48:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:49:38] ERROR : Attempting retry Connection# 676
[2026-01-11 09:49:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:50:38] ERROR : Attempting retry Connection# 677
[2026-01-11 09:50:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:51:38] ERROR : Attempting retry Connection# 678
[2026-01-11 09:51:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:52:38] ERROR : Attempting retry Connection# 679
[2026-01-11 09:52:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:53:38] ERROR : Attempting retry Connection# 680
[2026-01-11 09:53:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:54:38] ERROR : Attempting retry Connection# 681
[2026-01-11 09:54:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:55:38] ERROR : Attempting retry Connection# 682
[2026-01-11 09:55:38] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:56:38] ERROR : Attempting retry Connection# 683
[2026-01-11 09:56:39] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:57:39] ERROR : Attempting retry Connection# 684
[2026-01-11 09:57:39] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:58:39] ERROR : Attempting retry Connection# 685
[2026-01-11 09:58:39] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 09:59:39] ERROR : Attempting retry Connection# 686
[2026-01-11 09:59:39] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
configuration :
more config.json
"D03F5D6A146B85FB2EA2CDD1A3025861": {
"cap": {
"5ghz": 1,
"area": 1,
"autoevac": 1,
"binFullDetect": 0,
"bleLog": 1,
"carpetBoost": 3,
"dPause": 1,
"dSpot": 1,
"dnd": 1,
"dockComm": 1,
"expectingUserConf": 2,
"floorTypeDetect": 4,
"idl": 0,
"lang": 2,
"langOta": 2,
"lmap": 1,
"log": 2,
"mapMax": 5,
"maps": 6,
"matter": 1,
"mc": 3,
"multiPass": 1,
"ns": 1,
"oMode": 550,
"odoa": 1,
"ota": 3,
"p2maps": 3,
"ppWetLvl": 0,
"prov": 3,
"pw": 3,
"saSku": 1,
"sched": 2,
"scrub": 3,
"suctionLvl": 4,
"svcConf": 1,
"tLine": 2,
"vmStrat": 1
"hostname": "iRobot-D03F5D6A146B85FB2EA2CDD1A3025861",
"ip": "192.168.20.10",
"mac": "ac:f4:73:02:ff:8a",
"nc": 0,
"proto": "mqtt",
"robotid": "D03F5D6A146B85FB2EA2CDD1A3025861",
"robotname": "nestor",
"sku": "N185040",
"sw": "p25-505+9.3.6+I3.8.149",
"ver": "4"
J’ai tenté de redémarrer le plugin, voici les logs après le redemarrage :
2026-01-11 10:21:17] INFO : Found 1 robots defined in the cloud
[2026-01-11 10:21:17] INFO : Robot nestor added to configuration with password from cloud
[2026-01-11 10:21:18] INFO : Try to connect to nestor with ip 192.168.20.10
[2026-01-11 10:21:18] INFO : Setting TLS
[2026-01-11 10:21:18] INFO : Setting TLS - OK
[2026-01-11 10:21:18] DEBUG : Broker Connected with result code Success
[2026-01-11 10:21:18] INFO : subscribed to iRobot/command/D03F5D6A146B85FB2EA2CDD1A3025861/#, iRobot/setting/D03F5D6A146B85FB2EA2CDD1A3025861/#
[2026-01-11 10:21:18] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 10:21:18] DEBUG : sleeping 1s
[2026-01-11 10:21:19] ERROR : Attempting retry Connection# 0
[2026-01-11 10:21:19] INFO : Attempting to Reconnect...
[2026-01-11 10:21:19] ERROR : Robot nestor found but connection is refused, make sure nothing else is connected(app?), as only one connection at a time is allowed
[2026-01-11 10:21:19] DEBUG : sleeping 2s
