vu ce matin dans mes logs jeedom cron-execution , le plugin n’a pas été mis à jour, la seule mise à jour faite est le plugin wifilightV2
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::requestToArray() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 79
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::getModuleRequest() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 949
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::getModuleRequest() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 952
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::getModuleRequest() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 958
PHP Deprecated: Non-static method olindoteTools::network_sendRequestByCurl() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 966
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::requestToArray() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 979
PHP Deprecated: Non-static method discordlink::checkall() should not be called statically in /var/www/html/plugins/discordlink/core/class/discordlink.class.php on line 157
PHP Deprecated: Non-static method olindoteTools::eqlogicHtml_getWidgetCacheName() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 193
PHP Deprecated: Non-static method olindoteTools::network_setHealth() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 984
PHP Deprecated: Non-static method olindoteTools::getObjName() should not be called statically in /var/www/html/data/custom/olindote/php/olindoteTools.class.php on line 193
PHP Deprecated: Non-static method olindoteTools::network_setStatut() should not be called statically in /var/www/html/data/custom/olindote/php/olindoteTools.class.php on line 205
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::requestToArray() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 859
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::getModuleRequest() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 861
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::getModuleRequest() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 934
