le token configuration est aussi vide chez moi
mais le return a une valeur par contre.
il faudrait @enfrafer de régénérer la configuration dans le plugin
0001|[2023-11-25 11:58:52]DEBUG : | Appel API Mobile > sync
0002|[2023-11-25 11:58:52]DEBUG : | paramètres passés > {"allowPlugin":["Plugin"],"Iq":"Nn1uUhU1EKZZZUlCDWKHJxaYHUQprrgG","notificationRegistration":"a9e7f607aa6d671601dd38f0642f5f321c6e406b3cfa8b4a9c32baac37aae66d","notificationProvider":"\"arn:aws:sns:eu-west-1:507915066327:endpoint\/APNS\/jeedom-ios\/7a4499c3-7278-3efb-a796-ce0e3e107c65\"","rdk":"Z1vKHg75Ej14alNpowx2Q1fKIGiGbpXlTaptobbWFLD9UQUGsGPBYdYCzquBBTFT","platform":"ios","apikey":"EzgsGemqHuOkEeCoKKixF31rhsQKLSfrzbKFO0Ei1Gq5NCNu4EMKgVvFPIVkcVKA","plugin":"mobile","session":true,"sess_id":""}
0003|[2023-11-25 11:58:52]DEBUG : | Mobile demandeur > JAG - Iphone 12 Pro - VM - Jeedom_OLD
0004|[2023-11-25 11:58:52]DEBUG : |-----------------------------------
0005|[2023-11-25 11:58:52]DEBUG : SYNC
0006|[2023-11-25 11:58:52]DEBUG : Demande du RDK
0007|[2023-11-25 11:58:52]DEBUG : RDK :Z1vKHg75Ej14alNpowx2Q1fKIGiGbpXlTaptobbWFLD9UQUGsGPBYdYCzquBBTFT
0008|[2023-11-25 11:58:52]DEBUG : notificationProvider Disponible
0009|[2023-11-25 11:58:52]DEBUG : EqLogic dispo
0010|[2023-11-25 11:58:52]DEBUG : arn NON null dans la configuration > arn:aws:sns:eu-west-1:507915066327:endpoint/APNS/jeedom-ios/7a4499c3-7278-3efb-a796-ce0e3e107c65
0011|[2023-11-25 11:58:52]DEBUG : Token dans la configuration >
0012|[2023-11-25 11:58:52]DEBUG : Return $discovery_summaryValue > [{"object_id":"1","key":"security","value":2},{"object_id":"2","key":"motion","value":1},{"object_id":"2","key":"outlet","value":3},{"object_id":"2","key":"temperature","value":20.8},{"object_id":"2","key":"humidity","value":56},{"object_id":"2","key":"luminosity","value":20},{"object_id":"2","key":"power","value":100.4},{"object_id":"4","key":"outlet","value":1},{"object_id":"4","key":"temperature","value":19.7},{"object_id":"4","key":"humidity","value":52},{"object_id":"4","key":"power","value":3.1},{"object_id":"5","key":"temperature","value":21.5},{"object_id":"5","key":"humidity","value":51},{"object_id":"7","key":"motion","value":1},{"object_id":"7","key":"outlet","value":3},{"object_id":"7","key":"temperature","value":19.9},{"object_id":"7","key":"humidity","value":52},{"object_id":"7","key":"luminosity","value":139},{"object_id":"7","key":"power","value":66.4},{"object_id":"9","key":"outlet","value":1},{"object_id":"9","key":"temperature","value":19.1},{"object_id":"9","key":"humidity","value":53},{"object_id":"10","key":"temperature","value":23.9},{"object_id":"10","key":"humidity","value":57},{"object_id":"11","key":"motion","value":1},{"object_id":"3","key":"shutter","value":2},{"object_id":"3","key":"temperature","value":5.6},{"object_id":"3","key":"humidity","value":66},{"object_id":"6","key":"temperature","value":13.9},{"object_id":"6","key":"humidity","value":38.6},{"object_id":"8","key":"security","value":1},{"object_id":"8","key":"outlet","value":1},{"object_id":"8","key":"temperature","value":19.5},{"object_id":"8","key":"humidity","value":51},{"object_id":"8","key":"power","value":0.8},{"object_id":"27","key":"temperature","value":6},{"object_id":"27","key":"humidity","value":61.1},{"object_id":"global","key":"security","value":3},{"object_id":"global","key":"motion","value":3},{"object_id":"global","key":"shutter","value":2},{"object_id":"global","key":"outlet","value":9},{"object_id":"global","key":"temperature","value":20.7},{"object_id":"global","key":"humidity","value":52.9},{"object_id":"global","key":"luminosity","value":79.5},{"object_id":"global","key":"power","value":170.7}]
