Voici l’erreur :
`[START BACKUP]
***************Start of Jeedom backup at 2022-12-21 10:48:42***************
Send begin backup event...OK
Checking files rights...
OK
Checking database...
mysqlcheck: Got error: 2013: Lost connection to MySQL server during query when executing 'CHECK TABLE ... '
OK
Backing up database...mysqldump: Got error: 2002: "Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)" when trying to connect
Error during backup: Backing up database failed. Check mysqldump installation. Code: 2Details : Array
[END BACKUP ERROR]
PHP Fatal error: Uncaught Exception: Backing up database failed. Check mysqldump installation. Code: 2 in /var/www/html/install/backup.php:104
Stack trace:
#0 {main}
thrown in /var/www/html/install/backup.php on line 104`
Il faut noter qu’il y a associé des soucis qui s’arrangent après un reboot comme des infos capteurs qui ne s’affichent pas alors qu’elles arrivent.
Page santé tout est vert
J’ai fait toutes les vérifications système sans souci
Tentative de dump :
mysqldump: Error 2013: Lost connection to MySQL server during query when dumping table `historyArch` at row: 16751028
