Je suis sous le plugin Zigbee et ma sortie de câble Legrand ne fonctionne pas. Inclusion OK mais pas d’infos qui remontent.
Alors j’ai lu pas mal de truc sur le forum, maj firmware, inclusion en plusieurs fois…etc, mais impossible d’y arriver.
Est-ce que qq1 à la solution miracle ?
Les logs lors d’une inclusion :
[2021-10-15 16:13:30][DEBUG] : {"device_joined":"00:04:74:00:00:11:ee:6b"}
[2021-10-15 16:13:31][DEBUG] : {"device_initialized":"00:04:74:00:00:11:ee:6b"}
[2021-10-15 16:13:33][DEBUG] : {"devices":{"00:04:74:00:00:11:ee:6b":{"1":[[{"value":"2","cluster_name":"Basic"},{"value":"0","cluster_name":"Basic"},{"value":"66","cluster_name":"Basic"},{"value":"1","cluster_name":"Basic"}]]}}}
[2021-10-15 16:13:34][DEBUG] : {"devices":{"00:04:74:00:00:11:ee:6b":{"1":[{"7":{"value":"PowerSource.Mains_single_phase","cluster_name":"Basic"}}]}}}
[2021-10-15 16:13:35][DEBUG] : {"devices":{"00:04:74:00:00:11:ee:6b":{"1":[{"6":{"value":" ","cluster_name":"Basic"},"16384":{"value":"0008","cluster_name":"Basic"}}]}}}
[2021-10-15 16:13:51][DEBUG] : {"device_left":"00:04:74:00:00:11:ee:6b"}
[2021-10-15 16:14:01][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-10-15 16:14:01][DEBUG] : {"with_attributes":2}
[2021-10-15 16:14:01][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2021-10-15 16:14:01][DEBUG] : {"ieee":"00:04:74:00:00:11:ee:6b","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-10-15 16:14:29][INFO] : [Aucun][Legrand.Cable_outlet 00:04:74:00:00:11:ee:6b] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:04:74:00:00:11:ee:6b","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"[0x2365:1:0x0006]: Message send failure","code":0}
[2021-10-15 16:14:29][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2021-10-15 16:14:29][DEBUG] : {"ieee":"00:04:74:00:00:11:ee:6b","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2021-10-15 16:14:57][INFO] : [Aucun][Legrand.Cable_outlet 00:04:74:00:00:11:ee:6b] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"00:04:74:00:00:11:ee:6b","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0} erreur : {"state":"error","result":"[0x2365:1:0x0b04]: Message send failure","code":0}
Merci pour votre aide.
