je me retrouve de nouveau avec le même problème…
> zigbee2mqtt@1.32.2 start
> node index.js
Building Zigbee2MQTT... (initial build), failed
Error: Command failed: npm run build
at ChildProcess.exithandler (node:child_process:402:12)
at ChildProcess.emit (node:events:513:28)
at maybeClose (node:internal/child_process:1100:16)
at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
En redémarrant Zigbee2MQTT en mode debug les log sont identiques à ce qu’avait envoyé @Soyann
Si vous pouvez m’aiguiller ? merci par avance…
voici en plus les log mqtt en debug :
1693463959: Will message specified (24 bytes) (r0, q1).
1693463959: /Jeedom_zbmqtt1458
1693463959: Sending CONNACK to jeedomzb1458 (0, 0)
1693463959: Received SUBSCRIBE from jeedomzb1458
1693463959: # (QoS 1)
1693463959: Sending SUBACK to jeedomzb1458
et l’installation des dépendances :
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:10.2.1-1).
gcc is already the newest version (4:10.2.1-1).
git is already the newest version (1:2.30.2-1+deb11u2).
make is already the newest version (4.3-4.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
##### Install or update NodeJs
NodeJs 16 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (2.0.11-1).
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
##### Update : Download update from Zigbee2mqtt git
##### up to date
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
Merci par avance pour votre aide
