Bonjour, je viens de remarquer que le démon était NOK avec le log suivant:
/usr/lib/python3/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.9) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
File "/var/www/html/plugins/broadlink/resources/broadlinkd/broadlinkd.py", line 37, in <module>
from jeedom.jeedom import *
File "/var/www/html/plugins/broadlink/resources/broadlinkd/jeedom/jeedom.py", line 21, in <module>
import requests
File "/usr/lib/python3/dist-packages/requests/__init__.py", line 95, in <module>
from urllib3.contrib import pyopenssl
File "/usr/local/lib/python3.7/dist-packages/urllib3/contrib/pyopenssl.py", line 50, in <module>
import OpenSSL.SSL
File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 3268, in <module>
_lib.OpenSSL_add_all_algorithms()
AttributeError: module 'lib' has no attribute 'OpenSSL_add_all_algorithms'
[2023-04-06 20:43:45][ERROR] : Impossible de lancer le démon broadlink, vérifiez la log
après reinstallation des dépendances celui-ci ne démarre tjs pas.
Cordialement
