Failed to start zigbee-herdsman
Voici mon probléme depuis quelques jours.Est-ce quequelqu’un peut m’aider ? merci
zigbee2mqtt@2.6.3 start
node index.js
Starting Zigbee2MQTT without watchdog.
[2025-11-20 22:37:22] e[32minfoe[39m: 	z2m: Logging to console, file (filename: log.log)
[2025-11-20 22:37:22] e[32minfoe[39m: 	z2m: Starting Zigbee2MQTT version 2.6.3 (commit #5797b568)
[2025-11-20 22:37:22] e[32minfoe[39m: 	z2m: Starting zigbee-herdsman (6.3.2)
[2025-11-20 22:37:23] e[33mwarninge[39m: 	zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2025-11-20 22:37:33] e[31merrore[39m: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2025-11-20 22:37:33] e[31merrore[39m: 	zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
[2025-11-20 22:37:48] e[31merrore[39m: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2025-11-20 22:37:48] e[31merrore[39m: 	zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
[2025-11-20 22:38:08] e[31merrore[39m: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2025-11-20 22:38:08] e[31merrore[39m: 	zh:ezsp:ezsp: Connection attempt 3 error: Error: Failure to connect
[2025-11-20 22:38:33] e[31merrore[39m: 	zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2025-11-20 22:38:33] e[31merrore[39m: 	zh:ezsp:ezsp: Connection attempt 4 error: Error: Failure to connect
[2025-11-20 22:38:33] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2025-11-20 22:38:33] e[31merrore[39m: 	z2m: Failed to start zigbee-herdsman
[2025-11-20 22:38:33] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-11-20 22:38:33] e[31merrore[39m: 	z2m: Exiting...
[2025-11-20 22:38:34] e[31merrore[39m: 	z2m: Error: Failure to connect
at Ezsp.connect (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:366:19)
at Driver.startup (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:186:13)
at EZSPAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:151:16)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:67:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:101:13)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:149:5)
> node index.js
Informations Jeedom luna
Core : 4.4.20 (master)
DNS Jeedom luna : oui
Plugin : JeeZigbee
Version : 2025-11-19 12:03:15 (stable)
Statut Démon : Démarré - (2025-11-21 13:50:13)
Auriez-vous mis le firmware du contrôleur de la luna à jour ? Dans l’affirmative passer la configuration sur ember.
Sinon
