Je me suis amusé a mettre a jour mon jeedom de Debian 10 a 11, avec un peux de ténacité j’ai réussi a relancer tout les plug-in sauf un qui me fait de la résistance …
Kiaevo :
[2023-07-30 00:10:17]DEBUG : starting deamon with log level : debug
[2023-07-30 00:10:17]DEBUG : node /var/www/html/plugins/kiauvo/node/main.js --region=EU --pin=**** --password=********** --userName=Y3lqZW4ubGVjbGVyQGdtYWlsLmNvbQ== --port=8090 --language=fr --sharedFile=/tmp/jeedom-kiauvo-key.dat
[2023-07-30 00:10:17]INFO : kiauvo deamon started
[2023-07-30 00:11:25]DEBUG : [Maison][E-Soul] Utilisation du template kiauvo
[2023-07-30 00:15:03]ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2023-07-30 00:15:03]INFO : Stopping deamon kiauvo
[2023-07-30 00:15:03]INFO : Starting kiauvo deamon
[2023-07-30 00:15:03]DEBUG : starting deamon with log level : debug
[2023-07-30 00:15:03]DEBUG : node /var/www/html/plugins/kiauvo/node/main.js --region=EU --pin=**** --password=********** --userName=Y3lqZW4ubGVjbGVyQGdtYWlsLmNvbQ== --port=8090 --language=fr --sharedFile=/tmp/jeedom-kiauvo-key.dat
[2023-07-30 00:15:03]INFO : kiauvo deamon started
Kiaevo_dep :
Starting installation
Current : v16.20.1, major: 16
Current version: Compatible
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 182 packages, and audited 183 packages in 2s
3 packages are looking for funding
run `npm fund` for details
14 vulnerabilities (8 moderate, 6 high)
To address issues that do not require attention, run:
npm audit fix
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
Installation finished`
Kia_node :
[2023-07-30 00:15:03] e[32minfoe[39m: Deamon kia_node is starting
[2023-07-30 00:15:03] e[34mdebuge[39m: EU Controller created
[2023-07-30 00:15:03] e[34mdebuge[39m: @EuropeController.login: Trying to sign in with EuropeanBrandAuthStrategy
[2023-07-30 00:15:06] e[34mdebuge[39m: @EuropeController.login: Authenticated properly with user and password
[2023-07-30 00:15:07] e[34mdebuge[39m: @EuropeController.login: Device registered
[2023-07-30 00:15:07] e[34mdebuge[39m: @EuropeController.login: Session defined properly
[2023-07-30 00:15:08] e[31merrore[39m: @EuropeController.getVehicles: [401] Unauthorized on [GET] https://prd.eu-ccapi.kia.com:8080/api/v1/spa/vehicles - {"retCode":"F","resCode":"4017","resMsg":"Invalid request value - Invalid Application Id. - 86230.04948","msgId":"48****8c-*0*c-42*f**1-8*8***a-52c"}
Pourquoi il me ressort un « Unauthorized »
J’ai bien remis mon mdp j’ai meme changé le code pin et il ne ce lance pas, relancé les dépendances, réinstaller stable/beta …
Une idée ?
Merci ![]()
