Bonjour ,
Après avoir installé le plugin MQTT manager, j’ai installé le plugin jeezigbee
le statut et Demon sont en vert .
je lance l’inclusion pour detecter les capteurs
et j’ai le message : Passage en inclusion sur ? : un seul choix : Demon 1
Est ce bien ma clé Conbee2 ? comment le savoir ?
l’inclusion ne marche pas …
pouvez vous m’aider?
ci joint des logs:
z2m.txt (26,0 Ko)
z2m_packages.txt (1,8 Ko)
z2md.txt (11,7 Ko)
Bonjour @philler
Pouvez vous mettre les log entre balise </>
Cela simplifie la lecture
Dams
Le log z2md
READ THIS CAREFULLY
Refusing to start because configuration is not valid, found the following errors:
- mqtt/password must be string
If you don't know how to solve this, read https://www.zigbee2mqtt.io/guide/configuration
npm WARN invalid config prefix=true set in command line options
npm WARN invalid config Must be valid filesystem path
npm ERR! code ENOENT
npm ERR! syscall open
npm ERR! path /var/www/package.json
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, open '/var/www/package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2023-08-05T10_10_05_849Z-debug-0.log
> zigbee2mqtt@1.32.2 start
> node index.js
Zigbee2MQTT:error 2023-08-05 12:36:02: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:error 2023-08-05 12:43:52: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:error 2023-08-05 12:44:02: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:error 2023-08-05 17:44:24: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:error 2023-08-05 17:44:34: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Il dit erreur de configuration notamment npn
Le log z2m package
86 packages are looking for funding
run `npm fund` for details
1 moderate severity vulnerability
To address all issues, run:
npm audit fix
Run `npm audit` for details.
+ npm run build
Tout est noté dans les log
Donc dans système, configuration, OS DB puis administration système lancer les commandes
npm audit fix
puis
npm run build
il y a ça aussi
Vérifier le mot de passe mqtt
Dams
J’ai fait audi fix et run build
la réponse est pour les 2 :
npm ERR! code ENOLOCK
npm ERR! audit This command requires an existing lockfile.
npm ERR! audit Try creating one first with: npm i --package-lock-only
npm ERR! audit Original error: loadVirtual requires existing shrinkwrap file
npm ERR! Log files were not written due to an error writing to the directory: /var/www/.npm/_logs
npm ERR! You can rerun the command with --loglevel=verbose to see the logs in your terminal
Pour le mot de passe MQTT , il a été généré automatiquement par jeedom . Je ne sais pas quoi verifier.
La demande faite plus haut :
Reste toujours d actualité pour ton precedent message (comme pour tous les prochains !) @philler ![]()
Et ne pas hesiter a trouver un titre un peu plus parlant (et donc editer le post actuel!) pour aider d autres utilisateus qui auraient le meme soucis a tomber sur ce post ![]()
