Nouvel utilisateur du plugin, j’ai, dans les log du plugin des erreurs qui reviennent toutes les 10 minutes et que je ne m’explique pas.
La com depuis la centrale Ax Pro fonctionne mais le log se rempli à grande vitesse.
Voici les logs (il n’y a pas d’avantage d’information en mode debug qu’en mode normal) :
[2026-04-19 07:31:14.124] ERROR : SIATCPHandler::process line: A19B003A"NULL"0000L0#010611[#0000|0000 00 000]_05:31:13,04-19-2026, exc: SIAEvent::__init__ line: A19B003A"NULL"0000L0#010611[#0000|0000 00 000]_05:31:13,04-19-2026 (no matches found)
[2026-04-19 07:31:14.124] ERROR : SIATCPHandler::handle exc: [Errno 104] Connection reset by peer
[2026-04-19 07:41:21.283] ERROR : SIATCPHandler::process line: 54D8003A"NULL"0000L0#010611[#0000|0000 00 000]_05:41:20,04-19-2026, exc: SIAEvent::__init__ line: 54D8003A"NULL"0000L0#010611[#0000|0000 00 000]_05:41:20,04-19-2026 (no matches found)
[2026-04-19 07:41:21.283] ERROR : SIATCPHandler::handle exc: [Errno 104] Connection reset by peer
[2026-04-19 07:51:28.414] ERROR : SIATCPHandler::process line: CC11003A"NULL"0000L0#010611[#0000|0000 00 000]_05:51:26,04-19-2026, exc: SIAEvent::__init__ line: CC11003A"NULL"0000L0#010611[#0000|0000 00 000]_05:51:26,04-19-2026 (no matches found)
[2026-04-19 07:51:28.414] ERROR : SIATCPHandler::handle exc: [Errno 104] Connection reset by peer
[2026-04-19 08:01:35.562] ERROR : SIATCPHandler::process line: 562C003A"NULL"0000L0#010611[#0000|0000 00 000]_06:01:33,04-19-2026, exc: SIAEvent::__init__ line: 562C003A"NULL"0000L0#010611[#0000|0000 00 000]_06:01:33,04-19-2026 (no matches found)
[2026-04-19 08:01:35.563] ERROR : SIATCPHandler::handle exc: [Errno 104] Connection reset by peer
[2026-04-19 08:11:42.678] ERROR : SIATCPHandler::process line: 85E2003A"NULL"0000L0#010611[#0000|0000 00 000]_06:11:40,04-19-2026, exc: SIAEvent::__init__ line: 85E2003A"NULL"0000L0#010611[#0000|0000 00 000]_06:11:40,04-19-2026 (no matches found)
[2026-04-19 08:11:42.679] ERROR : SIATCPHandler::handle exc: [Errno 104] Connection reset by peer
Merci d’avance
