Problème avec le plugin Modbus.
Impossible d’installer les dépendances avec la dernière mise à jour. alors qu’elles semblent installées ! Cela bloque à 12%.
Message des LOGS :
LOG MODBUS :
[2023-07-31 00:58:38][INFO] : Début d'activation du plugin
[2023-07-31 00:58:49][INFO] : Info sur le démon : {"log":"modbus","state":"nok","launchable":"nok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2023-06-28 15:06:14"}
[2023-07-31 01:00:16][ERROR] : Attention : l'installation des dépendances a dépassé le temps maximum autorisé : 0min
LOG PACKAGE MODBUS :
+ touch /tmp/jeedom_install_in_progress_modbus
+ echo 1
+ echo 2
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ sudo pip3 cache purge
Files removed: 28
+ echo 4
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.2.1)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 5
+ sudo pip3 install --force-reinstall --upgrade pyudev
Collecting pyudev
Downloading pyudev-0.24.1-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.9/62.9 kB 2.3 MB/s eta 0:00:00
Installing collected packages: pyudev
Attempting uninstall: pyudev
Found existing installation: pyudev 0.24.1
Uninstalling pyudev-0.24.1:
Successfully uninstalled pyudev-0.24.1
Successfully installed pyudev-0.24.1
+ echo 6
+ sudo pip3 install --force-reinstall --upgrade requests
Collecting requests
Obtaining dependency information for requests from https://files.pythonhosted.org/packages/70/8e/0e2d847013cb52cd35b38c009bb167a1a26b2ce6cd6965bf26b47bc0bf44/requests-2.31.0-py3-none-any.whl.metadata
Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
Collecting charset-normalizer<4,>=2 (from requests)
Obtaining dependency information for charset-normalizer<4,>=2 from https://files.pythonhosted.org/packages/9c/74/10a518cd27c2c595768f70ddbd7d05c9acb01b26033f79433105ccc73308/charset_normalizer-3.2.0-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata
Downloading charset_normalizer-3.2.0-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (31 kB)
Collecting idna<4,>=2.5 (from requests)
Downloading idna-3.4-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.5/61.5 kB 2.9 MB/s eta 0:00:00
Collecting urllib3<3,>=1.21.1 (from requests)
Obtaining dependency information for urllib3<3,>=1.21.1 from https://files.pythonhosted.org/packages/9b/81/62fd61001fa4b9d0df6e31d47ff49cfa9de4af03adecf339c7bc30656b37/urllib3-2.0.4-py3-none-any.whl.metadata
Downloading urllib3-2.0.4-py3-none-any.whl.metadata (6.6 kB)
Collecting certifi>=2017.4.17 (from requests)
Obtaining dependency information for certifi>=2017.4.17 from https://files.pythonhosted.org/packages/4c/dd/2234eab22353ffc7d94e8d13177aaa050113286e93e7b40eae01fbf7c3d9/certifi-2023.7.22-py3-none-any.whl.metadata
Downloading certifi-2023.7.22-py3-none-any.whl.metadata (2.2 kB)
Downloading requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 325.8 kB/s eta 0:00:00
Downloading certifi-2023.7.22-py3-none-any.whl (158 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 158.3/158.3 kB 546.3 kB/s eta 0:00:00
Downloading charset_normalizer-3.2.0-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (171 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 171.5/171.5 kB 832.4 kB/s eta 0:00:00
Downloading urllib3-2.0.4-py3-none-any.whl (123 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 123.9/123.9 kB 781.5 kB/s eta 0:00:00
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 2.0.4
Uninstalling urllib3-2.0.4:
Successfully uninstalled urllib3-2.0.4
Attempting uninstall: idna
Found existing installation: idna 3.4
Uninstalling idna-3.4:
Successfully uninstalled idna-3.4
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 3.2.0
Uninstalling charset-normalizer-3.2.0:
Successfully uninstalled charset-normalizer-3.2.0
Attempting uninstall: certifi
Found existing installation: certifi 2023.7.22
Uninstalling certifi-2023.7.22:
Successfully uninstalled certifi-2023.7.22
Attempting uninstall: requests
Found existing installation: requests 2.31.0
Uninstalling requests-2.31.0:
Successfully uninstalled requests-2.31.0
Successfully installed certifi-2023.7.22 charset-normalizer-3.2.0 idna-3.4 requests-2.31.0 urllib3-2.0.4
+ echo 7
+ sudo pip3 install --force-reinstall --upgrade setuptools
Collecting setuptools
Obtaining dependency information for setuptools from https://files.pythonhosted.org/packages/c7/42/be1c7bbdd83e1bfb160c94b9cafd8e25efc7400346cf7ccdbdb452c467fa/setuptools-68.0.0-py3-none-any.whl.metadata
Downloading setuptools-68.0.0-py3-none-any.whl.metadata (6.4 kB)
Downloading setuptools-68.0.0-py3-none-any.whl (804 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 804.0/804.0 kB 4.4 MB/s eta 0:00:00
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 68.0.0
Uninstalling setuptools-68.0.0:
Successfully uninstalled setuptools-68.0.0
Successfully installed setuptools-68.0.0
+ echo 8
+ sudo pip3 install --force-reinstall --upgrade wheel
Collecting wheel
Obtaining dependency information for wheel from https://files.pythonhosted.org/packages/17/11/f139e25018ea2218aeedbedcf85cd0dd8abeed29a38ac1fda7f5a8889382/wheel-0.41.0-py3-none-any.whl.metadata
Downloading wheel-0.41.0-py3-none-any.whl.metadata (2.2 kB)
Downloading wheel-0.41.0-py3-none-any.whl (64 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 64.7/64.7 kB 1.5 MB/s eta 0:00:00
Installing collected packages: wheel
Attempting uninstall: wheel
Found existing installation: wheel 0.41.0
Uninstalling wheel-0.41.0:
Successfully uninstalled wheel-0.41.0
Successfully installed wheel-0.41.0
+ echo 9
+ sudo pip3 install --force-reinstall --upgrade pyserial
Collecting pyserial
Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 90.6/90.6 kB 3.6 MB/s eta 0:00:00
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 10
+ sudo pip3 install --force-reinstall --upgrade pymodbus==3.2.2
ERROR: Ignored the following versions that require a different python version: 3.0.0 Requires-Python >=3.8.0; 3.0.0.dev4 Requires-Python >=3.8.0; 3.0.0.dev5 Requires-Python >=3.8.0; 3.0.0rc1 Requires-Python >=3.8.0; 3.0.1 Requires-Python >=3.8.0; 3.0.2 Requires-Python >=3.8.0; 3.1.0 Requires-Python >=3.8.0; 3.1.1 Requires-Python >=3.8.0; 3.1.2 Requires-Python >=3.8.0; 3.1.3 Requires-Python >=3.8.0; 3.2.0 Requires-Python >=3.8.0; 3.2.1 Requires-Python >=3.8.0; 3.2.2 Requires-Python >=3.8.0; 3.3.0 Requires-Python >=3.8.0; 3.3.1 Requires-Python >=3.8.0; 3.3.2 Requires-Python >=3.8.0; 3.4.0 Requires-Python >=3.8.0; 3.4.1 Requires-Python >=3.8.0
ERROR: Could not find a version that satisfies the requirement pymodbus==3.2.2 (from versions: 0.9.0, 1.0.0, 1.1.0, 1.2.0, 1.3.0rc1, 1.3.0rc2, 1.3.1, 1.3.2, 1.4.0rc3, 1.4.0, 1.5.0, 1.5.1, 1.5.2, 2.0.0, 2.0.1, 2.1.0, 2.2.0rc1, 2.2.0rc2, 2.2.0rc3, 2.2.0rc4, 2.2.0, 2.3.0rc1, 2.3.0, 2.4.0rc1, 2.4.0, 2.5.0rc1, 2.5.0rc2, 2.5.0, 2.5.1rc1, 2.5.1, 2.5.2, 2.5.3rc1, 2.5.3, 3.0.0.dev2, 3.0.0.dev3)
ERROR: No matching distribution found for pymodbus==3.2.2
+ echo 11
+ sudo pip3 install --force-reinstall --upgrade bitstring
Collecting bitstring
Downloading bitstring-4.0.2-py3-none-any.whl (46 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 46.0/46.0 kB 2.1 MB/s eta 0:00:00
Installing collected packages: bitstring
Attempting uninstall: bitstring
Found existing installation: bitstring 4.0.2
Uninstalling bitstring-4.0.2:
Successfully uninstalled bitstring-4.0.2
Successfully installed bitstring-4.0.2
+ echo 12
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end modbus
+ rm /tmp/jeedom_install_in_progress_modbus
Alors si quelqu'un avait une idée !
Merci :slight_smile:
Bonne journée !
