Erreur: 'InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
J’ai acheté récemment le pack power et de ce fait la descente du plugin openvpn s’est faite sur mon système
Petit soucis sur les dépendances de ce plugin qui ne s’installent pas: log:
+ touch /tmp/jeedom_install_in_progress_openvpn
+ echo 1
+ echo 2
apt: no process found
apt-get: no process found
+ sudo apt update
Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Reading package lists...
E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
+ echo 3
Building dependency tree...
Reading state information...
The following additional packages will be installed:
easy-rsa libccid libpkcs11-helper1 opensc opensc-pkcs11 pcscd
Suggested packages:
pcmciautils openvpn-systemd-resolved
easy-rsa libccid libpkcs11-helper1 opensc opensc-pkcs11 openvpn pcscd
0 upgraded, 7 newly installed, 0 to remove and 529 not upgraded.
Need to get 994 kB/1912 kB of archives.
After this operation, 5289 kB of additional disk space will be used.
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf opensc-pkcs11 armhf 0.19.0-1+deb10u2
404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf opensc armhf 0.19.0-1+deb10u2
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/o/opensc/opensc-pkcs11_0.19.0-1+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/o/opensc/opensc_0.19.0-1+deb10u2_armhf.deb  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
+ echo 4
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end openvpn
J’ai redémarré plusieurs fois et testé également un dpkg configuré et attendu une dizaine de minute avant de faire la réinstallation mais sans succès.
Auriez vous une solution svp?
Matériel; raspberry pi4b
Os: Raspbian GNU/Linux 10 (buster) 32bits (armv7l)
Merci d’avance
J’ai mis à jour le titre de votre sujet, faites une recherche sur l’erreur en question.
La solution a déjà été donnée des dizaines de fois
Pas de solution clé en main mais un indice :wink: En faisant une recherche sur le forum sur cette erreur tu devrais facilement trouver comment corriger :
Un autre indice pour une autre solution : il pourrait être judicieux de passer sous Debian 11 non ?
J’y ai pensé mais le but étant de conserver openzwave sans devoir migrer sur zwavejs
La seule solution serait donc de faire une maj de l’os de debian 10 en 11 donc?
Résultats de recherche pour « E: Repository 'http://deb.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable' » - Communauté Jeedom
J’ai lancé la maj via
sudo apt-get update --allow-releaseinfo-change
A fonctionné
Merci encore a tous même si j’ai senti beaucoup de jugement lol
A clôturé
Nous t’avons pourtant juste donné les clés pour trouver la réponse par toi-même, je ne vois à quel moment il y a eu le moindre jugement :
D’autant plus que la réponse de @Furaxworld est justement ce que nous t’avons conseillé de faire qu’il a donc fait à ta place.
