avec la dernière version stable, problème lors de l’installation des dépendances
[2023-10-27 17:31:57] *************************************
[2023-10-27 17:31:57] * Launch install of dependencies *
[2023-10-27 17:31:58] Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
[2023-10-27 17:31:58] Get:2 http://www.deb-multimedia.org buster InRelease [18.1 kB]
[2023-10-27 17:31:58] Get:3 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
[2023-10-27 17:31:58] Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
[2023-10-27 17:31:58] Get:5 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
[2023-10-27 17:31:58] Hit:6 https://oph.mdrjr.net/meveric all InRelease
[2023-10-27 17:31:59] Hit:8 https://oph.mdrjr.net/meveric buster InRelease
[2023-10-27 17:31:59] Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
[2023-10-27 17:32:07] Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
[2023-10-27 17:32:07] *****************************
[2023-10-27 17:32:07] Install modules using apt-get
[2023-10-27 17:32:08] Building dependency tree...
[2023-10-27 17:32:08] Reading state information...
[2023-10-27 17:32:09] python3-pip is already the newest version (18.1-5).
[2023-10-27 17:32:09] python3 is already the newest version (3.7.3-1).
[2023-10-27 17:32:09] python3-dev is already the newest version (3.7.3-1).
[2023-10-27 17:32:09] python3-requests is already the newest version (2.21.0-1).
[2023-10-27 17:32:09] The following additional packages will be installed:
[2023-10-27 17:32:09] libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
[2023-10-27 17:32:09] python3.7 python3.7-dev python3.7-minimal python3.7-venv
[2023-10-27 17:32:09] Suggested packages:
[2023-10-27 17:32:09] python3.7-doc binfmt-support
[2023-10-27 17:32:10] The following NEW packages will be installed:
[2023-10-27 17:32:10] python3-venv python3.7-venv
[2023-10-27 17:32:10] The following packages will be upgraded:
[2023-10-27 17:32:10] libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
[2023-10-27 17:32:10] python3.7 python3.7-dev python3.7-minimal
[2023-10-27 17:32:10] 7 upgraded, 2 newly installed, 0 to remove and 259 not upgraded.
[2023-10-27 17:32:10] Need to get 8233 kB of archives.
[2023-10-27 17:32:10] After this operation, 57.3 kB of additional disk space will be used.
[2023-10-27 17:32:10] Err:1 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-dev arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] 404 Not Found [IP: 199.232.170.132 80]
[2023-10-27 17:32:10] Err:2 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7-dev arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] Err:3 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7 arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] Err:4 http://security.debian.org/debian-security buster/updates/main arm64 python3.7 arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] Err:5 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7-stdlib arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] Err:6 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-minimal arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] Err:7 http://security.debian.org/debian-security buster/updates/main arm64 libpython3.7-minimal arm64 3.7.3-2+deb10u4
[2023-10-27 17:32:10] Err:8 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-venv arm64 3.7.3-2+deb10u4
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-dev_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-dev_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-stdlib_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-minimal_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-minimal_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-venv_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 199.232.170.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[2023-10-27 17:32:10] Get:9 http://ftp.uk.debian.org/debian buster/main arm64 python3-venv arm64 3.7.3-1 [1180 B]
[2023-10-27 17:32:10] Fetched 1180 B in 0s (16.7 kB/s)
[2023-10-27 17:32:10] *************************************
[2023-10-27 17:32:10] Creating python 3 virtual environment
[2023-10-27 17:32:10] The virtual environment was not created successfully because ensurepip is not
[2023-10-27 17:32:10] available. On Debian/Ubuntu systems, you need to install the python3-venv
[2023-10-27 17:32:10] package using the following command.
[2023-10-27 17:32:10] apt-get install python3-venv
[2023-10-27 17:32:10] You may need to use sudo with that command. After installing the python3-venv
[2023-10-27 17:32:10] package, recreate your virtual environment.
[2023-10-27 17:32:10] Failing command: ['/var/www/html/plugins/worxLandroidS/resources/venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
[2023-10-27 17:32:10] Done
[2023-10-27 17:32:10] Install the required python libraries
/var/www/html/plugins/worxLandroidS/resources/venv/bin/python3: No module named pip
[2023-10-27 17:32:11] ***************************
[2023-10-27 17:32:11] * Install ended *
Désolé, mais il n’y a plus l’icone pour mettre du code…
Merci @Salvialf , je me souvenais pas du code
c’est bizarre que l’option ne soit pas plus présente non ?
