J’ai l’erreur suivante lors de l’installation
wget -O- https://raw.githubusercontent.com/jeedom/core/master/install/install.sh | sudo bash
\033[1;33mStarting step 3 - databse\033[0;39m
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
mariadb-client is already the newest version (1:10.11.3-1+rpi1).
mariadb-common is already the newest version (1:10.11.3-1+rpi1).
mariadb-server is already the newest version (1:10.11.3-1+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
● mariadb.service - MariaDB 10.11.3 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; preset: enab>
Drop-In: /usr/lib/systemd/system/mariadb.service.d
└─override.conf
Active: activating (auto-restart) (Result: exit-code) since Fri 2023-10-20>
Docs: man:mariadbd(8)
systemd - MariaDB Knowledge Base
Process: 2531 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var>
Process: 2532 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_ST>
Process: 2534 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && >
Process: 2633 ExecStart=/usr/sbin/mariadbd $MYSQLD_OPTS $_WSREP_NEW_CLUSTER>
Main PID: 2633 (code=exited, status=1/FAILURE)
Status: « MariaDB server is down »
CPU: 556ms
lines 1-14/14 (END)
