Je viens de mettre ma box Tahoma à jour, et depuis j’ai ce message d’erreur a chaque pull():
Erreur sur tahoma::pull() : [Aucun][OGP (AB5A9831)][core:RGBColorState] Le sous-type de la commande ne peut pas être vide :tahomaCmd Object ( [id:protected] => [logicalId:protected] => core:RGBColorState [generic_type:protected] => [eqType:protected] => [name:protected] => core:RGBColorState [order:protected] => [type:protected] => info [subType:protected] => [eqLogic_id:protected] => 583 [isHistorized:protected] => 0 [unite:protected] => [configuration:protected] => Array ( [type] => core:RGBColorState ) [template:protected] => [display:protected] => [value:protected] => [isVisible:protected] => 0 [alert:protected] => [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => tahoma Object ( [id:protected] => 583 [name:protected] => OGP (AB5A9831) [logicalId:protected] => [generic_type:protected] => [object_id:protected] => [eqType_name:protected] => tahoma [eqReal_id:protected] => [isVisible:protected] => 1 [isEnable:protected] => 1 [configuration:protected] => {"type":"ogp:Light","deviceURL":"ogp:XXXXXX","createtime":"2020-12-01 14:18:24"} [timeout:protected] => [category:protected] => [] [display:protected] => {"height":"110px","width":"230px"} [order:protected] => 9999 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => ) [_needRefreshWidget:protected] => 1 [_needRefreshAlert:protected] => [_changed:protected] => 1 )
Est-ce que quelqu’un a deja eu ce probléme ?
Merci de votre aide
