Hello depuis la mise à jour de ce matin en 7.2 j’ai les erreurs suivantes dans les log :
[2025-10-09 08:00:20][ERROR] : Errors received from Tado: "invalid_device_code"
[2025-10-09 08:00:20][ERROR] : Token manquant - La récupération d'un token a échoué: Errors received from Tado: "invalid_device_code"
[2025-10-09 08:00:20][ERROR] : Error while executing the command 'MyTadoDaemonCmd.REFRESH_HOME_DATA': Make request - Token invalide, impossible d'appeler 'https://my.tado.com/api/v2/homes/1962536/zones' (api.py (146) -> MyTadod.py (189))
[2025-10-09 08:22:45][ERROR] : TadoZone - Hot Water - Failed to read some zone information: HTTPSConnectionPool(host='my.tado.com', port=443): Max retries exceeded with url: /api/v2/homes/1962536/zones/0/state (Caused by NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7fa85d0070>: Failed to resolve 'my.tado.com' ([Errno -3] Temporary failure in name resolution)"))
[2025-10-09 08:22:45][ERROR] : Send command to daemon error: Server disconnected
[2025-10-09 08:22:46][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 08:22:46][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 08:30:09][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 08:30:09][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 08:45:07][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 08:45:07][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 09:00:12][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 09:00:12][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 09:15:07][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 09:15:07][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 09:30:20][ERROR] : Token expiré - La mise à jour du token a échoué: HTTPSConnectionPool(host='login.tado.com', port=443): Max retries exceeded with url: /oauth2/token (Caused by NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7fa86ba3a0>: Failed to resolve 'login.tado.com' ([Errno -3] Temporary failure in name resolution)"))
[2025-10-09 09:30:20][ERROR] : Errors received from Tado: "missing_device_code"
[2025-10-09 09:30:20][ERROR] : Token manquant - La récupération d'un token a échoué: Errors received from Tado: "missing_device_code"
[2025-10-09 09:30:20][ERROR] : Error while executing the command 'MyTadoDaemonCmd.REFRESH_HOME_DATA': Make request - Token invalide, impossible d'appeler 'https://my.tado.com/api/v2/homes/1962536/zones' (api.py (146) -> MyTadod.py (189))
[2025-10-09 09:45:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 09:45:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:00:12][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:00:12][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:15:07][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:15:07][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:30:10][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:30:10][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:45:07][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 10:45:07][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:00:21][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:00:21][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:15:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:15:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:30:11][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:30:11][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:45:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 11:45:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:00:12][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:00:12][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:15:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:15:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:30:10][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:30:10][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:45:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 12:45:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:00:11][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:00:11][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:15:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:15:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:30:11][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:30:11][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:45:07][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 13:45:07][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 14:00:11][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 14:00:11][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 14:15:08][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 14:15:08][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 14:30:11][ERROR] : Error while collecting info for device 'BRXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
[2025-10-09 14:30:11][ERROR] : Error while collecting info for device 'SUXXXXXXXX': 'TadoZone' object has no attribute 'capabilities' (home.py (545) -> home.py (1278))
Les deux équipements sont celui créé pour le contrôle de l’eau chaude et l’autre pour le récepteur sans fil qui est relié à la chaudière
Informations Jeedom
Core : 4.4.20 (master)
DNS Jeedom : oui
RPI4 Debian 11
