Erreurs dans http.error access_compat:error
Bonjour, j’ai ce type d’erreur dans http.error meme apres avoir supprimé le plug in…
je ne comprends pas pourquoi…
Ca apparait tous les jours
0757|[Sun Sep 03 10:24:26.700374 2023] [access_compat:error] [pid 25288] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0758|[Sun Sep 03 10:24:27.725625 2023] [access_compat:error] [pid 12691] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0759|[Sun Sep 03 10:32:28.509562 2023] [access_compat:error] [pid 2903] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0760|[Sun Sep 03 10:33:04.331487 2023] [access_compat:error] [pid 4031] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0761|[Sun Sep 03 10:33:04.437517 2023] [access_compat:error] [pid 4066] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0762|[Sun Sep 03 11:06:29.107682 2023] [access_compat:error] [pid 13286] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0763|[Sun Sep 03 11:14:49.891697 2023] [access_compat:error] [pid 13286] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0764|[Sun Sep 03 11:14:49.966109 2023] [access_compat:error] [pid 4066] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0765|[Sun Sep 03 11:15:09.320562 2023] [access_compat:error] [pid 4031] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0766|[Sun Sep 03 12:33:13.904853 2023] [access_compat:error] [pid 9667] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0767|[Mon Sep 04 13:33:46.900836 2023] [access_compat:error] [pid 26596] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0768|[Mon Sep 04 14:12:11.312117 2023] [access_compat:error] [pid 5840] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0769|[Mon Sep 04 14:12:31.578696 2023] [access_compat:error] [pid 19548] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0770|[Mon Sep 04 14:12:42.942471 2023] [access_compat:error] [pid 22155] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0771|[Mon Sep 04 14:13:05.963025 2023] [access_compat:error] [pid 14824] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0772|[Mon Sep 04 14:17:23.798410 2023] [access_compat:error] [pid 27499] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0773|[Mon Sep 04 16:44:05.957715 2023] [access_compat:error] [pid 19548] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0774|[Mon Sep 04 16:44:05.986355 2023] [access_compat:error] [pid 22155] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0775|[Mon Sep 04 16:45:22.205129 2023] [access_compat:error] [pid 20475] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0776|[Mon Sep 04 17:10:50.539721 2023] [access_compat:error] [pid 16347] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0777|[Mon Sep 04 17:11:01.782323 2023] [access_compat:error] [pid 19548] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0778|[Mon Sep 04 17:11:01.902542 2023] [access_compat:error] [pid 25501] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0779|[Mon Sep 04 18:28:02.517521 2023] [access_compat:error] [pid 9054] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0780|[Mon Sep 04 18:51:19.952050 2023] [access_compat:error] [pid 25018] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0781|[Mon Sep 04 18:51:24.154490 2023] [access_compat:error] [pid 15095] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0782|[Mon Sep 04 18:51:24.255967 2023] [access_compat:error] [pid 25018] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0783|[Mon Sep 04 18:51:39.318009 2023] [access_compat:error] [pid 14824] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0784|[Mon Sep 04 19:48:30.815884 2023] [access_compat:error] [pid 14824] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
0785|[Mon Sep 04 19:49:13.185958 2023] [access_compat:error] [pid 25032] [client 20.54.163.231:0] AH01797: client denied by server configuration: /var/www/html/plugins/netatmopro
Peut-être le webhook… Je viens de regarder le code et je ne le supprime pas quand on désactive/supprime le plugin.
Peux-tu faire un disable de l’application sur le site https://dev.netatmo.com et voir si tu as toujours ces logs ?
Tout autre chose : puis-je savoir pourquoi tu as supprimé le plugin ?
car il a a eu tout un bazar avec la nouvelle authentification et les plug in netatmo du coup j’ai dépanné au plus vite.
et aussi car j’en avais marre de recevoir les mails de connexion. j’attendais que ce problème soit résolu pour le reinstaller car je trouve que les caméra sont mieux intégrées.
