Error: 'ConnectionError' object has no attribute 'message'
La Dernière mise à jour en bêta a fait planter mon système.
J’ai repassé en sable et ça fait replanter mon système encore. Je vais désactiver le plug-in voir si ça vient bien de là.
Difficile de te venir en aide sans logs …
2115|[2025-02-05 22:05:06] INFO  : Writing PID 559612 to /tmp/jeedom/tahomalocalapi/tahomalocalapid.pid
2116|[2025-02-05 22:05:06] INFO  : Init request module v2.32.3
2117|[2025-02-05 22:05:06] DEBUG  : Starting new HTTP connection (1): 127.0.0.1:80
2118|[2025-02-05 22:07:15] ERROR  : Fatal error: 'ConnectionError' object has no attribute 'message'
2119|[2025-02-05 22:07:15] ERROR  : Fatal error: 'ConnectionError' object has no attribute 'message'
2120|[2025-02-05 22:07:15] INFO  : Traceback (most recent call last):
2121|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 198, in _new_conn
2122|sock = connection.create_connection(
2123|File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 85, in create_connection
2124|raise err
2125|File "/usr/local/lib/python3.9/dist-packages/urllib3/util/connection.py", line 73, in create_connection
2126|sock.connect(sa)
2127|TimeoutError: [Errno 110] Connection timed out
2128|The above exception was the direct cause of the following exception:
2129|Traceback (most recent call last):
2130|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 787, in urlopen
2131|response = self._make_request(
2132|File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 493, in _make_request
2133|conn.request(
2134|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 445, in request
2135|self.endheaders()
2136|File "/usr/lib/python3.9/http/client.py", line 1250, in endheaders
2137|self._send_output(message_body, encode_chunked=encode_chunked)
2138|File "/usr/lib/python3.9/http/client.py", line 1010, in _send_output
2139|self.send(msg)
2140|File "/usr/lib/python3.9/http/client.py", line 950, in send
2141|self.connect()
2142|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 276, in connect
2143|self.sock = self._new_conn()
2144|File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 213, in _new_conn
2145|raise NewConnectionError(
2146|urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xffff9a84c7c0>: Failed to establish a new connection: [Errno 110] Connection timed out
2147|The above exception was the direct cause of the following exception:
2148|Traceback (most recent call last):
2149|File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 667, in send
Bonjour, je vois que le poste a été déplacé, je ne sais pas si tu as eu le temps de jeter un coup d’œil ou si malheureusement rien n’est possible.
Pour info, j’ai désactivé le plug-in, et pour l’instant ça n’a pas replanté.
Ton système plante car le daemon du plugin se relance automatiquement …désactivé la relance auto et tout va aller mieux
Peux tu poster les 2 logs mais complete stp
Je viens de réactiver le planning en désactivant la relance automatique et au bout de cinq minutes ça vient de faire planter ma box
Très bizarre car si le plugin ne se relance pas automatiquement y a pas de raison que cela change le comportement de la box
tahomalocalapi.txt (95,7 Ko)
tahomalocalapi_daemon.txt (329,2 Ko)
Juste enlever le login et le mot de passe
Super merci
Je suis en vacances la …je regarde des que je peux
Pour info après le dernier redémarrage de l’autre jour, j’ai bien vérifié que la gestion automatique du démon était désactivé et là ça ne plante plus. Il a fallu que je redémarre le démon deux fois depuis, mais rien à planer.
C’est juste une solution pour pas surcharger ta box …excuse moi si je te repose une question que je t’ai déjà posé mais ta box est connecté en wifi ou filaire ? Car je pense que c’est un soucis de déconnexion du reseau
Désolé pour la réponse extrêmement tardive, mais depuis quelques mois j’ai eu des priorités à gérer.
Ma box est en filaire
