- beta installée et relance des dependances (au cas ou)
quand je vais dans la page de l’objet j’ai une erreur javascript (triangle avec ! en haut a droite) :
(http://192.168.xx.xx/core/php/getResource.php?file=plugins/worxLandroidS/desktop/js/worxLandroidS.js&md5=xxx&lang=fr_FR)
287 Uncaught TypeError: Cannot read properties of undefined (reading 'days')
Pour etre sur, j’ai delete l’objet et refait la synchro.
Et la… la tondeuse est retrouvée, avec les bonnes infos sur la page generale mais la page commande est vide, meme en cliquant sur « creer les commandes ». L’erreur javascript est tjrs présente
J’ai mis les logs en debug.
[2023-05-18 14:48:54][INFO] : Found 1 mower(s)
[2023-05-18 14:48:53][DEBUG] : params to send to daemon:{"action":"synchronize"}
[2023-05-18 14:48:54][DEBUG] : devices received:[{"id":60968,"uuid":"96c52f16-9ef6-4002-a3b4-9308298c8f3a","product_id":19,"serial_number":"30155002161028010226","mac_address":"0023A7A499C0","name":"L","locked":false,"sim":null,"mqtt_registered":true,"pin_code":"0455","registered_at":"2018-06-25 00:00:00","online":true,"protocol":0,"capabilities":{"__int__":0,"ready":false},"capabilities_available":[],"accessories":null,"purchased_at":"2018-05-18 00:00:00","setup_location":{"latitude":50.7524345,"longitude":3.2379542},"city":{"id":2798361,"country_id":56,"name":"Festingue","latitude":50.73333,"longitude":3.23333,"created_at":"2018-02-15 22:28:45","updated_at":"2018-02-15 22:28:45"},"time_zone":"Europe\/Brussels","improvement":true,"diagnostic":true,"mower_work_time":110582,"product":{"code":"WG797E.1","description":"Landroid L2000","year":2016,"cutting_width":220},"battery":{"cycles":{"total":3271,"current":0,"reset_at":null,"reset_time":null},"temperature":33.9,"voltage":25.91,"percent":30,"charging":true},"blades":{"total_on":94080,"reset_at":72857,"reset_time":"2022-05-09T10:54:59+02:00","current_on":21223},"chassis":[],"error":{"id":0,"description":"no error"},"orientation":{"pitch":0,"roll":0,"yaw":0},"rainsensor":{"delay":5},"status":{"id":1,"description":"home"},"zone":{"index":1,"indicies":[0,1,0,1,1,3,3,2,3,2],"starting_point":[21,75,106,1],"current":1},"warranty":{"expires_at":"2023-05-18T00:00:00+02:00","registered":true,"expired":true},"firmware":{"auto_upgrade":false,"version":"5.25"},"schedules":{"daily_progress":58,"next_schedule_start":"2023-05-19 09:00:00","time_extension":0,"active":true,"auto_schedule":{"settings":[],"enabled":false},"primary":{"monday":{"start":"09:00","end":"19:00","duration":600,"boundary":true},"tuesday":{"start":"09:00","end":"19:00","duration":600,"boundary":false},"wednesday":{"start":"09:00","end":"19:00","duration":600,"boundary":false},"thursday":{"start":"09:00","end":"19:00","duration":600,"boundary":true},"friday":{"start":"09:00","end":"19:00","duration":600,"boundary":false},"saturday":{"start":"09:00","end":"19:00","duration":600,"boundary":false},"sunday":{"start":"09:00","end":"17:00","duration":480,"boundary":false}}},"lawn":{"perimeter":null,"size":null},"in_topic":"DB504\/0023A7A499C0\/commandIn","out_topic":"DB504\/0023A7A499C0\/commandOut","rssi":64,"statistics":{"worktime_blades_on":94080,"distance":2582782,"worktime_total":110694},"updated":"18\/05\/2023 14:43:29","partymode_enabled":false}]
[2023-05-18 14:48:54][DEBUG] : create:online/En ligne
[2023-05-18 14:48:54][DEBUG] : create:pin_code/Code PIN
[2023-05-18 14:48:54][DEBUG] : create:gps_latitude/Latitude
[2023-05-18 14:48:54][DEBUG] : create:gps_longitude/Longitude
[2023-05-18 14:48:54][DEBUG] : create:battery_temperature/Température batterie
[2023-05-18 14:48:54][DEBUG] : create:battery_voltage/Tension batterie
[2023-05-18 14:48:54][DEBUG] : create:battery_percent/Batterie
[2023-05-18 14:48:54][DEBUG] : create:battery_charging/En charge
[2023-05-18 14:48:54][DEBUG] : create:battery_cycles_total/Cycles de charge
[2023-05-18 14:48:54][DEBUG] : create:blades_total_on/Temps de travail des lames totales
[2023-05-18 14:48:54][DEBUG] : create:blades_current_on/Temps de travail des lames actuelles
[2023-05-18 14:48:54][DEBUG] : create:status_id/Code statut
[2023-05-18 14:48:54][DEBUG] : create:status_description/Statut
[2023-05-18 14:48:54][DEBUG] : create:error_id/Code erreur
[2023-05-18 14:48:54][DEBUG] : create:error_description/Description erreur
[2023-05-18 14:48:54][DEBUG] : create:orientation_pitch/Tangage
[2023-05-18 14:48:54][DEBUG] : create:orientation_roll/Roulis
[2023-05-18 14:48:54][DEBUG] : create:orientation_yaw/Direction
[2023-05-18 14:48:54][DEBUG] : create:rainsensor_delay/Délai pluie
[2023-05-18 14:48:54][DEBUG] : create:rainsensor_triggered/Délai pluie activé
[2023-05-18 14:48:54][DEBUG] : create:rainsensor_remaining/Délai pluie restant
[2023-05-18 14:48:54][DEBUG] : create:statistics_distance/Distance
[2023-05-18 14:48:54][DEBUG] : create:statistics_worktime_total/Temps de travail tondeuse
[2023-05-18 14:48:54][DEBUG] : create:updated/Dernière mise à jour
[2023-05-18 14:48:54][DEBUG] : create:rssi/rssi
[2023-05-18 14:48:54][DEBUG] : create:refresh/Rafraichir
[2023-05-18 14:48:54][DEBUG] : create:update/update
[2023-05-18 14:48:54][DEBUG] : create:start/Démarrer
[2023-05-18 14:48:54][DEBUG] : create:home/Retour à la base
[2023-05-18 14:48:54][DEBUG] : create:safehome/Arrêter les lames et retour à la base
[2023-05-18 14:48:54][DEBUG] : create:pause/Pause
[2023-05-18 14:48:54][DEBUG] : create:zonetraining/Zone training
[2023-05-18 14:48:54][DEBUG] : create:setraindelay/Définir le délai pluie
[2023-05-18 14:48:54][DEBUG] : create:locked/Verrouillée
[2023-05-18 14:48:54][DEBUG] : create:lock/Verrouiller
[2023-05-18 14:48:54][DEBUG] : create:unlock/Déverrouiller
[2023-05-18 14:48:54][DEBUG] : create:cutedge/Routine de bord
[2023-05-18 14:48:54][DEBUG] : create:onetimeschedule/Horaire unique
[2023-05-18 14:48:54][DEBUG] : create:partymode_enabled/Mode festif
[2023-05-18 14:48:54][DEBUG] : create:setpartymode/Activer mode festif
[2023-05-18 14:48:54][DEBUG] : create:unsetpartymode/Désactiver mode festif
[2023-05-18 14:48:54][DEBUG] : create:schedules_daily_progress/Programme journalier
[2023-05-18 14:48:54][DEBUG] : create:schedules_active/Planification active
[2023-05-18 14:48:54][DEBUG] : create:activateschedules/Activer la planification
[2023-05-18 14:48:54][DEBUG] : create:deactivateschedules/Désactiver la planification
[2023-05-18 14:48:54][DEBUG] : create:zone_current/Zone actuelle
[2023-05-18 14:48:54][DEBUG] : create:zone_next_start/Zone prochain départ
[2023-05-18 14:48:54][DEBUG] : create:zone_starting_point_0/Départ zone 1
[2023-05-18 14:48:54][DEBUG] : create:zone_starting_point_1/Départ zone 2
[2023-05-18 14:48:54][DEBUG] : create:zone_starting_point_2/Départ zone 3
[2023-05-18 14:48:55][DEBUG] : create:zone_starting_point_3/Départ zone 4
[2023-05-18 14:48:55][DEBUG] : create:set_mowing_zone/Zone de travail
[2023-05-18 14:48:55][DEBUG] : create:set_zones_starting_point/Définir point de départ zones
[2023-05-18 14:48:55][INFO] : rain delay active for L
[2023-05-18 14:48:55][INFO] : Schedules updated for L
[2023-05-18 14:48:55][INFO] : Zone updated for L
[2023-05-18 14:49:11][DEBUG] : create:online/En ligne
[2023-05-18 14:49:11][DEBUG] : create:pin_code/Code PIN
[2023-05-18 14:49:11][DEBUG] : create:gps_latitude/Latitude
[2023-05-18 14:49:11][DEBUG] : create:gps_longitude/Longitude
[2023-05-18 14:49:11][DEBUG] : create:battery_temperature/Température batterie
[2023-05-18 14:49:11][DEBUG] : create:battery_voltage/Tension batterie
[2023-05-18 14:49:11][DEBUG] : create:battery_percent/Batterie
[2023-05-18 14:49:11][DEBUG] : create:battery_charging/En charge
[2023-05-18 14:49:11][DEBUG] : create:battery_cycles_total/Cycles de charge
[2023-05-18 14:49:11][DEBUG] : create:blades_total_on/Temps de travail des lames totales
[2023-05-18 14:49:11][DEBUG] : create:blades_current_on/Temps de travail des lames actuelles
[2023-05-18 14:49:11][DEBUG] : create:status_id/Code statut
[2023-05-18 14:49:11][DEBUG] : create:status_description/Statut
[2023-05-18 14:49:11][DEBUG] : create:error_id/Code erreur
[2023-05-18 14:49:11][DEBUG] : create:error_description/Description erreur
[2023-05-18 14:49:11][DEBUG] : create:orientation_pitch/Tangage
[2023-05-18 14:49:11][DEBUG] : create:orientation_roll/Roulis
[2023-05-18 14:49:11][DEBUG] : create:orientation_yaw/Direction
[2023-05-18 14:49:11][DEBUG] : create:rainsensor_delay/Délai pluie
[2023-05-18 14:49:11][DEBUG] : create:rainsensor_triggered/Délai pluie activé
[2023-05-18 14:49:11][DEBUG] : create:rainsensor_remaining/Délai pluie restant
[2023-05-18 14:49:11][DEBUG] : create:statistics_distance/Distance
[2023-05-18 14:49:11][DEBUG] : create:statistics_worktime_total/Temps de travail tondeuse
[2023-05-18 14:49:11][DEBUG] : create:updated/Dernière mise à jour
[2023-05-18 14:49:11][DEBUG] : create:rssi/rssi
[2023-05-18 14:49:11][DEBUG] : create:refresh/Rafraichir
[2023-05-18 14:49:11][DEBUG] : create:update/update
[2023-05-18 14:49:11][DEBUG] : create:start/Démarrer
[2023-05-18 14:49:11][DEBUG] : create:home/Retour à la base
[2023-05-18 14:49:11][DEBUG] : create:safehome/Arrêter les lames et retour à la base
[2023-05-18 14:49:11][DEBUG] : create:pause/Pause
[2023-05-18 14:49:11][DEBUG] : create:zonetraining/Zone training
[2023-05-18 14:49:11][DEBUG] : create:setraindelay/Définir le délai pluie
[2023-05-18 14:49:11][DEBUG] : create:locked/Verrouillée
[2023-05-18 14:49:11][DEBUG] : create:lock/Verrouiller
[2023-05-18 14:49:11][DEBUG] : create:unlock/Déverrouiller
[2023-05-18 14:49:11][DEBUG] : create:cutedge/Routine de bord
[2023-05-18 14:49:11][DEBUG] : create:onetimeschedule/Horaire unique
[2023-05-18 14:49:12][DEBUG] : create:partymode_enabled/Mode festif
[2023-05-18 14:49:12][DEBUG] : create:setpartymode/Activer mode festif
[2023-05-18 14:49:12][DEBUG] : create:unsetpartymode/Désactiver mode festif
[2023-05-18 14:49:12][DEBUG] : create:schedules_daily_progress/Programme journalier
[2023-05-18 14:49:12][DEBUG] : create:schedules_active/Planification active
[2023-05-18 14:49:12][DEBUG] : create:activateschedules/Activer la planification
[2023-05-18 14:49:12][DEBUG] : create:deactivateschedules/Désactiver la planification
[2023-05-18 14:49:12][DEBUG] : create:zone_current/Zone actuelle
[2023-05-18 14:49:12][DEBUG] : create:zone_next_start/Zone prochain départ
[2023-05-18 14:49:12][DEBUG] : create:zone_starting_point_0/Départ zone 1
[2023-05-18 14:49:12][DEBUG] : create:zone_starting_point_1/Départ zone 2
[2023-05-18 14:49:12][DEBUG] : create:zone_starting_point_2/Départ zone 3
[2023-05-18 14:49:12][DEBUG] : create:zone_starting_point_3/Départ zone 4
[2023-05-18 14:49:12][DEBUG] : create:set_mowing_zone/Zone de travail
[2023-05-18 14:49:12][DEBUG] : create:set_zones_starting_point/Définir point de départ zones
Forcement, l’objet est vide sur le dashboard (si widget non selectionné) et j’ai tjrs la meme erreur si j’active le widget.
Autre chose, meme si je sauve l’objet, il me dit tjrs en sortant qu’il n’est pas sauvé.
