Erreur Timeline V4.1.20
Bonsoir a tous,
j’ai depuis un petit moment une impossibilité de me rendre sur la timeline.
Malgré la suppression des messages et la diminution ce la ne fonctionne pas.
voici ma config
Version : 4.1.20
Source : default
Branche : V4-stable
Système : diy
voici les logs
[Sun Mar 14 21:48:09.352704 2021] [php7:notice] [pid 18991] [client 192.168.1.47:61614] PHP Notice:  Undefined variable: br_before in /var/www/html/plugins/telecfree/core/class/telecfree.class.php on line 166, referer: http://192.168.1.150/index.php?v=d&p=dashboard
[Sun Mar 14 21:48:09.353369 2021] [php7:notice] [pid 18991] [client 192.168.1.47:61614] PHP Notice:  Undefined index: #Racourcis# in /var/www/html/plugins/telecfree/core/class/telecfree.class.php on line 179, referer: http://192.168.1.150/index.php?v=d&p=dashboard
[Sun Mar 14 21:49:41.878053 2021] [php7:error] [pid 12469] [client 192.168.1.47:61598] PHP Fatal error:  Allowed memory size of 268435456 bytes exhausted (tried to allocate 14696448 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: http://192.168.1.150/index.php?v=d&p=timeline
[Sun Mar 14 21:52:18.717768 2021] [php7:error] [pid 12437] [client 192.168.1.47:61616] PHP Fatal error:  Allowed memory size of 268435456 bytes exhausted (tried to allocate 14696448 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: http://192.168.1.150/index.php?v=d&p=timeline
[Sun Mar 14 22:02:23.059184 2021] [php7:notice] [pid 12469] [client 192.168.1.47:61795] PHP Notice:  Undefined variable: br_before in /var/www/html/plugins/telecfree/core/class/telecfree.class.php on line 166, referer: http://192.168.1.150/index.php?v=d&p=dashboard
[Sun Mar 14 22:02:23.067231 2021] [php7:notice] [pid 12469] [client 192.168.1.47:61795] PHP Notice:  Undefined index: #Racourcis# in /var/www/html/plugins/telecfree/core/class/telecfree.class.php on line 179, referer: http://192.168.1.150/index.php?v=d&p=dashboard
[Sun Mar 14 22:04:00.062731 2021] [php7:error] [pid 5782] [client 192.168.1.47:61786] PHP Fatal error:  Allowed memory size of 268435456 bytes exhausted (tried to allocate 14696448 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: http://192.168.1.150/index.php?v=d&p=timeline
Que puis-je faire.
Cordialement.
Le plugin telecfree désactivé ça fait pareil ?
L’information est effectivement interressante car je ne vois pas trop le lien avec la Timeline.
Quoi qu’il en soit, j’ai corrigé l’initialisation de ses 2 varriable
Bonsoir, idem avec tout les plugins désactivés
c’est donc pas l’origine de ton probleme
Non malheureusement, j’avais trouver sur le forum une histoire de mémoire.
Il faut que je retrouve le topic que je le remette ici
