Merci pour ta réponse, voici le fichier json
{"60":{"3901":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"18553":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"10687":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"536":{"activated":"1","state":"Activation Nuit : 19\/01\/2022 \u00e0 22:24","type":"string","force_update":"0","cmd":[]},"12795":{"activated":"1","state":"Tous les capteurs sont OK, activation de l'alarme Nuit (Total) : 19\/01\/2022 \u00e0 22:25","type":"string","force_update":"0","cmd":[]},"4231":{"activated":"1","state":1642618817,"type":"numeric","force_update":"0","cmd":[]},"3885":{"activated":"1","state":"Armement TOTAL : 19\/01\/2022 \u00e0 14:45","type":"string","force_update":"0","cmd":[]},"10689":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"18555":{"activated":"1","state":"Armement TOTAL : 19\/01\/2022 \u00e0 14:45","type":"string","force_update":"0","cmd":[]},"18557":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"3878":{"activated":"1","state":"Alerte mouvement NUIT (2) : 18","type":"string","force_update":"0","cmd":[]},"4229":{"activated":"1","state":"OK : 19\/01\/2022 \u00e0 19:59","type":"string","force_update":"0","cmd":[]},"10972":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"10975":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"10693":{"activated":"1","state":"OK : 18\/01\/2022 \u00e0 06:42","type":"string","force_update":"0","cmd":[]},"4698":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"15309":{"activated":"1","state":"Antoine : CHAUFFAGEVANNESALON Vanne Salon : CHGCONSIGNE (17.5\u00b0) : 19\/01\/2022 \u00e0 22:09","type":"string","force_update":"0","cmd":[]},"15301":{"activated":"1","state":"Antoine : MODE THERMOSTATS Les thermostats ne sont pas dans le m\u00eame mode : 1\nSalon=\u00c9co - Normal\nChb=Alternance autre thermostat - Normal : 19\/01\/2022 \u00e0 16:36","type":"string","force_update":"0","cmd":[]},"15999":{"activated":"1","state":"SCENARIO Lancement du scenario Sauvegarde STATCAPTURER : Commande=schedule, d\u00e9clencheur=schedule\/0, valeur=\/ : 19\/01\/2022 \u00e0 22:59","type":"string","force_update":"0","cmd":[]},"14174":{"activated":"1","state":"Tablette:Alarme NUIT maintenant arm\u00e9e, ne plus ouvrir la porte d'entr\u00e9e, les baies ou les portes du garage (30%) : 19\/01\/2022 \u00e0 22:24","type":"string","force_update":"0","cmd":[]},"13411":{"activated":"1","state":"0","type":"string","force_update":"0","cmd":[]},"15038":{"activated":"1","state":"Un visage inconnu a \u00e9t\u00e9 d\u00e9tect\u00e9 par la Welcome : 17\/01\/2022 \u00e0 12:50","type":"string","force_update":"0","cmd":[]},"3272":{"activated":"1","state":"<b>Mouvement<\/b> d\u00e9tect\u00e9","type":"string","force_update":"0","cmd":[]},"16127":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"16128":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"16129":{"activated":"1","state":"","type":"string","force_update":"0","cmd":[]},"21812":{"activated":"1","state":"SCENARIO Lancement du scenario Sauvegarde STATCAPTURER : Commande=schedule, d\u00e9clencheur=schedule\/0, valeur=\/","type":"string","force_update":"0","cmd":[]},"21813":{"activated":"1","state":"SCENARIO Lancement du scenario Sauvegarde STATCAPTURER : Commande=schedule, d\u00e9clencheur=schedule\/0, valeur=\/","type":"string","force_update":"0","cmd":[]},"21814":{"activated":"1","state":"DEBUG : Nouveau : SCENARIO Lancement du scenario Sauvegarde STATCAPTURER : Commande=schedule, d\u00e9clencheur=schedule\/0, valeur=\/ - Pr\u00e9c\u00e9dent : SCENARIO Lancement du scenario Alerte TabletteDebranche : Commande=other, d\u00e9clencheur=other\/0, valeur=\/","type":"string","force_update":"0","cmd":[]}}}
j’ai voulu te fournit un log alors j’ai refais un SAV + RESTORE et forcement plus l’erreur…
alors pas sur que le problème soit encore présent dans le json, je SAV tous les soirs
l’information qui posait soucie ne doit plus être présente pour le moment
EDIT : tu pourras me prévenir quand les ajoutes du mode SAUVEGARDE seront poussées en Stable, faudra que je repasse sur cette version
