Avez vous ce code erreur « Failed to set privacy: Rejected (0x0b) » lors de la commande ssh ,
sudo service bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/bluetooth.service.d
└─override.conf
Active: active (running) since Mon 2022-06-20 17:38:45 CEST; 20h ago
Docs: man:bluetoothd(8)
Main PID: 709 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4102)
CGroup: /system.slice/bluetooth.service
└─709 /usr/lib/bluetooth/bluetoothd --noplugin=sap
juin 20 17:38:45 jeedom systemd[1]: Starting Bluetooth service...
juin 20 17:38:45 jeedom bluetoothd[709]: Bluetooth daemon 5.50
juin 20 17:38:45 jeedom systemd[1]: Started Bluetooth service.
juin 20 17:38:45 jeedom bluetoothd[709]: Starting SDP server
juin 20 17:38:45 jeedom bluetoothd[709]: Excluding (cli) sap
juin 20 17:38:45 jeedom bluetoothd[709]: Bluetooth management interface 1.18 initialized
juin 20 17:38:45 jeedom bluetoothd[709]: Failed to set privacy: Rejected (0x0b)
juin 20 17:38:45 jeedom bluetoothd[709]: Endpoint registered: sender=:1.13 path=/org/bluez/hci0/A2DP/SBC/Source/1
juin 20 17:38:45 jeedom bluetoothd[709]: Endpoint registered: sender=:1.13 path=/org/bluez/hci0/A2DP/SBC/Source/2
Ou est ce que je dois recherche ?
