Depuis quelques jours le plugin Dyson est HS pour moi, que ce soit la version beta ou stable, j’ai réinstallé les dépendances plusieurs fois, déco/reco, resynchro etc…
Voici le log
(node:32058) UnhandledPromiseRejectionWarning: StatusCodeError: 403 - "error code: 1020"
at new StatusCodeError (/var/www/html/plugins/dyson/resources/dysond/node_modules/request-promise-core/lib/errors.js:32:15)
at Request.plumbing.callback (/var/www/html/plugins/dyson/resources/dysond/node_modules/request-promise-core/lib/plumbing.js:104:33)
at Request.RP$callback [as _callback] (/var/www/html/plugins/dyson/resources/dysond/node_modules/request-promise-core/lib/plumbing.js:46:31)
at Request.self.callback (/var/www/html/plugins/dyson/resources/dysond/node_modules/request/request.js:185:22)
at Request.emit (events.js:315:20)
at Request.<anonymous> (/var/www/html/plugins/dyson/resources/dysond/node_modules/request/request.js:1154:10)
at IncomingMessage.<anonymous> (/var/www/html/plugins/dyson/resources/dysond/node_modules/request/request.js:1076:12)
at Object.onceWrapper (events.js:421:28)
at IncomingMessage.emit (events.js:327:22)
(Use `nodejs --trace-warnings ...` to show where the warning was created)
(node:32058) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:32058) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
[2021-06-09 18:27:33][ERROR] : Erreur exécution de la commande [Pièce principale][Dyson Pure Cool™][Rafraîchir] : Echec de la requête http : http://127.0.0.1:55026/device/sensor?id=VS8-EU-KEA1018A&apikey=b2SYFv0d5QFetekNHgZ1kutujACQ109q Curl error : Failed to connect to 127.0.0.1 port 55026: Connection refused
[2021-06-09 18:27:34][ERROR] : Erreur exécution de la commande [Pièce principale][Dyson Pure Cool™][Vitesse] : Echec de la requête http : http://127.0.0.1:55026/device/set?id=VS8-EU-KEA1018A&action=setFanSpeed&value=5&apikey=b2SYFv0d5QFetekNHgZ1kutujACQ109q Curl error : Failed to connect to 127.0.0.1 port 55026: Connection refused
[2021-06-09 18:27:34][ERROR] : Erreur exécution de la commande [Pièce principale][Dyson Pure Cool™][Vitesse] : Echec de la requête http : http://127.0.0.1:55026/device/set?id=VS8-EU-KEA1018A&action=setFanSpeed&value=6&apikey=b2SYFv0d5QFetekNHgZ1kutujACQ109q Curl error : Failed to connect to 127.0.0.1 port 55026: Connection refused
(node:3913) UnhandledPromiseRejectionWarning: StatusCodeError: 403 - "error code: 1020"
(node:3913) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:3913) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
