Je suis en Jeedom 4.3.23 avec Debian 11 sur un Odroid C4.
J’ai l’impression que NO-IP ne fonctionne pas normalement; pas de scan des domaines, pas de mise à jor de mes adresses.
Dans le log du plugin j’ai ceci même après relance des dépendances (ce qui m’inquiète c’est le WARNING vers la fin):
Launch install of noip dependencies
-- Current OS version :
Description: Debian GNU/Linux 11 (bullseye)
-- Updating repo...
Hit:1 http://security.debian.org bullseye-security InRelease
Hit:2 http://fi.mirror.armbian.de/apt bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye InRelease
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
-- Installation of python3 and dependencies
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
python-dev-is-python2 is already the newest version (2.7.18-9).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
-- Installed version of Python :
Python 3.9.2
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (20.3.4-4+deb11u1).
python3-dev is already the newest version (3.9.2-3).
python3-requests is already the newest version (2.25.1+dfsg-2).
-- Installation of chromium
chromium is already the newest version (120.0.6099.224-1~deb11u1).
-- Installed version of pip :
pip 24.0 from /usr/local/lib/python3.9/dist-packages/pip (python 3.9)
-- Installation of python library 'selenium' with command pip3.9
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
cat: /tmp/jeedom/noip/dependancy_noip: No such file or directory
-- Installation of dependencies is don
[2024-03-23 16:30:06]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 16:45:05]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 17:00:07]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 17:15:05]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 17:18:48]DEBUG : Execution de la commande refresh
[2024-03-23 17:18:48]INFO : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py --loglevel debug --user scodron --pwd "********" --threshold 2 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2024-03-23 17:18:48]INFO : Log level : debug
[2024-03-23 17:18:48]INFO : User : scodron
[2024-03-23 17:18:48]INFO : Threshold : 2
[2024-03-23 17:18:48]INFO : Renew : 1
[2024-03-23 17:18:48]INFO : ForcePath : 1
[2024-03-23 17:18:48]ERROR : Exception has been thrown. Message: Unable to locate or obtain driver for chrome; For documentation on this error, please visit: https://www.selenium.dev/documentation/webdriver/troubleshooting/errors/driver_location
[2024-03-23 17:18:48]DEBUG : [système][No-Ip] file content:
[2024-03-23 17:18:48]ERROR : [système][No-Ip] file content empty
[2024-03-23 17:19:29]DEBUG : Task 'syncNoIp' executed now
[2024-03-23 17:19:29]INFO : Début de synchronisation
[2024-03-23 17:19:29]INFO : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py --loglevel debug --user scodron --pwd "********" --threshold 3 --renew 0 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2024-03-23 17:19:30]INFO : Log level : debug
[2024-03-23 17:19:30]INFO : User : scodron
[2024-03-23 17:19:30]INFO : Threshold : 3
[2024-03-23 17:19:30]INFO : Renew : 0
[2024-03-23 17:19:30]INFO : ForcePath : 1
[2024-03-23 17:19:30]ERROR : Exception has been thrown. Message: Unable to locate or obtain driver for chrome; For documentation on this error, please visit: https://www.selenium.dev/documentation/webdriver/troubleshooting/errors/driver_location
[2024-03-23 17:19:30]DEBUG : [système][No-Ip] file content:
[2024-03-23 17:19:30]ERROR : [système][No-Ip] file content empty
[2024-03-23 17:19:30]INFO : Fin de la synchronisation
[2024-03-23 17:30:06]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 17:45:05]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 18:00:06]DEBUG : Pas de mise à jour d'IP à réaliser
[2024-03-23 18:15:04]DEBUG : Pas de mise à jour d'IP à réaliser
