Erreur: package architecture (arm64) does not match system (armhf)
Je démarre la domotique.
J’ai installé un Rpi4.
J’ai installé Jeedom 4.3.17
J’en suis à l’étape d’installer le plugin DECONZ, version 2023-02-16 01:01:43.
Lors de l’installation, je récupère ce log :
*             Installation deconz                      *
Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:3 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Fetched 13.6 MB in 6s (2460 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
libqt5serialport5 is already the newest version (5.15.2-2).
libqt5websockets5 is already the newest version (5.15.2-2).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
sqlite3 is already the newest version (3.34.1-3).
It's arm64, RPI
--2023-08-31 20:36:53--  https://images.jeedom.com/resources/deconz/arm64/deconz.deb
Resolving images.jeedom.com (images.jeedom.com)... 57.128.120.126
Connecting to images.jeedom.com (images.jeedom.com)|57.128.120.126|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6785632 (6.5M) [application/vnd.debian.binary-package]
Saving to: '/tmp/deconz.deb'
     0K .......... .......... .......... .......... ..........  0%  966K 7s
    50K .......... .......... .......... .......... ..........  1% 6.70M 4s
   100K .......... .......... .......... .......... ..........  2% 1.75M 4s
   150K .......... .......... .......... .......... ..........  3% 11.0M 3s
   200K .......... .......... .......... .......... ..........  3% 9.84M 2s
   250K .......... .......... .......... .......... ..........  4% 2.37M 2s
   300K .......... .......... .......... .......... ..........  5% 8.35M 2s
   350K .......... .......... .......... .......... ..........  6% 12.3M 2s
   400K .......... .......... .......... .......... ..........  6% 11.3M 2s
   450K .......... .......... .......... .......... ..........  7% 6.37M 2s
   500K .......... .......... .......... .......... ..........  8% 5.85M 2s
   550K .......... .......... .......... .......... ..........  9% 5.96M 2s
   600K .......... .......... .......... .......... ..........  9% 9.79M 1s
   650K .......... .......... .......... .......... .......... 10% 12.8M 1s
   700K .......... .......... .......... .......... .......... 11% 9.78M 1s
   750K .......... .......... .......... .......... .......... 12% 13.5M 1s
   800K .......... .......... .......... .......... .......... 12% 3.65M 1s
   850K .......... .......... .......... .......... .......... 13% 9.60M 1s
   900K .......... .......... .......... .......... .......... 14% 10.4M 1s
   950K .......... .......... .......... .......... .......... 15% 8.39M 1s
  1000K .......... .......... .......... .......... .......... 15% 8.61M 1s
  1050K .......... .......... .......... .......... .......... 16% 10.7M 1s
  1100K .......... .......... .......... .......... .......... 17% 11.0M 1s
  1150K .......... .......... .......... .......... .......... 18% 6.77M 1s
  1200K .......... .......... .......... .......... .......... 18% 8.63M 1s
  1250K .......... .......... .......... .......... .......... 19% 12.0M 1s
  1300K .......... .......... .......... .......... .......... 20% 5.69M 1s
  1350K .......... .......... .......... .......... .......... 21% 9.10M 1s
  1400K .......... .......... .......... .......... .......... 21% 14.1M 1s
  1450K .......... .......... .......... .......... .......... 22% 13.2M 1s
  1500K .......... .......... .......... .......... .......... 23% 10.1M 1s
  1550K .......... .......... .......... .......... .......... 24% 12.6M 1s
  1600K .......... .......... .......... .......... .......... 24% 5.60M 1s
  1650K .......... .......... .......... .......... .......... 25% 7.47M 1s
  1700K .......... .......... .......... .......... .......... 26% 10.0M 1s
  1750K .......... .......... .......... .......... .......... 27% 9.78M 1s
  1800K .......... .......... .......... .......... .......... 27% 14.0M 1s
  1850K .......... .......... .......... .......... .......... 28% 12.9M 1s
  1900K .......... .......... .......... .......... .......... 29% 10.7M 1s
  1950K .......... .......... .......... .......... .......... 30%  476K 1s
  2000K .......... .......... .......... .......... .......... 30% 14.7M 1s
  2050K .......... .......... .......... .......... .......... 31% 11.3M 1s
  2100K .......... .......... .......... .......... .......... 32% 14.3M 1s
  2150K .......... .......... .......... .......... .......... 33% 12.0M 1s
  2200K .......... .......... .......... .......... .......... 33% 13.5M 1s
  2250K .......... .......... .......... .......... .......... 34% 5.87M 1s
  2300K .......... .......... .......... .......... .......... 35% 8.41M 1s
  2350K .......... .......... .......... .......... .......... 36% 14.1M 1s
  2400K .......... .......... .......... .......... .......... 36% 7.69M 1s
  2450K .......... .......... .......... .......... .......... 37% 12.7M 1s
  2500K .......... .......... .......... .......... .......... 38% 9.54M 1s
  2550K .......... .......... .......... .......... .......... 39% 14.3M 1s
  2600K .......... .......... .......... .......... .......... 39% 7.70M 1s
  2650K .......... .......... .......... .......... .......... 40% 10.4M 1s
  2700K .......... .......... .......... .......... .......... 41% 7.38M 1s
  2750K .......... .......... .......... .......... .......... 42% 11.4M 1s
  2800K .......... .......... .......... .......... .......... 43% 13.8M 1s
  2850K .......... .......... .......... .......... .......... 43% 12.8M 1s
  2900K .......... .......... .......... .......... .......... 44% 9.83M 1s
  2950K .......... .......... .......... .......... .........
. 45%  452K 1s
  3000K .......... .......... .......... .......... .......... 46% 8.74M 1s
  3050K .......... .......... .......... .......... .......... 46% 13.5M 1s
  3100K .......... .......... .......... .......... .......... 47% 11.6M 1s
  3150K .......... .......... .......... .......... .......... 48% 10.4M 1s
  3200K .......... .......... .......... .......... .......... 49% 9.93M 1s
  3250K .......... .......... .......... .......... .......... 49% 7.25M 1s
  3300K .......... .......... .......... .......... .......... 50% 11.3M 1s
  3350K .......... .......... .......... .......... .......... 51% 13.8M 1s
  3400K .......... .......... .......... .......... .......... 52% 12.8M 1s
  3450K .......... .......... .......... .......... .......... 52% 11.9M 1s
  3500K .......... .......... .......... .......... .......... 53% 13.1M 1s
  3550K .......... .......... .......... .......... .......... 54% 13.0M 1s
  3600K .......... .......... .......... .......... .......... 55% 4.30M 1s
  3650K .......... .......... .......... .......... .......... 55% 12.9M 1s
  3700K .......... .......... .......... .......... .......... 56% 11.2M 1s
  3750K .......... .......... .......... .......... .......... 57% 10.6M 1s
  3800K .......... .......... .......... .......... .......... 58% 9.03M 0s
  3850K .......... .......... .......... .......... .......... 58% 8.49M 0s
  3900K .......... .......... .......... .......... .......... 59% 13.2M 0s
  3950K .......... .......... .......... .......... .......... 60%  446K 1s
  4000K .......... .......... .......... .......... .......... 61% 13.1M 1s
  4050K .......... .......... .......... .......... .......... 61% 11.6M 1s
  4100K .......... .......... .......... .......... .......... 62% 16.3M 0s
  4150K .......... .......... .......... .......... .......... 63% 9.97M 0s
  4200K .......... .......... .......... .......... .......... 64% 13.9M 0s
  4250K .......... .......... .......... .......... .......... 64% 11.3M 0s
  4300K .......... .......... .......... .......... .......... 65% 14.2M 0s
  4350K .......... .......... .......... .......... .......... 66% 10.8M 0s
  4400K .......... .......... .......... .......... .......... 67% 10.9M 0s
  4450K .......... .......... .......... .......... .......... 67% 11.1M 0s
  4500K .......... .......... .......... .......... .......... 68% 13.9M 0s
  4550K .......... .......... .......... .......... .......... 69% 13.1M 0s
  4600K .......... .......... .......... .......... .......... 70% 9.02M 0s
  4650K .......... .......... .......... .......... .......... 70% 10.3M 0s
  4700K .......... .......... .......... .......... .......... 71% 12.8M 0s
  4750K .......... .......... .......... .......... .......... 72% 8.61M 0s
  4800K .......... .......... .......... .......... .......... 73% 13.1M 0s
  4850K .......... .......... .......... .......... .......... 73% 12.3M 0s
  4900K .......... .......... .......... .......... .......... 74% 10.3M 0s
  4950K .......... .......... .......... .......... .......... 75%  416K 0s
  5000K .......... .......... .......... .......... .......... 76% 13.1M 0s
  5050K .......... .......... .......... .......... .......... 76% 10.2M 0s
  5100K .......... .......... .......... .......... .......... 77% 13.1M 0s
  5150K .......... .......... .......... .......... .......... 78% 9.81M 0s
  5200K .......... .......... .......... .......... .......... 79% 13.2M 0s
  5250K .......... .......... .......... .......... .......... 79% 7.97M 0s
  5300K .......... .......... .......... .......... .......... 80% 8.81M 0s
  5350K .......... .......... .......... .......... .......... 81% 12.5M 0s
  5400K .......... .......... .......... .......... .......... 82% 12.7M 0s
  5450K .......... .......... .......... .......... .......... 82% 10.3M 0s
  5500K .......... .......... .......... .......... .......... 83% 12.3M 0s
  5550K .......... .......... .......... .......... .......... 84% 9.38M 0s
  5600K .......... .......... .......... .......... .......... 85% 11.9M 0s
  5650K .......... .......... .......... .......... .......... 86% 12.7M 0s
  5700K .......... .......... .......... .......... .......... 86% 14.3M 0s
  5750K .......... .......... .......... .......... .......... 87% 9.55M 0s
  5800K .......... .......... .......... .......... .......... 88% 14.3M 0s
  5850K .......... .......... .......... .......... .......... 89% 9.20M 0s
  5900K .......... .......... .......... .......... .......... 89% 13.5M 0s
  5950K .......... .......... .......... .......... .......... 90%  402K 0s
  6000K .......... .......... .......... .......... .......... 91% 13.7M 0s
  6050K .......... .......... .......... .......... .......... 92% 11.2M 0s
  6100K .......... .......... .......... .......... .......... 92% 13.5M 0s
  6150K .......... .......... .......... .......... .......... 93% 9.90M 0s
  6200K .......... .......... .......... .......... .......... 94% 13.5M 0s
  6250K .......... .......... .......... .......... .......... 95% 11.5M 0s
  6300K .......... .......... .......... .......... .......... 95% 10.0M 0s
  6350K .......... .......... .......... .......... .......... 96% 11.3M 0s
  6400K .......... .......... .......... .......... .......... 97% 14.3M 0s
  6450K .......... .......... .......... .......... .......... 98% 8.76M 0s
  6500K .......... .......... .......... .......... .......... 98% 11.9M 0s
  6550K .......... .......... .......... .......... .......... 99% 11.9M 0s
  6600K .......... .......... ......                          100% 7.64M=1.3s
2023-08-31 20:36:55 (5.09 MB/s) - '/tmp/deconz.deb' saved [6785632/6785632]
dpkg: error processing archive /tmp/deconz.deb (--install):
Errors were encountered while processing:
 /tmp/deconz.deb
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Fetched 4586 B in 1s (6372 B/s)
Failed to disable unit: Unit file deconz-gui.service does not exist.
Failed to stop deconz-gui.service: Unit deconz-gui.service not loaded.
Failed to disable unit: Unit file deconz.service does not exist.
Failed to stop deconz.service: Unit deconz.service not loaded.
*             Installation terminée                    *
Je reçois l’erreur: package architecture (arm64) does not match system (armhf)
L’installation étant incomplète, ma clé ConbeeII ne semble pas reconnue.
Une idée ?
Voir ici : Impossible d'ouvrir phoscon - #18 par akenad
akenad :slight_smile:
J’ai parcouru le post.
J’ai les retours suivants:
arch
aarch64
dpkg --print-architecture
armhf
Du coup, je comprends que cela confirme l’anomalie.
En lisant le précédent post, je comprends que je dois procéder à une réinstallation de Jeedom. Est-ce exact ?
Pourquoi la dernière version stable de Jeedom génère cette anomalie ?
Guillaume
Je constate le même soucis chez moi.
Tu as réinstallé du coup ?
Tu peux forcer la mise à jour de jeedom depuis le centre de mise à jour. Mais il faudrait mieux que tu ouvres ton propre post avec tes informations: logs deconz, page santé jeedom, etc.
