Impossible d’installer les depandances, auriez vous une idée?
Voici les logs :
Begin installation of composer
--2024-04-20 08:49:50-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 54.36.53.46, 2001:41d0:302:1100::8:104f
Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58444 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 87% 3.15M 0s
50K ....... 100% 59.4M=0.02s
2024-04-20 08:49:50 (3.57 MB/s) - 'composer-setup.php' saved [58444/58444]
PHP Warning: Module 'mosquitto' already loaded in Unknown on line 0
All settings correct for using Composer
Downloading...
Composer (version 2.7.3) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
+ echo 7
+ cd /var/www/html/core/class/../../plugins/espeasy/resources
+ rm -rf node_modules
+ sudo npm install
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 48 packages, and audited 49 packages in 2s
2 packages are looking for funding
run `npm fund` for details
2 moderate severity vulnerabilities
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
+ sudo chown -R www-data:www-data espeasy.js node_modules package-lock.json package.json
+ echo 8
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end espeasy
+ echo 9
+ rm /tmp/jeedom_install_in_progress_espeasy
Merci pour votre aide!
Informations Jeedom Atlas
Core : 4.4.3 (V4-stable)
DNS Jeedom Atlas : oui
Plugin : ESPeasy
Version : 2023-07-27 01:00:50 (stable)
Statut Démon : Stoppé - (2024-04-20 11:50:46)
