Freebox Delta PHP Warning
J’ai régulièrement des erreurs sur les logs cron_execution , je ne sais pas définir la cause de ces erreurs.
Cela ne semble pas gêner le fonctionnement.
merci pour votre aide
Patrick
0000|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0001|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0002|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0003|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0004|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0005|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0006|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0007|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0008|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0009|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0010|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0011|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0012|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0013|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0014|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0015|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0016|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0017|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0018|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0019|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0020|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0021|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0022|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0023|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0024|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0025|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0026|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0027|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0028|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0029|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0030|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0031|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0032|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0033|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0034|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0035|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0036|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0037|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0038|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0039|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0040|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
0041|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/Freebox_OS/core/class/Free_Refresh.class.php on line 1144
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : oui
Plugin : Freebox
Version : 2025-01-01 01:13:12 (stable)
Statut Démon : Démarré - (2025-01-08 18:00:06)
Informations complémentaires
Box [fbxgw7r] ; Box_name [Freebox Server] ; Firmware [4.8.17.1] ; Mode [router] ; IP Box [mafreebox.freebox.fr]
Nom [Patrick_G] ; API [v12] ; Freebox Compatible Tiles [OK] ; Cron Tiles [0]
Scans : EQ [02/01/2025 09:51:34] ; Tiles [02/01/2025 09:51:39] ; Parental [02/01/2025 09:51:37]
ECO WIFI DISPO : [1]
merci du retour,
J’ai fait pas mal de correction dans la beta actuelle. Il faudrait tester avec le plugin en beta
Attention il faudra lancer une recherche des équipements standards, il y a du changement au niveau de la gestion du WIFI
