Je rencontre l’erreur suivante sur renouvellement du certificat letsencrypt. De mémoire, j’avais suivi ce tuto pour l’installer : Comment sécuriser l'accès à Jeedom en HTTPS avec un certificat SSL gratuit - Page 3 sur 3
L’erreur en question :
> $ certbot renew
File "/snap/certbot/4194/bin/certbot", line 5, in <module>
from certbot.main import main
File "/snap/certbot/4194/lib/python3.12/site-packages/certbot/main.py", line 6, in <module>
from certbot._internal import main as internal_main
File "/snap/certbot/4194/lib/python3.12/site-packages/certbot/_internal/main.py", line 20, in <module>
import josepy as jose
File "/snap/certbot/4194/lib/python3.12/site-packages/josepy/__init__.py", line 40, in <module>
from josepy.json_util import (
File "/snap/certbot/4194/lib/python3.12/site-packages/josepy/json_util.py", line 24, in <module>
from OpenSSL import crypto
File "/snap/certbot/4194/lib/python3.12/site-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import SSL, crypto
File "/snap/certbot/4194/lib/python3.12/site-packages/OpenSSL/SSL.py", line 11, in <module>
from OpenSSL._util import (
File "/snap/certbot/4194/lib/python3.12/site-packages/OpenSSL/_util.py", line 6, in <module>
from cryptography.hazmat.bindings.openssl.binding import Binding
File "/snap/certbot/4194/lib/python3.12/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
from cryptography.exceptions import InternalError
File "/snap/certbot/4194/lib/python3.12/site-packages/cryptography/exceptions.py", line 9, in <module>
from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
**RuntimeError: OpenSSL 3.0's legacy provider failed to load. This is a fatal error by default, but cryptography supports running without legacy algorithms by setting the environment variable CRYPTOGRAPHY_OPENSSL_NO_LEGACY. If you did not expect this error, you have likely made a mistake with your OpenSSL configuration**.
Ma version d’OpenSSL :
$ openssl version
OpenSSL 1.1.1n 15 Mar 2022
J’a cru comprendre du post suivant qu’il y avait une histoire de version d’OpenSSL, de variable d’environnement « CRYPTOGRAPHY_OPENSSL_NO_LEGACY=1 », puis de mise à jour de certbot :
Quelqu’un peut-il me donner les commande à entrer sur mon RPi en Debian 10.13 pour régler ce problème ?
