Erreur log RteEcoWatt : getResourceRTE ----- CURL return code: 500 URL:
Ma log est truffée de ces messages RteEcowatt :
2025-06-01 18:35:05 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-39813c689b46b19d43c95046 } }] Log rteEcowatt
2025-06-01 18:34:05 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-fd803c68091db262f354de1e } }] Log rteEcowatt
2025-06-01 18:33:04 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-c0803c689e307b28d3d6406e } }] Log rteEcowatt
2025-06-01 18:32:04 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-84803c68a4217675edca9bdd } }] Log rteEcowatt
2025-06-01 18:31:04 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-48803c68e3f72f30b786dfb7 } }] Log rteEcowatt
2025-06-01 18:30:07 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-0e803c6854eddf345267017c } }] Log rteEcowatt
2025-06-01 18:29:04 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-d07f3c68efe1b838d7394608 } }] Log rteEcowatt
2025-06-01 18:28:05 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-957f3c6820f6ef6422031b35 } }] Log rteEcowatt
2025-06-01 18:27:05 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-597f3c6840ebeca00f290341 } }] Log rteEcowatt
2025-06-01 18:26:05 rteEcowatt getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ error:TMPLIKSUPCON_COMMON_T05, error_description:Internal Server Error, error_uri:, error_details: { transaction_id:Id-1d7f3c6881c4c6c81dc54979 } }] Log rteEcowatt
Le plugin semble bien fonctionner et il remonte les infos dont j’ai besoin.
Que puis-je faire pour m’en débarraser ?
Je ne trouve rien sur le net…
Par avance merci
C’est une erreur 500 sur le serveur RTE. Le plugin le signale dans les logs et réessayera dans l’heure suivante.
J’ai eu aussi quelques lignes d’erreur 500 le 15 mai entre 10h30 et 17h.
Ce qui n’est pas normal chez vous, c’est qu’il réessaye la minute suivante.
Dans le moteur des taches, pouvez-vous montrer la programmation de la tache pullDataEcowatt:
Merci pour la réponse rapide.
Je ne connaissais pas cette entrée, voici ce que j’ai :
Cordialement.
Même symptôme même erreur chez moi…
[2025-07-18 12:30:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-2a227a6884cbee8951fb4a00" 	} }]
[2025-07-19 02:00:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-02e07a688983f95933cca7ff" 	} }]
[2025-07-19 08:00:03] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-62347b6874f201dc974b2544" 	} }]
[2025-07-19 10:30:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-8a577b68bde299eabb03fefe" 	} }]
[2025-07-19 11:30:03] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-9b657b68061a812f0b160aae" 	} }]
[2025-07-19 11:51:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/ecowatt/v5/signals response: [{ 	"error":"COMMON_ERROR_T03", 	"error_description":"Error code unknown", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-866a7b68001ff8c0a7c48e74" 	} }]
[2025-07-19 11:51:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars response: [{ 	"error":"COMMON_ERROR_T03", 	"error_description":"Error code unknown", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-866a7b68805cb3f4301650a3" 	} }]
[2025-07-19 12:00:03] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-a36c7b68bbdcffde769964c0" 	} }]
[2025-07-19 12:30:03] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-ab737b68cdda839a3ad93599" 	} }]
[2025-07-19 15:30:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-da9d7b68379ea5e7b4a76e55" 	} }]
[2025-07-19 15:51:01] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/ecowatt/v5/signals response: [{ 	"error":"COMMON_ERROR_T03", 	"error_description":"Error code unknown", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-c5a27b686c90a1ed1986448c" 	} }]
[2025-07-19 16:00:04] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-e4a47b6832061e4a69df55eb" 	} }]
[2025-07-19 17:30:02] ERROR  : getResourceRTE ----- CURL return code: 500 URL: https://digital.iservices.rte-france.com/open_api/consumption/v1/short_term response: [{ 	"error":"CONSUMPTION_COMMON_T05", 	"error_description":"Internal Server Error.", 	"error_uri": "", 	"error_details": { 		"transaction_id":"Id-fab97b68e68849fb614ce6b9" 	} }]
des idées ?
Merci d’avance
Fabrice
Bonjour.
Je n’ai pas d’autre explication que celle donnée au dessus. :thinking:
Idem de mon coté depuis quelques jours. J’ai essayé de vérifier coté API RTE mais je ne vois plus les api auquel je suis abonné. Quand j’essaye de me réabonner j’ai une erreur interne serveur qui apparait… Bizarre
Ludovic
De mon coté c’est résolu, j’ai supprimé l’API web coté RTE et tout recommencer et cela fonctionne depuis 24h
Ludo
Quand il y a une erreur 500, il n’y a qu’à attendre que le serveur en face (RTE dans ce cas) retombe en marche.
Bonjour, j’ai également le même soucis donc j’ai supprimé le plugin ainsi que l’appli sur le site RTE pour refaire une installation « neuve ». Pour le moment je n’ai pas de données qui remontent et j’ai en revanche toujours le même message d’erreur que signalé dans ce fil…
Du coup j’ai du mal à savoir si le soucis vient réellement du site RTE.
Si vous avez d’autres idées je suis intéressé, sinon tant pis mais c’est un peu inutilisable à la longue :-S.
Si de temps en temps quelques messages dans le centre des messages de Jeedom rende le plugin inutilisable pour vous, vous pouvez dans votre configuration Jeedom sur l’onglet Logs décocher :
Bonjour, en effet c’est sûrement le plus simple. Ça reste surprenant comme fonctionnement car avant il n’y avait pas d’erreurs et subitement ce sont des dizaines de messages par jour donc ça remplit le log de défauts inutilement. Enfin voilà je vais simplement le désactiver pour ce plugin.
Merci pour le conseil
Dispo dans la beta de la nuit prochaine, la réduction du niveau de log d’error à warning pour cette erreur coté serveurs RTE.
j 'ai installé le plugin RTE ECO watt il y a 3jours avec le code en base 64.
Je n’ai toujours pas de retour de la couleur TEMPO et dans le widget j’ai un texte quidit;
dernière requete rte le 01/07/1970.
Est-ce que le plugin marche ?
Y a t il quelque chose à faire ?
Rien dans le log du plugin ni dans le log http.error ?
salut Jpty
le log http.error aucune alerte
celui du plugin c est autre chose`Texte préf
[2025-11-13 16:40:02][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 16:40:02][DEBUG] : RTE REQUESTS DATES: 2025-09-01T00:00:00+02:00 2025-11-15T00:00:00+01:00, LatestOK: 2025-11-13T16:40:02+01:00
[2025-11-13 16:40:02][DEBUG] :   initParamRTE tempoRTE ReUSE token till: 17:32:03
[2025-11-13 16:40:02][DEBUG] : ----- CURL getResourceRTE URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 16:40:02][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 16:40:02][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 16:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 16:57:04][DEBUG] : RTE REQUESTS DATES: 2025-09-01T00:00:00+02:00 2025-11-15T00:00:00+01:00, LatestOK: 2025-11-13T16:57:04+01:00
[2025-11-13 16:57:04][DEBUG] :   initParamRTE tempoRTE ReUSE token till: 17:32:03
[2025-11-13 16:57:04][DEBUG] : ----- CURL getResourceRTE URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 16:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 16:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 17:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 17:57:04][DEBUG] : RTE REQUESTS DATES: 2025-09-01T00:00:00+02:00 2025-11-15T00:00:00+01:00, LatestOK: 2025-11-13T17:57:04+01:00
[2025-11-13 17:57:05][DEBUG] : getNewTokenRTE {   "access_token" : "Ilgi84Kt74tMiWBrtXoRuPJeWJBFai2FR9Tjfm75rrFg15milp5LRM",   "token_type" : "Bearer",   "expires_in" : 3600 }
[2025-11-13 17:57:05][DEBUG] :   initParamRTE tempoRTE NEW token. Expires: 18:56:45
[2025-11-13 17:57:05][DEBUG] : ----- CURL getResourceRTE URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 17:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 17:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 18:57:05][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 18:57:05][DEBUG] : RTE REQUESTS DATES: 2025-09-01T00:00:00+02:00 2025-11-15T00:00:00+01:00, LatestOK: 2025-11-13T18:57:05+01:00
[2025-11-13 18:57:05][DEBUG] : getNewTokenRTE {   "access_token" : "KbzH3ne6P4KzzfWfYQAOFTIcpX0pQ1YeMWiyR0rsVKk1GnT3BV2JgK",   "token_type" : "Bearer",   "expires_in" : 3600 }
[2025-11-13 18:57:05][DEBUG] :   initParamRTE tempoRTE NEW token. Expires: 19:56:45
[2025-11-13 18:57:05][DEBUG] : ----- CURL getResourceRTE URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 18:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 18:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 19:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 19:57:04][DEBUG] : RTE REQUESTS DATES: 2025-09-01T00:00:00+02:00 2025-11-15T00:00:00+01:00, LatestOK: 2025-11-13T19:57:04+01:00
[2025-11-13 19:57:04][DEBUG] : getNewTokenRTE {   "access_token" : "NhZDqZYHJPhlm8d63JYf4XMNubFEMg0ozX3OoCn6wMtynm3hLPHdUc",   "token_type" : "Bearer",   "expires_in" : 3600 }
[2025-11-13 19:57:04][DEBUG] :   initParamRTE tempoRTE NEW token. Expires: 20:56:44
[2025-11-13 19:57:04][DEBUG] : ----- CURL getResourceRTE URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 19:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 19:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 20:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 20:57:04][DEBUG] : RTE REQUESTS DATES: 2025-09-01T00:00:00+02:00 2025-11-15T00:00:00+01:00, LatestOK: 2025-11-13T20:57:04+01:00
[2025-11-13 20:57:04][DEBUG] : getNewTokenRTE {   "access_token" : "VY5HtgPgFXBjiS6iJd4Q8Vq11irwGcrCE832z0hj2cck0GJuAmlOkf",   "token_type" : "Bearer",   "expires_in" : 3600 }
[2025-11-13 20:57:04][DEBUG] :   initParamRTE tempoRTE NEW token. Expires: 21:56:44
[2025-11-13 20:57:04][DEBUG] : ----- CURL getResourceRTE URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 20:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 20:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 21:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 21:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 21:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 22:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 22:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 22:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-13 23:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-13 23:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-15T00:00:00+01:00&fallback_status=false
[2025-11-13 23:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 00:00:08][WARNING] : Expiration date of Tempo prices not defined
[2025-11-14 06:18:48][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 1
[2025-11-14 06:18:49][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 06:18:49][WARNING] : decData vide getTempoData(0,1)
[2025-11-14 06:18:57][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 06:18:57][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 06:18:57][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 10:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 10:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 10:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 11:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 1
[2025-11-14 11:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 11:57:04][WARNING] : decData vide getTempoData(0,1)
[2025-11-14 12:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 12:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 12:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 13:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 13:57:07][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 13:57:07][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 14:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 14:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 14:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 15:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 15:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 15:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 16:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 16:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 16:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 17:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 17:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 17:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 18:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 18:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 18:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 19:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 19:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 19:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 20:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 20:57:04][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 20:57:04][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 21:57:05][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 21:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 21:57:05][WARNING] : decData vide getTempoData(0,0)
[2025-11-14 22:57:04][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 0
[2025-11-14 22:57:05][ERROR] : getResourceRTE ----- CURL return code: 403 URL: https://digital.iservices.rte-france.com/open_api/tempo_like_supply_contract/v1/tempo_like_calendars?start_date=2025-09-01T00:00:00+02:00&end_date=2025-11-16T00:00:00+01:00&fallback_status=false
[2025-11-14 22:57:05][WARNING] : decData vide getTempoData(0,0)
ormaté`
je ne sais jamais comment joindre un log j’espère que ca suffira.
en gros (si j’ai bien compris ) il dit que le dossier est vide.
C’est pour cela que je demandais si ça marchait encore.
Oui, il fonctionne encore.
Le log fourni est plutôt illisible. Utilisez image
La signification de l’erreur 403 que vous obtenez:
Vérifiez votre abonnement à l’API Tempo Like Supply Contract
Il l’a fait mais sans espacer le texte précédent et le bloque de log donc on a une seule quote au lieu de trois.
Si on utilise </> à la suite d’un texte, sans retour à la ligne
Texte préformaté
Utilisé separé du texte par un ou plusieurs retour à la ligne.
saisissez ou collez du code ici
bonjour,
Merci pour votre coup de main.
1j’avais bien ouvert l’appli rte et abonné à ecowatt
mais je ne m’étais pas abonné à tempo like : pas vu
LOL
merci pour l’explication pour incérer les log
Un tuto pour expliquer l’utilisation des messages serait le bien venu
Merci encore
saisissez ou colle[2025-11-15 07:18:10][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 1
[2025-11-15 07:19:57][INFO] : ---------------------- updateInfo tempoRTE Equipment [eco EDF] Fetch: 1z du code ici
