Bonjour à tous, suite à la dernière mise à jour j’ai l’installation des dépendances qui bloque vers 10%.
Ma page santé :
J’ai mis les log du plugin en DEBUG en voici ce que j’obtiens :
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_rfxcom
0003|+ echo 1
0004|+ echo 2
0005|+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
0006|+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
0007|Launch pre-install of rfxcom dependancy
0008|Traceback (most recent call last):
0009|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0010|__import__(vendored_name, globals(), locals(), level=0)
0011|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0012|During handling of the above exception, another exception occurred:
0013|Traceback (most recent call last):
0014|File "/usr/bin/pip3", line 9, in
0015|from pip._internal import main
0016|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0017|from pip._vendor.urllib3.exceptions import DependencyWarning
0018|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0019|vendored("cachecontrol")
0020|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0021|__import__(modulename, globals(), locals(), level=0)
0022|File "", line 983, in _find_and_load
0023|File "", line 967, in _find_and_load_unlocked
0024|File "", line 668, in _load_unlocked
0025|File "", line 638, in _load_backward_compatible
0026|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0027|File "", line 983, in _find_and_load
0028|File "", line 967, in _find_and_load_unlocked
0029|File "", line 668, in _load_unlocked
0030|File "", line 638, in _load_backward_compatible
0031|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0032|File "", line 983, in _find_and_load
0033|File "", line 967, in _find_and_load_unlocked
0034|File "", line 668, in _load_unlocked
0035|File "", line 638, in _load_backward_compatible
0036|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0037|File "", line 983, in _find_and_load
0038|File "", line 967, in _find_and_load_unlocked
0039|File "", line 668, in _load_unlocked
0040|File "", line 638, in _load_backward_compatible
0041|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0042|File "", line 983, in _find_and_load
0043|File "", line 967, in _find_and_load_unlocked
0044|File "", line 668, in _load_unlocked
0045|File "", line 638, in _load_backward_compatible
0046|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0047|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0048|from OpenSSL import crypto, SSL
0049|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0050|class X509StoreFlags(object):
0051|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0052|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0053|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0054|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0055|Reading package lists...
0056|Building dependency tree...
0057|Reading state information...
0058|Package 'python3-serial' is not installed, so not removed
0059|0 upgraded, 0 newly installed, 0 to remove and 271 not upgraded.
0060|+ echo 3
0061|++ awk '$1 <= 4'
0062|++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
0063|++ cut -f 2-
0064|+ RESULTTODELETE=
0065|++ sed 's, ,\ ,g'
0066|++ echo ''
0067|+ RESULTTODELETE2=
0068|+ echo ''
0069|+ xargs rm -rf
0070|+ echo 4
0071|+ sudo pip3 cache purge
0072|Traceback (most recent call last):
0073|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0074|__import__(vendored_name, globals(), locals(), level=0)
0075|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0076|During handling of the above exception, another exception occurred:
0077|Traceback (most recent call last):
0078|File "/usr/bin/pip3", line 9, in
0079|from pip._internal import main
0080|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0081|from pip._vendor.urllib3.exceptions import DependencyWarning
0082|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0083|vendored("cachecontrol")
0084|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0085|__import__(modulename, globals(), locals(), level=0)
0086|File "", line 983, in _find_and_load
0087|File "", line 967, in _find_and_load_unlocked
0088|File "", line 668, in _load_unlocked
0089|File "", line 638, in _load_backward_compatible
0090|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0091|File "", line 983, in _find_and_load
0092|File "", line 967, in _find_and_load_unlocked
0093|File "", line 668, in _load_unlocked
0094|File "", line 638, in _load_backward_compatible
0095|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0096|File "", line 983, in _find_and_load
0097|File "", line 967, in _find_and_load_unlocked
0098|File "", line 668, in _load_unlocked
0099|File "", line 638, in _load_backward_compatible
0100|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0101|File "", line 983, in _find_and_load
0102|File "", line 967, in _find_and_load_unlocked
0103|File "", line 668, in _load_unlocked
0104|File "", line 638, in _load_backward_compatible
0105|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0106|File "", line 983, in _find_and_load
0107|File "", line 967, in _find_and_load_unlocked
0108|File "", line 668, in _load_unlocked
0109|File "", line 638, in _load_backward_compatible
0110|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0111|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0112|from OpenSSL import crypto, SSL
0113|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0114|class X509StoreFlags(object):
0115|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0116|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0117|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0118|+ echo 5
0119|+ sudo pip3 install --upgrade pip
0120|Traceback (most recent call last):
0121|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0122|__import__(vendored_name, globals(), locals(), level=0)
0123|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0124|During handling of the above exception, another exception occurred:
0125|Traceback (most recent call last):
0126|File "/usr/bin/pip3", line 9, in
0127|from pip._internal import main
0128|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0129|from pip._vendor.urllib3.exceptions import DependencyWarning
0130|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0131|vendored("cachecontrol")
0132|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0133|__import__(modulename, globals(), locals(), level=0)
0134|File "", line 983, in _find_and_load
0135|File "", line 967, in _find_and_load_unlocked
0136|File "", line 668, in _load_unlocked
0137|File "", line 638, in _load_backward_compatible
0138|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0139|File "", line 983, in _find_and_load
0140|File "", line 967, in _find_and_load_unlocked
0141|File "", line 668, in _load_unlocked
0142|File "", line 638, in _load_backward_compatible
0143|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0144|File "", line 983, in _find_and_load
0145|File "", line 967, in _find_and_load_unlocked
0146|File "", line 668, in _load_unlocked
0147|File "", line 638, in _load_backward_compatible
0148|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0149|File "", line 983, in _find_and_load
0150|File "", line 967, in _find_and_load_unlocked
0151|File "", line 668, in _load_unlocked
0152|File "", line 638, in _load_backward_compatible
0153|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0154|File "", line 983, in _find_and_load
0155|File "", line 967, in _find_and_load_unlocked
0156|File "", line 668, in _load_unlocked
0157|File "", line 638, in _load_backward_compatible
0158|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0159|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0160|from OpenSSL import crypto, SSL
0161|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0162|class X509StoreFlags(object):
0163|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0164|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0165|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0166|+ echo 6
0167|+ sudo pip3 install --force-reinstall --upgrade six
0168|Traceback (most recent call last):
0169|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0170|__import__(vendored_name, globals(), locals(), level=0)
0171|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0172|During handling of the above exception, another exception occurred:
0173|Traceback (most recent call last):
0174|File "/usr/bin/pip3", line 9, in
0175|from pip._internal import main
0176|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0177|from pip._vendor.urllib3.exceptions import DependencyWarning
0178|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0179|vendored("cachecontrol")
0180|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0181|__import__(modulename, globals(), locals(), level=0)
0182|File "", line 983, in _find_and_load
0183|File "", line 967, in _find_and_load_unlocked
0184|File "", line 668, in _load_unlocked
0185|File "", line 638, in _load_backward_compatible
0186|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0187|File "", line 983, in _find_and_load
0188|File "", line 967, in _find_and_load_unlocked
0189|File "", line 668, in _load_unlocked
0190|File "", line 638, in _load_backward_compatible
0191|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0192|File "", line 983, in _find_and_load
0193|File "", line 967, in _find_and_load_unlocked
0194|File "", line 668, in _load_unlocked
0195|File "", line 638, in _load_backward_compatible
0196|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0197|File "", line 983, in _find_and_load
0198|File "", line 967, in _find_and_load_unlocked
0199|File "", line 668, in _load_unlocked
0200|File "", line 638, in _load_backward_compatible
0201|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0202|File "", line 983, in _find_and_load
0203|File "", line 967, in _find_and_load_unlocked
0204|File "", line 668, in _load_unlocked
0205|File "", line 638, in _load_backward_compatible
0206|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0207|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0208|from OpenSSL import crypto, SSL
0209|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0210|class X509StoreFlags(object):
0211|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0212|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0213|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0214|+ echo 7
0215|+ sudo pip3 install --force-reinstall --upgrade requests
0216|Traceback (most recent call last):
0217|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0218|__import__(vendored_name, globals(), locals(), level=0)
0219|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0220|During handling of the above exception, another exception occurred:
0221|Traceback (most recent call last):
0222|File "/usr/bin/pip3", line 9, in
0223|from pip._internal import main
0224|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0225|from pip._vendor.urllib3.exceptions import DependencyWarning
0226|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0227|vendored("cachecontrol")
0228|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0229|__import__(modulename, globals(), locals(), level=0)
0230|File "", line 983, in _find_and_load
0231|File "", line 967, in _find_and_load_unlocked
0232|File "", line 668, in _load_unlocked
0233|File "", line 638, in _load_backward_compatible
0234|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0235|File "", line 983, in _find_and_load
0236|File "", line 967, in _find_and_load_unlocked
0237|File "", line 668, in _load_unlocked
0238|File "", line 638, in _load_backward_compatible
0239|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0240|File "", line 983, in _find_and_load
0241|File "", line 967, in _find_and_load_unlocked
0242|File "", line 668, in _load_unlocked
0243|File "", line 638, in _load_backward_compatible
0244|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0245|File "", line 983, in _find_and_load
0246|File "", line 967, in _find_and_load_unlocked
0247|File "", line 668, in _load_unlocked
0248|File "", line 638, in _load_backward_compatible
0249|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0250|File "", line 983, in _find_and_load
0251|File "", line 967, in _find_and_load_unlocked
0252|File "", line 668, in _load_unlocked
0253|File "", line 638, in _load_backward_compatible
0254|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0255|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0256|from OpenSSL import crypto, SSL
0257|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0258|class X509StoreFlags(object):
0259|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0260|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0261|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0262|+ echo 8
0263|+ sudo pip3 install --force-reinstall --upgrade setuptools
0264|Traceback (most recent call last):
0265|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0266|__import__(vendored_name, globals(), locals(), level=0)
0267|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0268|During handling of the above exception, another exception occurred:
0269|Traceback (most recent call last):
0270|File "/usr/bin/pip3", line 9, in
0271|from pip._internal import main
0272|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0273|from pip._vendor.urllib3.exceptions import DependencyWarning
0274|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0275|vendored("cachecontrol")
0276|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0277|__import__(modulename, globals(), locals(), level=0)
0278|File "", line 983, in _find_and_load
0279|File "", line 967, in _find_and_load_unlocked
0280|File "", line 668, in _load_unlocked
0281|File "", line 638, in _load_backward_compatible
0282|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0283|File "", line 983, in _find_and_load
0284|File "", line 967, in _find_and_load_unlocked
0285|File "", line 668, in _load_unlocked
0286|File "", line 638, in _load_backward_compatible
0287|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0288|File "", line 983, in _find_and_load
0289|File "", line 967, in _find_and_load_unlocked
0290|File "", line 668, in _load_unlocked
0291|File "", line 638, in _load_backward_compatible
0292|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0293|File "", line 983, in _find_and_load
0294|File "", line 967, in _find_and_load_unlocked
0295|File "", line 668, in _load_unlocked
0296|File "", line 638, in _load_backward_compatible
0297|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0298|File "", line 983, in _find_and_load
0299|File "", line 967, in _find_and_load_unlocked
0300|File "", line 668, in _load_unlocked
0301|File "", line 638, in _load_backward_compatible
0302|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0303|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0304|from OpenSSL import crypto, SSL
0305|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0306|class X509StoreFlags(object):
0307|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0308|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0309|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0310|+ echo 9
0311|+ sudo pip3 install --force-reinstall --upgrade pyudev
0312|Traceback (most recent call last):
0313|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0314|__import__(vendored_name, globals(), locals(), level=0)
0315|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0316|During handling of the above exception, another exception occurred:
0317|Traceback (most recent call last):
0318|File "/usr/bin/pip3", line 9, in
0319|from pip._internal import main
0320|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0321|from pip._vendor.urllib3.exceptions import DependencyWarning
0322|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0323|vendored("cachecontrol")
0324|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0325|__import__(modulename, globals(), locals(), level=0)
0326|File "", line 983, in _find_and_load
0327|File "", line 967, in _find_and_load_unlocked
0328|File "", line 668, in _load_unlocked
0329|File "", line 638, in _load_backward_compatible
0330|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0331|File "", line 983, in _find_and_load
0332|File "", line 967, in _find_and_load_unlocked
0333|File "", line 668, in _load_unlocked
0334|File "", line 638, in _load_backward_compatible
0335|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0336|File "", line 983, in _find_and_load
0337|File "", line 967, in _find_and_load_unlocked
0338|File "", line 668, in _load_unlocked
0339|File "", line 638, in _load_backward_compatible
0340|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0341|File "", line 983, in _find_and_load
0342|File "", line 967, in _find_and_load_unlocked
0343|File "", line 668, in _load_unlocked
0344|File "", line 638, in _load_backward_compatible
0345|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0346|File "", line 983, in _find_and_load
0347|File "", line 967, in _find_and_load_unlocked
0348|File "", line 668, in _load_unlocked
0349|File "", line 638, in _load_backward_compatible
0350|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0351|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0352|from OpenSSL import crypto, SSL
0353|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0354|class X509StoreFlags(object):
0355|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0356|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0357|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0358|+ echo 10
0359|+ sudo pip3 install --force-reinstall --upgrade pyserial
0360|Traceback (most recent call last):
0361|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
0362|__import__(vendored_name, globals(), locals(), level=0)
0363|ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
0364|During handling of the above exception, another exception occurred:
0365|Traceback (most recent call last):
0366|File "/usr/bin/pip3", line 9, in
0367|from pip._internal import main
0368|File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
0369|from pip._vendor.urllib3.exceptions import DependencyWarning
0370|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
0371|vendored("cachecontrol")
0372|File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
0373|__import__(modulename, globals(), locals(), level=0)
0374|File "", line 983, in _find_and_load
0375|File "", line 967, in _find_and_load_unlocked
0376|File "", line 668, in _load_unlocked
0377|File "", line 638, in _load_backward_compatible
0378|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
0379|File "", line 983, in _find_and_load
0380|File "", line 967, in _find_and_load_unlocked
0381|File "", line 668, in _load_unlocked
0382|File "", line 638, in _load_backward_compatible
0383|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
0384|File "", line 983, in _find_and_load
0385|File "", line 967, in _find_and_load_unlocked
0386|File "", line 668, in _load_unlocked
0387|File "", line 638, in _load_backward_compatible
0388|File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
0389|File "", line 983, in _find_and_load
0390|File "", line 967, in _find_and_load_unlocked
0391|File "", line 668, in _load_unlocked
0392|File "", line 638, in _load_backward_compatible
0393|File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
0394|File "", line 983, in _find_and_load
0395|File "", line 967, in _find_and_load_unlocked
0396|File "", line 668, in _load_unlocked
0397|File "", line 638, in _load_backward_compatible
0398|File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
0399|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in
0400|from OpenSSL import crypto, SSL
0401|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1517, in
0402|class X509StoreFlags(object):
0403|File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 1537, in X509StoreFlags
0404|CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
0405|AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
0406|+ echo 11
0407|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
0408|+ rm /tmp/jeedom_install_in_progress_rfxcom
0409|+ echo '*******************End of package installation******************'
0410|*******************End of package installation******************
Je suis donc aller vérifier mes packages système via le bouton qui va bien dans la config et j’ai la désagréable surprise de découvrir ceci ![]()
Donc ni une ni deux je recherche dans le forum et je trouve une commande pour forcer une réinstallation
sudo python3 -m pip install --force-reinstall --ignore-installed --no-cache-dir pyserial
qui malheureusement se fini par la même erreur
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/lib/python3/dist-packages/pip/__main__.py", line 16, in
from pip._internal import main as _main # isort:skip # noqa
Si quelqu’un a une autre idée pour m’éviter un retour arrière je lui serait super reconnaissant ![]()
