Lorsque je tente d’utiliser le plugin, le démon du plugin Ajax Systeme, le démon refuse de démarrer avec l’erreur suivante : ERROR : Fatal error : [Errno 98] Address already in use
Les logs :
[2024-03-18 20:58:18]ERROR : Fatal error : [Errno 98] Address already in use
[2024-03-18 21:00:56]INFO : Start demond
[2024-03-18 21:00:56]INFO : Log level : debug
[2024-03-18 21:00:56]INFO : PID file : /tmp/jeedom/ajaxSystem/deamon.pid
[2024-03-18 21:00:56]INFO : Apikey : XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
[2024-03-18 21:00:56]INFO : Device : auto
[2024-03-18 21:00:56]INFO : Cycle : 0.3
[2024-03-18 21:00:56]INFO : Sia port : 51000
[2024-03-18 21:00:56]INFO : Sia Account : 84011
[2024-03-18 21:00:56]INFO : Sia key : htt7bas53a781zl9
[2024-03-18 21:00:56]DEBUG : Writing PID 8807 to /tmp/jeedom/ajaxSystem/deamon.pid
[2024-03-18 21:00:56]DEBUG : Init request module v2.31.0
[2024-03-18 21:00:56]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2024-03-18 21:00:56]DEBUG : http://127.0.0.1:80 "GET /plugins/ajaxSystem/core/php/jeeAjaxSystemSia.php?apikey=XXXXXXXXXXXXXXXXXXXXXXX HTTP/1.1" 200 0
[2024-03-18 21:00:56]ERROR : Fatal error : [Errno 98] Address already in use
[2024-03-18 21:00:56]INFO : Traceback (most recent call last):
File "/var/www/html/plugins/ajaxSystem/resources/ajaxSystemd/ajaxSystemd.py", line 179, in <module>
listen()
File "/var/www/html/plugins/ajaxSystem/resources/ajaxSystemd/ajaxSystemd.py", line 51, in listen
protocol=CommunicationsProtocol('TCP'))
File "/var/www/html/plugins/ajaxSystem/resources/ajaxSystemd/pysiaalarm/sync/client.py", line 49, in __init__
self.sia_server: SIATCPServer | SIAUDPServer = self.get_server()
File "/var/www/html/plugins/ajaxSystem/resources/ajaxSystemd/pysiaalarm/sync/client.py", line 56, in get_server
(self._host, self._port), self._accounts, self._func, self._counts
File "/var/www/html/plugins/ajaxSystem/resources/ajaxSystemd/pysiaalarm/sync/server.py", line 38, in __init__
ThreadingTCPServer.__init__(self, server_address, SIATCPHandler)
File "/usr/lib/python3.7/socketserver.py", line 452, in __init__
self.server_bind()
File "/usr/lib/python3.7/socketserver.py", line 466, in server_bind
self.socket.bind(self.server_address)
OSError: [Errno 98] Address already in use
[2024-03-18 21:00:56]DEBUG : Shutdown
[2024-03-18 21:00:56]DEBUG : Removing PID file /tmp/jeedom/ajaxSystem/deamon.pid
[2024-03-18 21:00:56]DEBUG : Exit 0
Je ne comprends pas le rapport avec une quelconque adresse existante, si quelqu’un sait m’en dire plus ![]()
Bonne soirée
