Erreur : le service zigbee2mqtt est arrêté
Voilà je me tourne vers vous (surtout vers @MrGreen :slight_smile: ) car depuis hier après-midi j’ai le fameux message « le service zigbee2mqtt est arrêté ».
J’ai bien sûr suivi les consignes données ici : Zigbee2MQTT s’est arrêté
Voici d’ailleurs mon log debug :
> zigbee2mqtt@1.22.2 start /opt/zigbee2mqtt
> node index.js
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Loaded state from file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Logging to console and directory: '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2022-01-22.11-38-19' filename: log.txt
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Removing old log directory '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2022-01-21.20-47-48'
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Starting Zigbee2MQTT version 1.22.2 (commit #1a0a9a6e)
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Starting zigbee-herdsman (0.13.188)
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"deconz","path":"/dev/ttyACM0"}}'
2022-01-22T10:38:21.780Z zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'DeconzAdapter'
2022-01-22T10:38:21.782Z zigbee-herdsman:deconz:driver Set delay to 0
CREATED DECONZ ADAPTER
2022-01-22T10:38:21.784Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/ttyACM0","adapter":"deconz"},"databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2022-01-22T10:38:21.784Z zigbee-herdsman:deconz:driver Opening with /dev/ttyACM0
2022-01-22T10:38:21.792Z zigbee-herdsman:deconz:driver Serialport opened
2022-01-22T10:38:21.793Z zigbee-herdsman:controller:log Started with result 'resumed'
2022-01-22T10:38:21.793Z zigbee-herdsman:controller:log Injected database: true, adapter: true
2022-01-22T10:38:21.794Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
2022-01-22T10:38:21.801Z zigbee-herdsman:deconz:frameParser MAC: 0x00212effff071d08
2022-01-22T10:38:21.804Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 2 paramId: 7
2022-01-22T10:38:21.807Z zigbee-herdsman:deconz:frameParser NWKADDR: 0
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: zigbee-herdsman started (resumed)
2022-01-22T10:38:21.815Z zigbee-herdsman:deconz:driver send read firmware version request from queue. seqNr: 3
2022-01-22T10:38:21.818Z zigbee-herdsman:deconz:frameParser read firmware version response - version: 0,7,104,38
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":104,"product":0,"revision":"0x26680700","transportrev":0},"type":"ConBee2/RaspBee2"}'
2022-01-22T10:38:21.821Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 4 paramId: 5
2022-01-22T10:38:21.824Z zigbee-herdsman:deconz:frameParser PANID: 1a62
2022-01-22T10:38:21.827Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 5 paramId: 11
2022-01-22T10:38:21.830Z zigbee-herdsman:deconz:frameParser APS_EXT_PANID: 0xdddddddddddddddd
2022-01-22T10:38:21.832Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 6 paramId: 28
2022-01-22T10:38:21.834Z zigbee-herdsman:deconz:frameParser CHANNEL: 11
2022-01-22T10:38:21.837Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 7 paramId: 24
2022-01-22T10:38:21.839Z zigbee-herdsman:deconz:frameParser NETWORK_KEY: hidden
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Zigbee network parameters: {"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754}
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: Failed to start zigbee
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: Exiting...
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received undefined
at new NodeError (internal/errors.js:322:7)
at validateString (internal/validators.js:124:11)
at Object.join (path.js:1148:7)
at Object.joinPath (/opt/zigbee2mqtt/lib/util/data.ts:17:17)
at writeDevicesOrGroups (/opt/zigbee2mqtt/lib/util/settings.ts:205:38)
at write (/opt/zigbee2mqtt/lib/util/settings.ts:211:5)
at Object.addDevice (/opt/zigbee2mqtt/lib/util/settings.ts:515:5)
at Device.ensureInSettings (/opt/zigbee2mqtt/lib/model/device.ts:37:22)
at Zigbee.resolveDevice (/opt/zigbee2mqtt/lib/zigbee.ts:230:20)
at /opt/zigbee2mqtt/lib/zigbee.ts:272:30
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.22.2 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.22.2 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2022-01-22T10_38_22_087Z-debug.log
Comme je n’y comprend pas grand chose (pour ne pas dire que je n’y comprend rien…) j’espère que vous aurez une solution pour moi.
Je précise que j’ai relancé les dépendances, redémarrer le démon et même tenté un redémarrage de ma box atlas… Aucun résultat.
Je suis donc sur une box atlas en V4.1.28 et je n’ai absolument rien touché à mon config depuis plusieurs semaine, le plugin ) planté hier après-midi sans raison apparrente.
Installation complète de Zigbeelinker. La clé conbee2 est branché sur la box atlas via une rallonge.
Merci !
bonjour,
pour suivre , j’ai exactement le même soucis, et ne sais pas comment dépanner
merci
J’ai eu le même problème !!
J’ai juste modifier le fichier configuration.yaml
en effaçant à la fin
groups: [ ]
external_converters: [ ]
