Est-il possible de ne pas avoir la répétition de valeurs identiques qui se suivent ?
La commande en question a la gestion de la répétition des valeurs à "jamais répéter".
| 2020-10-09 05:59:31 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:00:01 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:00:31 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:01:01 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:01:31 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:02:01 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:02:31 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:02:43 | Shelly | prise08 | Puissance | 55,76 | W | |
| 2020-10-09 06:03:13 | Shelly | prise08 | Puissance | 56,46 | W | |
| 2020-10-09 06:03:43 | Shelly | prise08 | Puissance | 56,3 | W | |
| 2020-10-09 06:04:13 | Shelly | prise08 | Puissance | 55,98 | W | |
| 2020-10-09 06:04:43 | Shelly | prise08 | Puissance | 55,56 | W | |
| 2020-10-09 06:05:13 | Shelly | prise08 | Puissance | 55,17 | W | |
| 2020-10-09 06:05:40 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:06:10 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:06:40 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:07:10 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:07:40 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:08:10 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:08:40 | Shelly | prise08 | Puissance | 0 | W | |
| 2020-10-09 06:09:10 | Shelly | prise08 | Puissance | 0 | W |
[2020-10-15 09:27:27][SCENARIO] name: Système à jour, comment: , state: 1, result: OK
[2020-10-15 09:27:27][SCENARIO] name: Cron actif, comment: , state: 1, result: OK
[2020-10-15 09:27:27][SCENARIO] name: Scénario actif, comment: , state: 1, result: OK
[2020-10-15 09:27:27][SCENARIO] name: Démarré, comment: , state: 1, result: OK 2020-10-02 13:44:01
[2020-10-15 09:27:27][SCENARIO] name: Date système (dernière heure enregistrée), comment: , state: 1, result: OK 2020-10-15 09:27:27 (2020-10-15 08:40:02)
[2020-10-15 09:27:27][SCENARIO] name: Droits sudo, comment: , state: 1, result: OK
[2020-10-15 09:27:27][SCENARIO] name: Version Jeedom, comment: , state: 1, result: 4.0.61
[2020-10-15 09:27:27][SCENARIO] name: Version PHP, comment: , state: 1, result: 7.3.19-1~deb10u1
[2020-10-15 09:27:27][SCENARIO] name: Apache, comment: , state: 1, result: 11
[2020-10-15 09:27:27][SCENARIO] name: Version OS, comment: , state: 1, result: Linux jeedom 4.19.0-11-amd64 #1 SMP Debian 4.19.146-1 (2020-09-17) x86_64 GNU/Linux [10.6]
[2020-10-15 09:27:27][SCENARIO] name: Version database, comment: , state: 1, result: 10.3.23-MariaDB-0+deb10u1
[2020-10-15 09:27:27][SCENARIO] name: Espace disque libre, comment: , state: 1, result: 71 %
[2020-10-15 09:27:27][SCENARIO] name: Espace disque libre tmp, comment: , state: 1, result: 96 %
[2020-10-15 09:27:27][SCENARIO] name: Mémoire disponible, comment: , state: 1, result: 45 % (Total 1995 Mo)
[2020-10-15 09:27:27][SCENARIO] name: Mémoire suffisante, comment: , state: 1, result: 0
[2020-10-15 09:27:27][SCENARIO] name: Erreur I/O, comment: , state: 1, result: 0
[2020-10-15 09:27:27][SCENARIO] name: Swap disponible, comment: , state: 1, result: 96 % (Total 2046 Mo)
[2020-10-15 09:27:27][SCENARIO] name: Swapiness, comment: , state: 1, result: 60%
[2020-10-15 09:27:27][SCENARIO] name: Charge, comment: , state: 1, result: 0.78 - 0.66 - 0.48
[2020-10-15 09:27:27][SCENARIO] name: Configuration réseau interne, comment: , state: 1, result: OK
[2020-10-15 09:27:27][SCENARIO] name: Configuration réseau externe, comment: , state: 1, result: OK
[2020-10-15 09:27:27][SCENARIO] name: Persistance du cache, comment: , state: 1, result: OK (2020-10-15 09:00:05)
[2020-10-15 09:27:27][SCENARIO] name: Apache private tmp, comment: , state: 0 , result: OK
[2020-10-15 09:27:27][SCENARIO] plugin: Data Export -> dataexport -> stable -> 2020-10-08 11:47:36
[2020-10-15 09:27:27][SCENARIO] active -> 1
[2020-10-15 09:27:27][SCENARIO] deamonAutoMode -> 1
Table historyArch
Table history
