J’ai ce message d’erreur maintenant :
Et je ne trouve ce signe que dans le fichier JS… Je dois le remplacer par quelque chose?
{\rtf1\ansi\ansicpg1252\cocoartf2639
\cocoatextscaling0\cocoaplatform0{\fonttbl\f0\fmodern\fcharset0 Courier;}
{\colortbl;\red255\green255\blue255;\red255\green255\blue255;}
{\*\expandedcolortbl;;\cssrgb\c100000\c100000\c100000;}
\paperw11900\paperh16840\margl1440\margr1440\vieww11520\viewh8400\viewkind0
\deftab720
\pard\pardeftab720\partightenfactor0
\f0\fs26 \cf0 \expnd0\expndtw0\kerning0
window.FontAwesomeKitConfig = \{"asyncLoading":\{"enabled":false\},"autoA11y":\{"enabled":true\},"baseUrl":"https://ka-f.fontawesome.com","baseUrlKit":"https://kit.fontawesome.com","detectConflictsUntil":null,"iconUploads":\{\},"id":8686944,"license":"free","method":"css","minify":\{"enabled":true\},"token":"615562335a","v4FontFaceShim":\{"enabled":true\},"v4shim":\{"enabled":true\},"v5FontFaceShim":\{"enabled":true\},"version":"6.4.2"\};\
!function(t)\{"function"==typeof define&&define.amd?define("kit-loader",t):t()\}((function()\{"use strict";function t(t,e)\{var n=Object.keys(t);if(Object.getOwnPropertySymbols)\{var r=Object.getOwnPropertySymbols(t);e&&(r=r.filter((function(e)\{return Object.getOwnPropertyDescriptor(t,e).enumerable\}))),n.push.apply(n,r)\}return n\}function e(e)\{for(var n=1;n<arguments.length;n++)\{var o=null!=arguments[n]?arguments[n]:\{\};n%2?t(Object(o),!0).forEach((function(t)\{r(e,t,o[t])\})):Object.getOwnPropertyDescriptors?Object.defineProperties(e,Object.getOwnPropertyDescriptors(o)):t(Object(o)).forEach((function(t)\{Object.defineProperty(e,t,Object.getOwnPropertyDescriptor(o,t))\}))\}return e\}function n(t)\{return(n="function"==typeof Symbol&&"symbol"==typeof Symbol.iterator?function(t)\{return typeof t\}:function(t)\{return t&&"function"==typeof Symbol&&t.constructor===Symbol&&t!==Symbol.prototype?"symbol":typeof t\})(t)\}function r(t,e,n)\{return(e=function(t)\{var e=function(t,e)\{if("object"!=typeof t||null===t)return t;var n=t[Symbol.toPrimitive];if(void 0!==n)\{var r=n.call(t,e||"default");if("object"!=typeof r)return r;throw new TypeError("@@toPrimitive must return a primitive value.")\}return("string"===e?String:Number)(t)\}(t,"string");return"symbol"==typeof e?e:String(e)\}(e))in t?Object.defineProperty(t,e,\{value:n,enumerable:!0,configurable:!0,writable:!0\}):t[e]=n,t\}function o(t,e)\{return function(t)\{if(Array.isArray(t))return t\}(t)||function(t,e)\{var n=null==t?null:"undefined"!=typeof Symbol&&t[Symbol.iterator]||t["@@iterator"];if(null!=n)\{var r,o,i,c,a=[],u=!0,f=!1;try\{if(i=(n=n.call(t)).next,0===e)\{if(Object(n)!==n)return;u=!1\}else for(;!(u=(r=i.call(n)).done)&&(a.push(r.value),a.length!==e);u=!0);\}catch(t)\{f=!0,o=t\}finally\{try\{if(!u&&null!=n.return&&(c=n.return(),Object(c)!==c))return\}finally\{if(f)throw o\}\}return a\}\}(t,e)||function(t,e)\{if(!t)return;if("string"==typeof t)return i(t,e);var n=Object.prototype.toString.call(t).slice(8,-1);"Object"===n&&t.constructor&&(n=t.constructor.name);if("Map"===n||"Set"===n)return Array.from(t);if("Arguments"===n||/^(?:Ui|I)nt(?:8|16|32)(?:Clamped)?Array$/.test(n))return i(t,e)\}(t,e)||function()\{throw new TypeError("Invalid attempt to destructure non-iterable instance.\\nIn order to be iterable, non-array objects must have a [Symbol.iterator]() method.")\}()\}function i(t,e)\{(null==e||e>t.length)&&(e=t.length);for(var n=0,r=new Array(e);n<e;n++)r[n]=t[n];return r\}function c(t,e)\{var n=e&&e.addOn||"",r=e&&e.baseFilename||t.license+n,o=e&&e.minify?".min":"",i=e&&e.fileSuffix||t.method,c=e&&e.subdir||t.method;return t.baseUrl+"/releases/"+("latest"===t.version?"latest":"v".concat(t.version))+"/"+c+"/"+r+o+"."+i\}function a(t,e)\{var n=e||["fa"],r="."+Array.prototype.join.call(n,",."),o=t.querySelectorAll(r);Array.prototype.forEach.call(o,(function(e)\{var n=e.getAttribute("title");e.setAttribute("aria-hidden","true");var r=!e.nextElementSibling||!e.nextElementSibling.classList.contains("sr-only");if(n&&r)\{var o=t.createElement("span");o.innerHTML=n,o.classList.add("sr-only"),e.parentNode.insertBefore(o,e.nextSibling)\}\}))\}var u,f=function()\{\},s="undefined"!=typeof global&&void 0!==global.process&&"function"==typeof global.process.emit,l="undefined"==typeof setImmediate?setTimeout:setImmediate,d=[];function h()\{for(var t=0;t<d.length;t++)d[t][0](d[t][1]);d=[],u=!1\}function m(t,e)\{d.push([t,e]),u||(u=!0,l(h,0))\}function p(t)\{var e=t.owner,n=e._state,r=e._data,o=t[n],i=t.then;if("function"==typeof o)\{n="fulfilled";try\{r=o(r)\}catch(t)\{g(i,t)\}\}v(i,r)||("fulfilled"===n&&b(i,r),"rejected"===n&&g(i,r))\}function v(t,e)\{var r;try\{if(t===e)throw new TypeError("A promises callback cannot return that same promise.");if(e&&("function"==typeof e||"object"===n(e)))\{var o=e.then;if("function"==typeof o)return o.call(e,(function(n)\{r||(r=!0,e===n?y(t,n):b(t,n))\}),(function(e)\{r||(r=!0,g(t,e))\})),!0\}\}catch(e)\{return r||g(t,e),!0\}return!1\}function b(t,e)\{t!==e&&v(t,e)||y(t,e)\}function y(t,e)\{"pending"===t._state&&(t._state="settled",t._data=e,m(A,t))\}function g(t,e)\{"pending"===t._state&&(t._state="settled",t._data=e,m(S,t))\}function w(t)\{t._then=t._then.forEach(p)\}function A(t)\{t._state="fulfilled",w(t)\}function S(t)\{t._state="rejected",w(t),!t._handled&&s&&global.process.emit("unhandledRejection",t._data,t)\}function O(t)\{global.process.emit("rejectionHandled",t)\}function j(t)\{if("function"!=typeof t)throw new TypeError("Promise resolver "+t+" is not a function");if(this instanceof j==!1)throw new TypeError("Failed to construct 'Promise': Please use the 'new' operator, this object constructor cannot be called as a function.");this._then=[],function(t,e)\{function n(t)\{g(e,t)\}try\{t((function(t)\{b(e,t)\}),n)\}catch(t)\{n(t)\}\}(t,this)\}j.prototype=\{constructor:j,_state:"pending",_then:null,_data:void 0,_handled:!1,then:function(t,e)\{var n=\{owner:this,then:new this.constructor(f),fulfilled:t,rejected:e\};return!e&&!t||this._handled||(this._handled=!0,"rejected"===this._state&&s&&m(O,this)),"fulfilled"===this._state||"rejected"===this._state?m(p,n):this._then.push(n),n.then\},catch:function(t)\{return this.then(null,t)\}\},j.all=function(t)\{if(!Array.isArray(t))throw new TypeError("You must pass an array to Promise.all().");return new j((function(e,n)\{var r=[],o=0;function i(t)\{return o++,function(n)\{r[t]=n,--o||e(r)\}\}for(var c,a=0;a<t.length;a++)(c=t[a])&&"function"==typeof c.then?c.then(i(a),n):r[a]=c;o||e(r)\}))\},j.race=function(t)\{if(!Array.isArray(t))throw new TypeError("You must pass an array to Promise.race().");return new j((function(e,n)\{for(var r,o=0;o<t.length;o++)(r=t[o])&&"function"==typeof r.then?r.then(e,n):e(r)\}))\},j.resolve=function(t)\{return t&&"object"===n(t)&&t.constructor===j?t:new j((function(e)\{e(t)\}))\},j.reject=function(t)\{return new j((function(e,n)\{n(t)\}))\};var E="function"==typeof Promise?Promise:j;function P(t,e)\{var n=e.fetch,r=e.XMLHttpRequest,o=e.token,i=t;return o&&!function(t)\{return t.indexOf("kit-upload.css")>-1\}(t)&&("URLSearchParams"in window?(i=new URL(t)).searchParams.set("token",o):i=i+"?token="+encodeURIComponent(o)),i=i.toString(),new E((function(t,e)\{if("function"==typeof n)n(i,\{mode:"cors",cache:"default"\}).then((function(t)\{if(t.ok)return t.text();throw new Error("")\})).then((function(e)\{t(e)\})).catch(e);else if("function"==typeof r)\{var o=new r;o.addEventListener("loadend",(function()\{this.responseText?t(this.responseText):e(new Error(""))\}));["abort","error","timeout"].map((function(t)\{o.addEventListener(t,(function()\{e(new Error(""))\}))\})),o.open("GET",i),o.send()\}else\{e(new Error(""))\}\}))\}function _(t,e,n)\{var r=t;return[[/(url\\("?)\\.\\.\\/\\.\\.\\/\\.\\./g,function(t,n)\{return"".concat(n).concat(e)\}],[/(url\\("?)\\.\\.\\/webfonts/g,function(t,r)\{return"".concat(r).concat(e,"/releases/v").concat(n,"/webfonts")\}],[/(url\\("?)https:\\/\\/kit-free([^.])*\\.fontawesome\\.com/g,function(t,n)\{return"".concat(n).concat(e)\}]].forEach((function(t)\{var e=o(t,2),n=e[0],i=e[1];r=r.replace(n,i)\})),r\}function F(t,n)\{var r=arguments.length>2&&void 0!==arguments[2]?arguments[2]:function()\{\},o=n.document||o,i=a.bind(a,o,["fa","fab","fas","far","fal","fad","fak"]);t.autoA11y.enabled&&r(i);var u=t.subsetPath&&t.baseUrl+"/"+t.subsetPath,f=[\{id:"fa-main",addOn:void 0,url:u\}];if(t.v4shim&&t.v4shim.enabled&&f.push(\{id:"fa-v4-shims",addOn:"-v4-shims"\}),t.v5FontFaceShim&&t.v5FontFaceShim.enabled&&f.push(\{id:"fa-v5-font-face",addOn:"-v5-font-face"\}),t.v4FontFaceShim&&t.v4FontFaceShim.enabled&&f.push(\{id:"fa-v4-font-face",addOn:"-v4-font-face"\}),!u&&t.customIconsCssPath)\{var s=t.customIconsCssPath.indexOf("kit-upload.css")>-1?t.baseUrlKit:t.baseUrl,l=s+"/"+t.customIconsCssPath;f.push(\{id:"fa-kit-upload",url:l\})\}var d=f.map((function(r)\{return new E((function(o,i)\{var a=r.url||c(t,\{addOn:r.addOn,minify:t.minify.enabled\}),u=\{id:r.id\},f=t.subset?u:e(e(e(\{\},n),u),\{\},\{baseUrl:t.baseUrl,version:t.version,id:r.id,contentFilter:function(t,e)\{return _(t,e.baseUrl,e.version)\}\});P(a,n).then((function(t)\{o(C(t,f))\})).catch(i)\}))\}));return E.all(d)\}function C(t,e)\{var n=e.contentFilter||function(t,e)\{return t\},r=document.createElement("style"),o=document.createTextNode(n(t,e));return r.appendChild(o),r.media="all",e.id&&r.setAttribute("id",e.id),e&&e.detectingConflicts&&e.detectionIgnoreAttr&&r.setAttributeNode(document.createAttribute(e.detectionIgnoreAttr)),r\}function I(t,n)\{n.autoA11y=t.autoA11y.enabled,"pro"===t.license&&(n.autoFetchSvg=!0,n.fetchSvgFrom=t.baseUrl+"/releases/"+("latest"===t.version?"latest":"v".concat(t.version))+"/svgs",n.fetchUploadedSvgFrom=t.uploadsUrl);var r=[];return t.v4shim.enabled&&r.push(new E((function(r,o)\{P(c(t,\{addOn:"-v4-shims",minify:t.minify.enabled\}),n).then((function(t)\{r(U(t,e(e(\{\},n),\{\},\{id:"fa-v4-shims"\})))\})).catch(o)\}))),r.push(new E((function(r,o)\{P(t.subsetPath&&t.baseUrl+"/"+t.subsetPath||c(t,\{minify:t.minify.enabled\}),n).then((function(t)\{var o=U(t,e(e(\{\},n),\{\},\{id:"fa-main"\}));r(function(t,e)\{var n=e&&void 0!==e.autoFetchSvg?e.autoFetchSvg:void 0,r=e&&void 0!==e.autoA11y?e.autoA11y:void 0;void 0!==r&&t.setAttribute("data-auto-a11y",r?"true":"false");n&&(t.setAttributeNode(document.createAttribute("data-auto-fetch-svg")),t.setAttribute("data-fetch-svg-from",e.fetchSvgFrom),t.setAttribute("data-fetch-uploaded-svg-from",e.fetchUploadedSvgFrom));return t\}(o,n))\})).catch(o)\}))),E.all(r)\}function U(t,e)\{var n=document.createElement("SCRIPT"),r=document.createTextNode(t);return n.appendChild(r),n.referrerPolicy="strict-origin",e.id&&n.setAttribute("id",e.id),e&&e.detectingConflicts&&e.detectionIgnoreAttr&&n.setAttributeNode(document.createAttribute(e.detectionIgnoreAttr)),n\}function T(t)\{var e,n=[],r=document,o=r.documentElement.doScroll,i=(o?/^loaded|^c/:/^loaded|^i|^c/).test(r.readyState);i||r.addEventListener("DOMContentLoaded",e=function()\{for(r.removeEventListener("DOMContentLoaded",e),i=1;e=n.shift();)e()\}),i?setTimeout(t,0):n.push(t)\}function L(t)\{"undefined"!=typeof MutationObserver&&new MutationObserver(t).observe(document,\{childList:!0,subtree:!0\})\}try\{if(window.FontAwesomeKitConfig)\{var k=window.FontAwesomeKitConfig,x=\{detectingConflicts:k.detectConflictsUntil&&new Date<=new Date(k.detectConflictsUntil),detectionIgnoreAttr:"data-fa-detection-ignore",fetch:window.fetch,token:k.token,XMLHttpRequest:window.XMLHttpRequest,document:document\},M=document.currentScript,N=M?M.parentElement:document.head;(function()\{var t=arguments.length>0&&void 0!==arguments[0]?arguments[0]:\{\},e=arguments.length>1&&void 0!==arguments[1]?arguments[1]:\{\};return"js"===t.method?I(t,e):"css"===t.method?F(t,e,(function(t)\{T(t),L(t)\})):void 0\})(k,x).then((function(t)\{t.map((function(t)\{try\{N.insertBefore(t,M?M.nextSibling:null)\}catch(e)\{N.appendChild(t)\}\})),x.detectingConflicts&&M&&T((function()\{M.setAttributeNode(document.createAttribute(x.detectionIgnoreAttr));var t=function(t,e)\{var n=document.createElement("script");return e&&e.detectionIgnoreAttr&&n.setAttributeNode(document.createAttribute(e.detectionIgnoreAttr)),n.src=c(t,\{baseFilename:"conflict-detection",fileSuffix:"js",subdir:"js",minify:t.minify.enabled\}),n\}(k,x);document.body.appendChild(t)\}))\})).catch((function(t)\{console.error("".concat("Font Awesome Kit:"," ").concat(t))\}))\}\}catch(t)\{console.error("".concat("Font Awesome Kit:"," ").concat(t))\}\}));}
