depuis les 2 dernières béta (23/09 installée), j’ai cette erreur mysql qui pop lors du cronDaily de minuit :
[2020-09-22 00:00:05][ERROR] : Erreur sur la fonction cronDaily du plugin : [MySQL] Error code : 22007 (1366). Incorrect integer value: '' for column `jeedom`.`cmd`.`isVisible` at row 1 : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2020-09-23 00:00:05][ERROR] : Erreur sur la fonction cronDaily du plugin : [MySQL] Error code : 22007 (1366). Incorrect integer value: '' for column `jeedom`.`cmd`.`isVisible` at row 1 : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2020-09-24 00:00:05][ERROR] : Erreur sur la fonction cronDaily du plugin : [MySQL] Error code : 22007 (1366). Incorrect integer value: '' for column `jeedom`.`cmd`.`isVisible` at row 1 : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
