J’ai un pb avec le plugin RFXCOM
La santé de mon Jeedom :
La conf du plugin :
La log RFXCOM_Pakages :
+ touch /tmp/jeedom_install_in_progress_rfxcom
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
Launch pre-install of rfxcom dependancy
WARNING: Skipping serial as it is not installed.
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 3
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
Fetched 44.1 kB in 2s (28.2 kB/s)
All packages are up to date.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3
python3 is already the newest version (3.9.2-3).
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pip
python3-pip is already the newest version (20.3.4-4+deb11u1).
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y build-essential
+ echo 7
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
python3-pyudev is already the newest version (0.22.0-2).
+ echo 8
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-dev
python3-dev is already the newest version (3.9.2-3).
+ echo 9
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
python3-requests is already the newest version (2.25.1+dfsg-2).
+ echo 10
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptools
python3-setuptools is already the newest version (52.0.0-4+deb11u1).
+ echo 11
++ find /usr/local/lib/python3.9/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ cut -f 2-
++ awk '$1 <= 4'
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 12
+ sudo pip3 cache purge
Files removed: 116
+ echo 13
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.9/dist-packages (24.2)
WARNING: Error parsing dependencies of gpg: Invalid version: '1.14.0-unknown'
+ echo 14
+ sudo python3 -m pip install --force-reinstall --upgrade six
Collecting six
Downloading six-1.16.0-py2.py3-none-any.whl.metadata (1.8 kB)
Downloading six-1.16.0-py2.py3-none-any.whl (11 kB)
Installing collected packages: six
Attempting uninstall: six
Found existing installation: six 1.16.0
Uninstalling six-1.16.0:
Successfully uninstalled six-1.16.0
Successfully installed six-1.16.0
+ echo 15
+ sudo python3 -m pip install --force-reinstall --upgrade requests
Collecting requests
Downloading requests-2.32.3-py3-none-any.whl.metadata (4.6 kB)
Collecting charset-normalizer<4,>=2 (from requests)
Downloading charset_normalizer-3.3.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (33 kB)
Collecting idna<4,>=2.5 (from requests)
Downloading idna-3.10-py3-none-any.whl.metadata (10 kB)
Collecting urllib3<3,>=1.21.1 (from requests)
Downloading urllib3-2.2.3-py3-none-any.whl.metadata (6.5 kB)
Collecting certifi>=2017.4.17 (from requests)
Downloading certifi-2024.8.30-py3-none-any.whl.metadata (2.2 kB)
Downloading requests-2.32.3-py3-none-any.whl (64 kB)
Downloading certifi-2024.8.30-py3-none-any.whl (167 kB)
Downloading charset_normalizer-3.3.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (142 kB)
Downloading idna-3.10-py3-none-any.whl (70 kB)
Downloading urllib3-2.2.3-py3-none-any.whl (126 kB)
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 2.2.3
Uninstalling urllib3-2.2.3:
Successfully uninstalled urllib3-2.2.3
Attempting uninstall: idna
Found existing installation: idna 3.10
Uninstalling idna-3.10:
Successfully uninstalled idna-3.10
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 3.3.2
Uninstalling charset-normalizer-3.3.2:
Successfully uninstalled charset-normalizer-3.3.2
Attempting uninstall: certifi
Found existing installation: certifi 2024.8.30
Uninstalling certifi-2024.8.30:
Successfully uninstalled certifi-2024.8.30
Attempting uninstall: requests
Found existing installation: requests 2.32.3
Uninstalling requests-2.32.3:
Successfully uninstalled requests-2.32.3
Successfully installed certifi-2024.8.30 charset-normalizer-3.3.2 idna-3.10 requests-2.32.3 urllib3-2.2.3
+ echo 16
+ sudo python3 -m pip install --force-reinstall --upgrade setuptools
Collecting setuptools
Downloading setuptools-75.1.0-py3-none-any.whl.metadata (6.9 kB)
Downloading setuptools-75.1.0-py3-none-any.whl (1.2 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 15.3 MB/s eta 0:00:00
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 75.0.0
Uninstalling setuptools-75.0.0:
Successfully uninstalled setuptools-75.0.0
Successfully installed setuptools-75.1.0
+ echo 17
+ sudo python3 -m pip install --force-reinstall --upgrade pyudev
Collecting pyudev
Downloading pyudev-0.24.3-py3-none-any.whl.metadata (4.6 kB)
Downloading pyudev-0.24.3-py3-none-any.whl (62 kB)
Installing collected packages: pyudev
Attempting uninstall: pyudev
Found existing installation: pyudev 0.24.3
Uninstalling pyudev-0.24.3:
Successfully uninstalled pyudev-0.24.3
Successfully installed pyudev-0.24.3
+ echo 18
+ sudo python3 -m pip install --force-reinstall --upgrade pyserial
Collecting pyserial
Downloading pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB)
Downloading pyserial-3.5-py2.py3-none-any.whl (90 kB)
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 19
+ sudo python3 -m pip install --force-reinstall --upgrade jeedomdaemon
Collecting jeedomdaemon
Downloading jeedomdaemon-0.11.2-py3-none-any.whl.metadata (5.0 kB)
Collecting aiohttp (from jeedomdaemon)
Downloading aiohttp-3.10.5-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (7.5 kB)
Collecting aiohappyeyeballs>=2.3.0 (from aiohttp->jeedomdaemon)
Downloading aiohappyeyeballs-2.4.0-py3-none-any.whl.metadata (5.9 kB)
Collecting aiosignal>=1.1.2 (from aiohttp->jeedomdaemon)
Downloading aiosignal-1.3.1-py3-none-any.whl.metadata (4.0 kB)
Collecting attrs>=17.3.0 (from aiohttp->jeedomdaemon)
Downloading attrs-24.2.0-py3-none-any.whl.metadata (11 kB)
Collecting frozenlist>=1.1.1 (from aiohttp->jeedomdaemon)
Downloading frozenlist-1.4.1-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (12 kB)
Collecting multidict<7.0,>=4.5 (from aiohttp->jeedomdaemon)
Downloading multidict-6.1.0-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (5.0 kB)
Collecting yarl<2.0,>=1.0 (from aiohttp->jeedomdaemon)
Downloading yarl-1.11.1-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (48 kB)
Collecting async-timeout<5.0,>=4.0 (from aiohttp->jeedomdaemon)
Downloading async_timeout-4.0.3-py3-none-any.whl.metadata (4.2 kB)
Collecting typing-extensions>=4.1.0 (from multidict<7.0,>=4.5->aiohttp->jeedomdaemon)
Downloading typing_extensions-4.12.2-py3-none-any.whl.metadata (3.0 kB)
Collecting idna>=2.0 (from yarl<2.0,>=1.0->aiohttp->jeedomdaemon)
Using cached idna-3.10-py3-none-any.whl.metadata (10 kB)
Downloading jeedomdaemon-0.11.2-py3-none-any.whl (12 kB)
Downloading aiohttp-3.10.5-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (1.2 MB)
Downloading aiohappyeyeballs-2.4.0-py3-none-any.whl (12 kB)
Downloading aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
Downloading async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Downloading attrs-24.2.0-py3-none-any.whl (63 kB)
Downloading frozenlist-1.4.1-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl (240 kB)
Downloading multidict-6.1.0-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (124 kB)
Downloading yarl-1.11.1-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (453 kB)
Using cached idna-3.10-py3-none-any.whl (70 kB)
Downloading typing_extensions-4.12.2-py3-none-any.whl (37 kB)
Installing collected packages: typing-extensions, idna, frozenlist, attrs, async-timeout, aiohappyeyeballs, multidict, aiosignal, yarl, aiohttp, jeedomdaemon
Attempting uninstall: typing-extensions
Found existing installation: typing_extensions 4.12.2
Uninstalling typing_extensions-4.12.2:
Successfully uninstalled typing_extensions-4.12.2
Attempting uninstall: frozenlist
Found existing installation: frozenlist 1.4.1
Uninstalling frozenlist-1.4.1:
Successfully uninstalled frozenlist-1.4.1
Attempting uninstall: attrs
Found existing installation: attrs 24.2.0
Uninstalling attrs-24.2.0:
Successfully uninstalled attrs-24.2.0
Attempting uninstall: async-timeout
Found existing installation: async-timeout 4.0.3
Uninstalling async-timeout-4.0.3:
Successfully uninstalled async-timeout-4.0.3
Attempting uninstall: aiohappyeyeballs
Found existing installation: aiohappyeyeballs 2.4.0
Uninstalling aiohappyeyeballs-2.4.0:
Successfully uninstalled aiohappyeyeballs-2.4.0
Attempting uninstall: multidict
Found existing installation: multidict 6.1.0
Uninstalling multidict-6.1.0:
Successfully uninstalled multidict-6.1.0
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.3.1
Uninstalling aiosignal-1.3.1:
Successfully uninstalled aiosignal-1.3.1
Attempting uninstall: yarl
Found existing installation: yarl 1.11.1
Uninstalling yarl-1.11.1:
Successfully uninstalled yarl-1.11.1
Attempting uninstall: aiohttp
Found existing installation: aiohttp 3.10.5
Uninstalling aiohttp-3.10.5:
Successfully uninstalled aiohttp-3.10.5
Attempting uninstall: jeedomdaemon
Found existing installation: jeedomdaemon 0.11.2
Uninstalling jeedomdaemon-0.11.2:
Successfully uninstalled jeedomdaemon-0.11.2
Successfully installed aiohappyeyeballs-2.4.0 aiohttp-3.10.5 aiosignal-1.3.1 async-timeout-4.0.3 attrs-24.2.0 frozenlist-1.4.1 idna-3.10 jeedomdaemon-0.11.2 multidict-6.1.0 typing-extensions-4.12.2 yarl-1.11.1
+ echo 20
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
+ echo 21
+ rm /tmp/jeedom_install_in_progress_rfxcom
Mes infos de config
OS version: debian 11 on RPI 4 B
PHP version: 7.4.33
Python version: 3.9.2
Core version: 4.4.14 (master)
Nb lines in http.error: 39
Plugins: jeelink jMQTT Monitoring rfxcom
jMQTT: 23.11.8 (2024-06-08 14:14:45) branch: stable
Nb Errors or Warnings in jMQTT logs: 0 (level is info)
Daemon Status: Started (2024-08-29 10:50:03)
Nb eqBrokers: 1 / eqLogics: 2 / cmds: 68
La log RFXCOMD :
[2024-09-16 17:14:22] ERROR : Timeout waiting status, is your rfxcom firmware up to date ?
Ce dernier fichier grossis très rapidement et le plugin ne fonctionne pas
Je l’ai arrêté avant qu’il ne sature l’espace disque
La passerelle RFXCOM a comme firmware le 1048
Avez vous une idée ?
Cordialement
Jean
